Distributor Part Numbers
Revision as of 06:15, 8 January 2012; view current revision
Categories: Catalog | Engine Electrical
Also see:
Part Numbers Index
main article: Distributor for usage, photos, cross-reference
Crank Type
DISTRIBUTOR(CRANK)
22100-H1001 ASSY-DISTRIBUTOR(HITACHI) A12 CRANK
2 22167-H2300 SET-CAP CLAMP A12 CRANK
3 22108-H2300 ASSY-SHAFT A12 CRANK
3 22108-H2301 ASSY-SHAFT A12 CRANK 2 22108-H2300
4 22109-71300 WEIGHT-GOVERNOR 2 A12 CRANK
5 22110-H1000 SPRING-GOVERNOR SET A12 CRANK
6 22132-21005 ASSY-CAM A12 CRANK
6 22132-22005 ASSY-CAM A12 CRANK 2 22132-21005
7 22119-18000 SET-PINION A12 CRANK
8 22136-H2300 ASSY-BRAKER A12 CRANK
9 22145-18005 SET-CONTACT A12 CRANK
10 22182-71300 WIRE-EATH A12 CRANK
11 22183-71300 WIRE-LEAD A12 CRANK
12 22403-18005 ASSY-TERMINAL A12 CRANK
13 22157-78500 ROTOR-HEAD A12 CRANK
13 22157-H1000 ROTOR-HEAD A12 CRANK 0871- 2 22157-78500
14 22162-21007 ASSY-CAP A12 CRANK
15 22165-30101 POINT-CARBON A12 CRANK
16 22301-H1000 ASSY-CONTROL VACUUM A12 CRANK
17 22102-00801 CONDENSER A12 CRANK
18 22248-A5502 SEAL-DUST A12 CRANK
19 22750-H2300 SET-SCREW A12 CRANK
Exhaust & Evapo Type
DISTRIBUTOR(EXHAUST & EVAPO)
1 22100-H1901 DISTRIBUTOR(HITACHI) A12 EXHAUST & EVAPO
1 22100-H1902 DISTRIBUTOR (HITACHI D412-63A) A12 AUTO 1271- 2 22100-H1901
1 22100-H7100 DISTRIBUTDR (HITACHI) A12 AUTOMATIC 0772- 0 22100-H1902
1 22100-H3900 DISTRIBUTOR(HITACHI) A12,MANUAL 0671-
1 22100-H3901 DISTRIBUTOR (HITACHI D412-80A) A12,MANUAL 1271- 2 22100-H3900
2 22167-H2300 SET-CLAMP,CAP A12 EXHAUST & EVAPO
3 22108-H1900 ASSY-SHAFT A12 1271- 0 22108-H2300
3 22108-H2300 ASSY-SHAFT A12 EXHAUST & EVAPO
3 22108-H2301 ASSY-SHAFT A12 EXHAUST & EVAPO 2 22108-H2300
4 22160-M0800 SET-WASHER THRUST A12 EXHAUST & EVAPO
5 22109-71300 WEIGHT-GOVERNOR 2 A12 EXHAUST & EVAPO
6 22110-H1900 SPRING-GOVERNOR A12 EXHAUST & EVAPO
6 22110-H1901 SPRING-GOVERNOR A12 1271- 0 22110-H1900
6 22110-H7100 SPRING-GOVERNOR A12 0772- 0 22110-H1901
7 22132-H1901 ASSY-CAM SET A12 1271- 0 22132-H1900
7 22132-H1900 ASSY-CAM SET A12 EXHAUST & EVAPO
8 22119-18000 SET-PINION A12 EXHAUST & EVAPO
9 22136-H2300 ASSY-BRAKER PLATE A12 EXHAUST & EVAPO
9 22136-E4600 ASSY-BRAKER PLATE A12 1271-
10 22145-18005 SET-CONTACT A12 EXHAUST & EVAPO
10 22145-89901 SET-CONTACT A12 EXHAUST & EVAPO 22145-18005
11 22182-71300 ASSY-WIRE,EARTH A12 EXHAUST & EVAPO
12 22183-71300 ASSY-WIRE,LEAD A12 EXHAUST & EVAPO
13 22403-18005 ASSY-TERMINAL A12 EXHAUST & EVAPO
14 22248-A5502 SEAL-DUST 2 A12 EXHAUST & EVAPO
15 22157-78500 ASSY-ROTOR,HEAD A12 EXHAUST & EVAPO
15 22157-H1000 ASSY-ROTOR,HEAD A12 EXHAUST & EVAPO 0871- 2 22157-78500
15 22157-D1290 ASSY-ROTOR,HEAD A12 EXHAUST & EVAPO 0871- 2 22157-H1000
16 22162-21007 ASSY-CAP A12 EXHAUST & EVAPO
17 22165-30101 POINT-CARBON A12 EXHAUST & EVAPO
18 22301-B3000 ASSY-CONTROL,VACUUM A12 EXHAUST & EVAPO
18 22301-B3001 ASSY-CONTROL,VACUUM A12 EXHAUST & EVAPO 2 22301-B3000
18 22301-H1900 ASSY-CONTROL,VACUUM A12 AUTO 1271- 0 22301-B0300
18 22301-E4603 ASSY-CONTROL,VACUUM A12 AUTO 0772- 0 22301-H1900
18 22301-H3900 ASSY-CONTROL,VACUUM A12,MANUAL 0671-
18 22301-H3901 ASSY-CONTROL,VACUUM A12,MANUAL 1271- 0 22301-H3900
19 22102-00801 ASSY-CONDENSER A12 EXHAUST & EVAPO
19 22102-D1100 ASSY-CONDENSER A12 EXHAUST & EVAPO 22102-00801
20 22750-H2300 SET-SCREW A12 EXHAUST & EVAPO
21 22180-18000 PLATE-FIX A12 EXHAUST & EVAPO
22 22201-18005 BOLT A12 EXHAUST & EVAPO
