Also see:
Part Numbers Index Main article for usage, photos, cross-reference Window Regulator for Window Winder/Regulator Handle Door Lock (door latch and door handle)
Sedan
1 80500-H3600 ASSY-DOOR LOCK & REMOTE CONTROL FRON SEDAN 2 DOOR 2 80501-H3600 ASSY-DOOR LOCK & REMOTE CONTROL FRON SEDAN 2 DOOR 3 80502-H1201 ASSY-DOOR LOCK FRONT RH SEDAN 2 DOOR 3 80502-H3600 ASSY-DOOR LOCK FRONT RH SEDAN 2 DOOR 4 80503-H1201 ASSY-DOOR LOCK FRONT LH SEDAN 2 DOOR 4 80503-H3600 ASSY-DOOR LOCK FRONT LH SEDAN 2 DOOR 5 80504-H1001 ASSY-REMOTE CONTROL DOOR LOCK RH SEDAN 2 DOOR 6 80505-H1001 ASSY-REMOTE CONTROL DOOR LOCK LH SEDAN 2 DOOR 7 80508-H1000 SPRING-DOOR LOCK RH SEDAN 2 DOOR 8 80509-H1000 SPRING-DOOR LOCK LH SEDAN 2 DOOR 9 08320-61012 SCREW-MACHINE M6 TO FIX DOORLOCK (6) SEDAN 2 DOOR 10 08916-43610 WASHER-LOCK TOOTH (6) SEDAN 2 DOOR 11 08310-61214 SCREW-MACHINE WITH WASHER (4) SEDAN 2 DOOR 12 08915-43610 WASHER-PLAIN TO FIX REMOTE CONTROL (4) SEDAN 2 DOOR 13 80570-E6000 ASSY-STRIKER DOOR LOCK RH SEDAN 2 DOOR 14 80571-E6000 ASSY-STRIKER DOOR LOCK LH SEDAN 2 DOOR 15 80575-24800 SHIM-STRIKER DOOR LOCK (2) SEDAN 2 DOOR 16 80577-21000 BOLT-SPECIAL TO FIX STRIKER (6) SEDAN 2 DOOR 17 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH SEDAN 2 DOOR 18 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH SEDAN 2 DOOR 19 08330-50820 SCREW-MACHINE M5 TO FIX ESCUTCHEON (2) SEDAN 2 DOOR 20 80595-21003 KNOB-DOOR LOCK (2) SEDAN 2 DOOR 20 80595-N1600 KNOB-DOOR LOCK (2) SEDAN,2 DOOR 80970-A4600 GROMMET-LOCK KNOB (2) SEDAN 2 DOOR 21 80970-21000 GROMMET-LOCK KNOB (2) SEDAN 2 DOOR 22 80605-H1900 ASSY-HANDLE DOOR OUT SIDE FRONT RH SEDAN 2 DOOR 22 80605-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT RH SEDAN 2 DOOR 0371- 23 80606-H1900 ASSY-HANDLE DOOR OUT SIDE FRONT LH SEDAN 2 DOOR 23 80606-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT LH SEDAN 2 DOOR 0371- 24 80608-H1000 ASSY-ROD OUT SIDE HANDLE (2) SEDAN 2 DOOR 25 08915-13510 WASHER-SPRING LOCK (4) SEDAN 2 DOOR 26 08915-43510 WASHER-PLAIN M5 (4) SEDAN 2 DOOR 27 08911-10510 NUT-HEX M5 (4) SEDAN 2 DOOR 28 80760-H1000 ASSY-HANDLE DOOR WINDOW REGULATOR (2) SEDAN 2 DOOR 29 80675-H1000 WASHER-HANDLE (2) SEDAN 2 DOOR 30 08330-51220 SCREW-MACHINE (2) SEDAN 2 DOOR 31 80700-H1000 ASSY-REGULATOR DOOR WINDOW FRONT (2) SEDAN 2 DOOR 31 80700-H1001 ASSY-REGULATOR,DOOR WINDOW, FRONT (2) SEDAN 2 DOOR 32 80700-H1200 ASSY-REGULATOR DOOR WINDOW (2) SEDAN 2 DOOR 1070- 32 80700-H1201 ASSY-REGULATOR DOOR WINDOW (2) SEDAN 2 DOOR 0771- 33 08310-61012 SCREW-MACHINE (6) SEDAN 2 DOOR 34 08915-13610 WASHER-SPRING LOCK M6 (6) SEDAN 2 DOOR 35 84371-H1000 HOLDER-NYLON (2) SEDAN 2 DOOR 35 24220-H6200 HOLDER-NYLON (2) SEDAN 2 DOOR 0371-
Coupe
1 80500-H3600 ASSY-DOOR LOCK & REMOTE CONTROL FRON COUPE 2 80501-H3600 ASSY-DOOR LOCK & REMOTE CONTROL FRON COUPE 3 80502-H1201 ASSY-DOOR LOCK FRONT RH COUPE 3 80502-H3600 ASSY-DOOR LOCK FRONT RH COUPE 2 80502-H1201 4 80503-H1201 ASSY-DOOR LOCK FRONT LH COUPE 4 80503-H3600 ASSY-DOOR LOCK FRONT LH COUPE 0671- 2 80503-H1201 5 80504-H1001 ASSY-REMOTE CONTROL DOOR LOCK RH COUPE 6 80505-H1001 ASSY-REMOTE CONTROL DOOR LOCK LH COUPE 7 80508-H1000 SPRING-DOOR LOCK RH COUPE 8 80509-H1000 SPRING-DOOR LOCK LH COUPE 9 08320-61012 SCREW-MACHINE M6 TO FIX DOORLOCK (6) COUPE 10 08916-43610 WASHER LOCK TOOTH TO FIX DOOR LOCK (6) COUPE 11 08310-61214 SCREW-MACHINE WITH WASHER (4) COUPE 12 08915-43610 WASHER-PLAIN TO FIX REMOTE CONTROL (4) COUPE 13 80570-E6000 ASSY-STRIKER DOOR LOCK RH COUPE 14 80571-E6000 ASSY-STRIKER DOOR LOCK LH COUPE 15 80575-24800 SHIM-STRIKER DOOR LOCK (2) COUPE 16 80577-21000 BOLT-SPECIAL TO FIX STRIKER (6) COUPE 17 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH COUPE 18 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH COUPE 19 08330-50820 SCREW-MACHINE M5 TO FIX ESCUTCHEON (2) COUPE 20 80595-21003 KNOB-DOOR LOCK (2) COUPE 20 80595-N1600 KNOB-DOOR LOCK (2) COUPE 2 80595-21003 21 80970-21000 GROMMET-LOCK KNOB (2) COUPE 22 80605-H1900 ASSY-HANDLE DOOR OUT SIDE FRONT RH COUPE 22 80605-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT RH COUPE 0371- 2 80605-H1900 23 80606-H1900 ASSY-HANDLE DOOR OUT SIDE FRONT LH COUPE 23 80606-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT LH COUPE 0371- 2 80605-H1900 24 80608-H1000 ASSY-ROD OUT SIDE HANDLE (2) COUPE 25 08915-13510 WASHER-SPRING LOCK (4) COUPE 26 08915-43510 WASHER-PLAIN M5 (4) COUPE 27 08911-10510 NUT-HEX M5 (4) COUPE 28 80760-H1000 ASSY-HANDLE DOOR WINDOW REGULATOR (2) COUPE 29 80675-H1000 WASHER-HANDLE (2) COUPE 30 08330-51220 SCREW-MACHINE (2) COUPE 31 80700-H1800 ASSY-REGULATOR DOOR WINDOW RH COUPE 32 08310-61012 SCREW-MACHINE 1 (12) COUPE 33 08915-13610 WASHER-SPRING LOCK M6 1 (12) COUPE 34 80701-H1800 ASSY-REGULATOR DOOR WINDOW LH COUPE 35 08915-43610 WASHER-PLAIN M6 (4) COUPE
