Intermittent Wipers
Revision as of 04:30, 12 September 2010; view current revision
Mid-model utes and later Sunny Truck came with intermittent wipers.
1978-up B120
This is a direct bolt-in for earlier 1200s, except for needing to wire up one connector. You would need the amplifier and wiper switch, and sub harness:
  • 25260-G1060 SWITCH ASSY-WIPER F/INTMT WIPER
    7804-8109 OPTION
    8110- STANDARD EQUIPMENT
    • 28890-B8060 AMP-INTERMITTENT WIPER 7804-
    • 28890-B8060 USA 620 AMP UNIT-INTERMITENT WIPER DX 0778-
      • replaced 28820-R4710 JDM 620 AMP-INTERMITENT WIPER -7708
      • 08513-30812 SCREW
    • WIPER SUB HARNESS
    • 24018-B9300 USA 620 HARNESS-WIPER DX 0778-
  • 25260-B5005 JDM 620 SWITCH ASSY-WIPER W/INTERMITTENT
  • 25260-B9300 USA 620 COMP-SWITCH,WIPER (INTERMITENT DX 0778- $35.80 USD
    • Possibly may fit 1200 dash?
Does this work???
  1. Remove the regular wiper switch
  2. Install the new wiper switch and connect it to the stock harness
  3. Screw the AMP to the steering post with its SUB HARNESS
  4. Connect AMP harness to SWITCH
  5. Create the new connector (in Red circle of wiring diagram) and plug it in
    1. Connect Blue/Red (LR) wire to fuse box 'W' terminal
    2. Connect Black wire to an available earth
    3. Connect Yellow wire to the original stock SWITCH connector Y wire
  • 710 JDM 25260-N7400 SWITCH INT.
    • 28890-N7400 AMP $102.68
  • 25260-N5820 S10 USA switch
    • 28890-M7300, 28890-U7500
  • S110 USA AMP more complicated + stalk
    • 28510-N8305, 28510-N8405 AMP
Others
B310
Some B310s had intermittent wipers. Apparently the motor is the same, but there is an "amplifier" box. Perhaps it can be adapted to the 1200.
Aftermarket
Hella Australia make a universal intermittant wiper switch. Unlike the 1200 intermittent option, it doesn't have set speeds you just turn the dial and the speed changes (variable-speed intermittent).
http://db.hella.com.au/cgi-bin/catalo ... flcmd=preview&flmaint=365
