Also see:
Part Numbers Index Main article for usage, photos, cross-reference Piston Crankshaft Connecting Rods Flywheel Camshaft bearings
1 12010-H1011 SET-PISTON WITH PIN STD (4) A12 0672- 2 12010-H1001 1 12010-H1003 SET-PISTON WITH PIN 0.25 OVER SIZE (4) A12 1 12010-H1004 SET-PISTON WITH PIN 0.50 OVER SIZE (4) A12 12010-H1065 SET-PISTON WITH PIN 0.50 OVER SIZE (4) A12 0672- 2 12010-H1014 1 12010-H1014 SET-PISTON WITH PIN 0.50 OVER SIZE (4) A12 0672- 2 12010-H1004 1 12010-H1005 SET-PISTON WITH PIN 0.75 OVER SIZE (4) A12 1 12010-H1006 SET-PISTON WITH PIN 1.00 OVER SIZE (4) A12 12010-H1066 SET-PISTON WITH PIN 1.00 OVER SIZE [-0.40] (4) A12 0672- 2 12010-H1016 1 12010-H1016 SET-PISTON WITH PIN 1.00 OVER SIZE (4) A12 0672- 2 12010-H1006 1 12010-H1007 SET-PISTON WITH PIN 1.25 OVER SIZE (4) A12 1 12010-H1008 SET-PISTON WITH PIN 1.50 OVER SIZE (4) A12 12010-H1061 SET-PISTON WITH PIN STD (4) A12 12010-H1001 1 12010-H1001 SET-PISTON WITH PIN STD (4) A12 12035-H6201 SET-RING PISTON 0.50 OVER SIZE (4) A12 2 12035-B3040 2 12035-B3040 SET-RING PISTON 0.50 OVER SIZE (4) A12 2 12035-H1002 12039-H6200 SET-RING PISTON 1.50 OVER SIZE (4) A12 2 12039-B3040 2 12039-B3040 SET-RING PISTON 1.50 OVER SIZE (4) A12 2 12039-H1002 2 12039-H1002 SET-RING PISTON 1.50 OVER SIZE (4) A12 2 12038-H1002 SET-RING PISTON 1.25 OVER SIZE (4) A12 2 12037-B3040 SET-RING PISTON 1.00 OVER SIZE (4) A12 2 12037-H1002 2 12033-H1002 SET-RING PISTON STD (4) A12 2 12037-H1002 SET-RING PISTON 1.00 OVER SIZE (4) A12 2 12035-H1002 SET-RING PISTON 0.50 OVER SIZE (4) A12 2 12034-H1002 SET-RING PISTON 0.25 OVER SIZE (4) A12 2 12033-H6201 SET-RING PISTON STD (4) A12 2 12033-B3040 2 12033-B3040 SET-RING PISTON STD (4) A12 2 12033-H1002 2 12036-H1002 SET-RING PISTON 0.75 OVER SIZE (4) A12 3 12100-H1000 ASSY-CONNECTING ROD (4) A12 4 12109-H1001 BOLT-CONNECTING ROD (TOKYO RASI) (8) A12 4 12109-H1011 BOLT-CONNECTING ROD (TOKAI SEIAT (8) A12 5 12112-18000 NUT-HEX CONNECTING ROD (8) A12 6 12111-20906 BUSHING-CONNECTING ROD UNDERSIZE 100 (8) A12 6 12111-20910 BEARING-CONNECTING ROD STD (8) A12 12111-20900 6 12111-20900 BEARING-CONNECTING ROD STD (8) A12 6 12111-20901 BUSHING-CONNECTING ROD UNDERSIZE 8 (8) A12 6 12111-20902 BUSHING-CONNECTING ROD UNDERSIZE 12 (8) A12 6 12111-20903 BUSHING-CONNECTING ROD UNDERSIZE 25 (8) A12 6 12111-20905 BUSHING-CONNECTING ROD UNDERSIZE 75 (8) A12 6 12111-20904 BUSHING-CONNECTING ROD UNDERSIZE 50 (8) A12 7 12200-H1000 ASSY-CRANKSHAFT A12 MANUAL 7 12200-H1001 CRANKSHAFT A12 -671 12 12200-H1000 7 12200-H1000 CRANKSHAFT A12 0671- 2 12200-H1001 7 12200-H5000 CRANKSHAFT A12 0572- 2 12200-H1000 8 00933-20650 PLUG-TAPER (4) A12 8 01647-00011 PLUG-TAPER (4) A12 2 00933-20650 9 32202-18000 BUSHING-PILOT A12 MANUAL 10 12316-30000 KEY-WOODLUF 5X16 (2) A12 11 13021-H1000 SPROCKET-CRANK A12 12 12301-30000 WASHER-PACKING CRANKSHAFT (0) A12 13 12299-18000 SHIM-CRANK SPROCKET (0) A12 14 12302-18000 THROWER-OIL CRANKSHAFT A12 15 12303-H1001 PULLEY-CRANKSHAFT A12 0272- 0 12303-18002 15 12303-18002 PULLEY-CRANKSHAFT A12 16 12308-H1000 WASHER-PULLEY BOLT A12 17 12309-78200 BOLT-CRANK PULLEY A12 18 12310-H1000 ASSY-FLY WHEEL A12 MANUAL 19 12312-18000 GEAR-RING FLY WHEEL A12 MANUAL 20 12313-10600 DOWL (3) A12 MANUAL 21 12315-H1001 BOLT-FLY WHEEL (6) A12 MANUAL 22 12331-20300 ASSY-DRIVE PLATE & GEAR A12 AUTOMATIC 23 12330-20300 PILOT-CONVERTER A12 AUTOMATIC 24 12333-20300 PLATE-CRANK CONVERTER A12 AUTOMATIC 25 12315-H1000 BOLT-FLY WHEEL (6) A12 AUTOMATIC 26 12212-H1000 SET-BEARING US 1.00MM A12 26 12207-M7201 SET-BEARING STD A12 12207-H1000 26 12207-H1000 SET-BEARING STD A12 26 12208-H1000 SET-BEARING US 0.20MM A12 26 12209-H1000 SET-BEARING US 0.25MM A12 26 12210-H1000 SET-BEARING US 0.50MM A12 26 12211-H1000 SET-BEARING US 0.75MM A12
