Electric Parts List
Revision as of 13:47, 30 June 2010; view current revision
For an overview of electric vehicle conversions for Datsun 1200, see Electric. Follows is one way to do it
Motor
8" DC motor
Adapter plate to stock transmission
(Optional: Use 60-series four speed for more durability)
Aluminum spacer for Datsun crank adapter to bolt the stock flywheel
Mounting
Aluminum mount with Ford engine mounts
* Purchase Ready-made for 8" motor
Battery Pack
128 Volt pack
40 Thundersky lithium ion 60ah batteries. $3000
* 128V pack (40 individual batteries)
* Weight: 300 lbs
Battery pack straps
Tin-plate copper battery interconnects
Inter-cell regulators
Mounting
Aluminum pack brackets/carrier frame
* can fit above engine subframe rails, fairly simple
* or in ute bed with simple bolted down rectangle box
* or under ute bed with careful fabrication of carrier
* Must prevent upward movement
* Must prevent sideways movement
Control
Use the stock Datsun 1200 accelerator pedal
Use the stock 1200 throttle cable
Connect it to the controller 'pot box'
Optional
Room Heater
Electric Heater Core: 108-156 VDC, 1500 watts $104.50
* Direct replacement for your vehicle's original heater core
* Not cheap, but very warm for cold, damp climates
High voltage relay
Gauges
Driver's Gauges: Voltmeter, etc.
*: Image0025.jpg
