Vanette C120 and C22 came with modern distributors for A-series engine. C22 had electronic ignition.
List
22100-W8511 C120 0779-0286 A15 EUR 22100-G1910 C120 0386- A15 EUR 22100-G5010 C120 0283-0884 A15 SWE 22100-G2770 C120 0984-0286 A15 SWE 22100-G2710 C120 0386- A15 SWE 22100-G5710 GC22 A15S EUR 22100-G2510 C120 A12S 7810-7907 JDM 22100-G2570 C120 A12S 7906-8512 JDM 22100-G6110 C120 A12S 8512- JDM 22100-G2810 C120 A14.K.MT 7810-8006 JDM 22100-G2815 C120 A14.K.AT 7810-8006 JDM 22100-G3210 C120 A14.(V,T) 7810-7907 JDM 22100-G2571 C120 A14.(V,T) 7906-8106 JDM 22100-G2561 C120 A15.(V,T) 8106-8209 JDM 22100-G2561 C120 A15.(V,T) A15.WV 8209-8512 JDM 22100-G2571 C120 A15.(V,T) A15.WV 8209-8512 JDM 22100-G2800 C120 A15.K.MT 8104- JDM 22100-G2805 C120 A15.AT 8104- JDM 22100-G2810 C120 A15.K.MT 8006- JDM 22100-G2815 C120 A15.AT 8006- JDM 22100-G4600 C120 A15.(V,T) A15.WV 8512- JDM 22100-G4610 C120 A15.(V,T) A15.WV 8512- JDM 22100-G2570 C22 A12S 8509-8602 JDM 22100-G6110 C22 A12S 8602-8809 JDM 22100-G6110 C22 A12.S3/6 8809-8811 JDM T3T03579B 22100-G6111 C22 A12.S3/6 8811- JDM 22100-G8210 C22 A12.S3 8809-8811 JDM 22100-G8211 C22 A12.S3 8811- JDM 22100-G5110 C22 A15.K.MT 8509-9106 JDM 22100-G5115 C22 A15.K.AT 8509-9106 JDM 22100-G5710 C22 A15.V 8509- JDM 22100-G5710 GC22 A15S JDM 22100-G8210 TC22 A12S 8811-8812 JDM 22100-G8211 TC22 A12S 8812- JDM 22100-G5710 TC22 A15S JDM
22100-W8511
C120 0779-0286 A15 EUR * interchangable with 22100-G1910
22100-G1910
C120 0386- A15 EUR
22100-G5010
C120 0283-0884 A15 SWE * interchangable with 22100-G6410
22100-G2770
C120 0984-0286 A15 SWE * interchangable with 22100-G2710
22100-G2710
C120 0386- A15 SWE
22100-G5110
Mitsubishi distributor 22100-G5110 has the small vacuum advance unit, which look like the original Datsun 1200 advance. G51 is the Applied model Code for Nissan Vanette C22 circa 1986 with A-series engine.
Discussion: Info on distrubutor please
22301-G5710
22100-G5710 Mitsubishi T4T00571/T4T05712 is points-type distributor (non-electronic)
22100-G5710 * GC22 A15S EUR
- Vanette, (C22)
- Ignition system type: CB / electronic
- Ignition coil make/type: Han/H5-13-49
- Supply voltage: 4.1 + Volts with ballast resistor
- distributor cap: 22162-78A10
- rotor button: 22157-23G15
- Vacuum Advance unit: 22301-G5710
