When using a Datsun Electronic Ignition distributor, you can use the stock 1200 coil as long as you leave the ballast resistor in place. But a high-energy Datsun coil has vastly better performance.
Also see: EI Wiring
Stock coil is 1.3 ohms + 1.5 ohm resistor = 3.2 ohm, so it will draw 3.75 amps at 12 volts (I=V/R). This low amperage is to prevent the contact points from burning out.
Points coil: 3.75 amps Nissan N12 Pulsar IE coil: 12 amps
For best performance, use the Pulsar coil or a performance coil. It draws 12.9 amps @ 0.93 ohms. Any 1980s Datsun-Nissan EI coil should work just fine. With this type of coil, bypass the stock resistor. Remove it or simply jump a wire (short) across both terminals.
The coil from a Series 2 Bluebird (Datsun 910) or R31 Pintara with electronic dizzy may be used with Datsun/Nissan electronic ignition. Bosch GT40R or GT40RT can be used as a direct replacement for the stock 1200 coil, but is less powerful than the stocker 1.3 ohm coil.
Pulsar Coil aftermarket Standard Motor Products UC12 Primary 200 Scale .7 - 1.4 Secondary 200 Scale 9.0k - 15.5k N12 part number 22433-11M00 assembly 22462-11M00 Hitachi coil 22462-N7811 Hanshin coil
Bosch HEC715 (made in China) is the aftermarket coil for EI systems, and draws more current (0.41 ohms). Consider using an ignition relay as this will draw a peak 29 amps (I=V/R) -- although considerably less in usage.
MSD Blaster
For multi-channel coil drivers (not stock IE) Low resistance, quick rise time for high-revving systems Maximum Output: 43,000 volts 85:1 windings
MSD Blaster 2/MSD Blaster 3
Primary Resistance: 0.7 ohms Secondary Resistance: 4.70K ohms 100:1 windings Maximum Output: 45,000 volts
