Starter Part Numbers
Revision as of 06:12, 11 January 2012; view current revision
Categories: Catalog | Engine Electrica Systeml
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference:
Starting Motor
1 23300-H6900 MOTOR-STARTER (HITACHI S11 A12 AUTO 0673- 2 23300-H3900
1 23300-H0100 MOTOR-STARTER (HITACHI S11 A12
1 23300-H0101 MOTOR-STARTER (HITACHI S11 A12 0170-0671 12 23300-H0100
1 23300-H0101 MOTOR-STARTER (HITACHI S11 A12,MANUAL 0771-0573 3
1 23300-H5000 MOTOR-STARTER (HITACHI S11 A12 0673-
1 23300-H3900 MOTOR-STARTER (HITACHI S11 A12,AUTO 0771-0573 32 23300-H0100
2 23310-H3900 ASSY-ARMATURE A12,AUTO 0771- 0 23310-19900
2 23310-19900 ASSY-ARMATURE A12,MANUAL 0771-
2 23310-19900 ASSY-ARMATURE A12 0170-0671 1
3 23321-09900 WASHER-THRUST 2 A12 0170-
4 23312-10600 ASSY-PINION A12 0170-
4 23312-10605 ASSY-PINION A12 2 23312-10600
4 23312-E3000 ASSY-PINION A12 2 23312-10605
5 23465-E6800 SET-STOPPER PINION A12 0170-
6 23383-10600 ASSY-BEARING CENTER A12 0170-
7 23441-10600 METAL-CENTER BEARING A12 0170-
8 23306-15801 ASSY-COIL FIELD A12,AUTO 0771- 0 23306-M0100
8 23306-M0100 ASSY-COIL FIELD A12 0170-0671 1
8 23306-M0100 ASSY-COIL FIELD A12,MANUAL 0771-
9 23305-09500 SCREW-POLE,CORE 4 A12 0170-
10 23337-18005 ASSY-COVER REAR A12 0170-
10 23337-H0100 ASSY-COVER,REAR A12, 0170-0671 1
10 23337-H0100 ASSY-COVER,REAR A12,MANUAL 0771-
10 23337-10605 ASSY-COVER,REAR A12,AUTO 0771- 0 23337-H0100
11 23338-09900 METAL-COVER REAR A12 0170-
12 23380-19900 BRUSH (+) A12 0170-0671 1
12 23380-19900 BRUSH (+) A12,MANUAL 0771-
12 23380-10600 BRUSH (+) A12,AUTO 0771- 0 23380-19900
13 23379-19900 BRUSH (-) A12 0170-0671 1
13 23379-19900 BRUSH (-) A12,MANUAL 0771-
13 23379-09900 BRUSH (-) A12,AUTO 0771- 0 23379-19900
14 23333-09900 SPRING-BRUSH 2 A12,AUTO 0771- 0 23333-21001
14 23333-09900 SPRING-BRUSH 2 A12 0170-
14 23333-21001 SPRING-BRUSH 2 A12 0170-0671 12 23333-09900
14 23333-21001 SPRING-BRUSH 2 A12,MANUAL 0771-
15 23340-15805 BOLT-THROUGH 2 A12,AUTO 0771- 0 23340-18005
15 23340-18005 BOLT-THROUGH 2 A12 0170-0671 1
15 23340-18005 BOLT-THROUGH 2 A12,MANUAL 0771-
16 23318-H0100 ASSY-GEAR CASE A12 0170-
17 23319-10600 METAL-GEAR CASE A12 0170-
18 23322-M0100 SET-LEVER SHIFT A12 0170-
19 23309-H5000 ASSY-COVER BRUSH A12 0673- 0 23309-19905
19 23309-18005 ASSY-COVER BRUSH A12 0170-0671 1
19 23309-18005 ASSY-COVER BRUSH A12,MANUAL 0771-0573 3
19 23309-19905 ASSY-COVER BRUSH A12,AUTO 0771-0573 30 23309-18005
20 23343-18005 ASSY-SWITCH MAGNETIC A12 0170-
21 23470-M0100 SET-DUST COVER A12 0170-
22 23390-18005 BOLT M5 2 A12 0170-
23 23480-M0100 SET-SCREW A12 0170-
