Release Lever
Revision as of 02:08, 28 April 2011; view current revision
The Clutch Release Lever is also known as the clutch fork or withdrawal lever. The release lever is inside the transmission bellhousing and operates the release bearing to engage/disengage the clutch.
  1. Withdrawal lever
  2. Return spring
  3. Release bearing
RHD, cable clutch
All 1200s, including coupe, sedan, wagon and pickup -- all years -- use the same lever. RHD and LHD levers and their rubber dust covers differ. All other parts (spring, pivot ball and release bearing) are the same RHD vs LHD.
  • 30531-H1000 LEVER-WITHDRAWAL
Comparison
B210/B310
* 30531-H7410 Withdrawal Lever 60-series
B110/B120/B210/B310
* 30531-H1000 Withdrawal Lever 56-series
B210/B310
63-series
* 30531-B5050 LEVER-WITHDRAWAL B210 F4W63L, L16S.FS5W63A
* 30531-K0550 LEVER-WITHDRAWAL B210 A14.FS5W63A
  • 30531-H1000 LEVER-withdrawal, clutch
  • 30537-H1000 PIN-ball, withdrawal lever
    • 08915-14010 (89-15140-1) WASHER-lock
  • 30501-H1000 SLEEVE-bearing, clutch release
  • 30502-21000 BEARING-clutch release
  • 30533-H1001 SPRING-return, clutch release
  • 30542-H1000 COVER-dust, withdrawal lever
  • 30543-H1000 BOOT-rubber, transmission case
LHD, Hydraulic Clutch
  • 30531-H1600 LEVER-WITHDRAWAL CLUTCH
  • 30537-21010 PIN-BALL WITHDRAWAL LEVER [Datsun 510 part number]
  • 30537-H1000 PIN-BALL WITHDRAWAL LEVER
    • 08915-14010 WASHER-SPRING
  • 30501-H1000 SLEEAVE-BEARING CLUTCH RELEASE
  • 30502-21000 BEARING-CLUTCH RELEASE
  • 30533-H1001 SPRING-RETURN CLUTCH RELEASE
  • 30542-H1600 COVER-DUST WITHDRAWAL LEVER
  • 30543-H1600 BOOT-RUBBER
