Vanette C120 and C22 came with modern distributors for A-series engine. C22 had electronic ignition.
22100-G5110
Mitsubishi distributor 22100-G5110 has the small vacuum advance unit, which look like the original Datsun 1200 advance. G51 is the Applied model Code for Nissan Vanette C22 circa 1986 with A-series engine.
Discussion: Info on distrubutor please
22301-G5710
22100-G5710 Mitsubishi T4T00571/T4T05712 is points-type distributor (non-electronic)
- Vanette, (C22)
- Ignition system type: CB / electronic
- Ignition coil make/type: Han/H5-13-49
- Supply voltage: 4.1 + Volts with ballast resistor
- distributor cap: 22162-78A10
- rotor button: 22157-23G15
- Vacuum Advance unit: 22301-G5710
