Transmission Gear Part Numbers
Revision as of 03:00, 23 January 2012; view current revision
Categories: Transmission | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
56-Series Transmission
F4W56L
4-speed Light-Duty to March 1973
1 32280-24901 ASSY-GEAR REVERSE IDLER 17T 4 SPEED
2 32283-24901 BUSH-GEAR REVERSE IDLER 4 SPEED
3 32281-24900 SHAFT-REVERSE IDLER 4 SPEED
4 32285-18000 RING-SNAP REVERSE IDLER (2) 4 SPEED
5 32210-24900 GEAR-COUNTER 29T,25T,19T,13T 4 SPEED
6 32223-24900 BEARING-BALL COUNTER SHAFT 4 SPEED
7 32220-24901 GEAR-REVERSE COUNTER 13T 4 SPEED
8 00922-11700 RING-SNAP 4 SPEED
9 32219-18000 BEARING-BALL COUNTER SHAFT 4 SPEED
10 32224-18003 SHIM-ADJUSTING COUNTER BEARING T=1. (0) 4 SPEED
10 32224-18006 SHIM-ADJUSTING COUNTER BEARING T=1. (0) 4 SPEED
10 32224-18004 SHIM-ADJUSTING COUNTER BEARING T=1. (0) 4 SPEED
10 32224-18002 SHIM-ADJUSTING COUNTER BEARING T=0. (0) 4 SPEED
10 32224-18001 SHIM-ADJUSTING COUNTER BEARING T=0. (0) 4 SPEED
10 32224-18005 SHIM-ADJUSTING COUNTER BEARING T=1. (0) 4 SPEED
11 00922-24000 RING-SNAP 4 SPEED
12 32200-H1000 ASSY-GEAR MAIN DRIVE 19T,30T 4 SPEED
13 32203-18000 BEARING-BALL MAIN SHAFT 4 SPEED
14 32205-18000 WASHER-MAIN BEARING 4 SPEED
15 32204-18000 RING-SNAP MAIN DRIVE GEAR SHAFT 4 SPEED
16 32241-H1010 SHAFT-MAIN 4 SPEED
17 32246-18000 WASHER-THRUST MAIN SHAFT 4 SPEED
18 32253-H1000 BUSH-MAIN SHAFT REVERSE GEAR 4 SPEED 0570- 6 32253-18000
18 32253-18000 BUSH-MAIN SHAFT REVERSE GEAR 4 SPEED
19 32264-H1000 BEARING-NEEDLE MAIN SHAFT 4 SPEED 0570- 6 32264-18000
19 32264-18000 BEARING-NEEDLE MAIN SHAFT 4 SPEED
20 32236-18000 SPACER-NEEDLE BEARING 4 SPEED
21 32230-24900 ASSY-GEAR 1ST SPEED MAIN SHAFT 32T 4 SPEED
22 32604-H1000 RING-BAULK (2) 4 SPEED
23 32609-18000 INSERT-SHIFTING (3) 4 SPEED
24 32603-18000 SPRING-SYNCHRONIZER (2) 4 SPEED
25 32601-18000 HUB-SYNCHRONIZER 4 SPEED
26 32606-18000 SLEAVE-COUPLING 4 SPEED
27 32264-24900 BEARING-NEEDLE MAIN SHAFT (2) 4 SPEED
28 32250-24900 ASSY-GEAR 2ND SPEED MAIN SHAFT 27T 4 SPEED
29 32260-24900 ASSY-GEAR 3RD SPEED MAIN SHAFT 23T 4 SPEED
30 32604-H1000 RING-BAULK (2) 4 SPEED
30 32604-H1010 RING-BAULK (2) 4 SPEED 2 32604-H1000
31 32609-18000 INSERT-SHIFTING (3) 4 SPEED
32 32603-18000 SPRING-SYNCHRONIZER (2) 4 SPEED
33 32601-18000 HUB-SYNCHRONIZER 4 SPEED
34 32606-18000 SLEEVE-COUPLING 4 SPEED
35 32265-18000 WASHER-THRUST SYNCHRO HUB 4 SPEED
35 32265-H7200 WASHER-THRUST SYNCHRO HUB 4 SPEED 0570- 2 32265-18000
36 32720-14600 BALL-STEEL 4 SPEED
37 32272-18000 BEARING-PILOT MAIN SHAFT 4 SPEED
38 32273-24900 BEARING-MAIN SHAFT 4 SPEED
39 32205-18000 WASHER-MAIN BEARING 4 SPEED
40 32204-18000 RING-SNAP MAIN SHAFT 4 SPEED
41 32245-24901 GEAR-REVESE MAIN SHAFT 31T 4 SPEED
F4W56A
4-speed Heavy-Duty from April 1973
1 32280-G1100 ASSY-GEAR REVERSE IDLER 17T 4 SPEED 0473-
2 32283-G1100 BUSH-GEAR REVERSE IDLER 4 SPEED 0473-
3 32281-G1100 SHAFT-REVERSE IDLER 4 SPEED 0473-
4 32285-18000 RING-SNAP REVERSE IDLER 4 SPEED 0473-
5 32210-G1100 GEAR-COUNTER 29T,25T,19T,13T 4 SPEED 0473-
6 32223-24900 BEARING-BALL COUNTER SHAFT 4 SPEED 0473-
7 32220-G1100 GEAR-REVERSE COUNTER 13T 4 SPEED 0473-
8 00922-11700 RING-SNAP 4 SPEED 0473-
9 32219-G1000 BEARING-NEEDLE COUNTER SHAFT 4 SPEED 0473-
10 32224-G1004 WASHER-THRUST COUNTER BEARING T=2 (0) 4 SPEED 0473-0573 3
10 32224-H7205 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0673- 2 32224-G1005
10 32224-H7204 WASHER-THRUST COUNTER BEARING T=2 (0) 4 SPEED 0673- 2 32224-G1004
10 32224-H7203 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0673- 2 32224-G1003
10 32224-G1003 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0473-0573 3
10 32224-G1002 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0473-0573 3
10 32224-H7201 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0673- 2 32224-G1001
10 32224-G1005 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0473-0573 3
10 32224-G1001 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0473-0573 3
10 32224-H7200 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0673- 2 32224-G1000
10 32224-G1000 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0473-0573 3
10 32224-H7202 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0673- 2 32224-G1002
11 32200-G1000 ASSY-GEAR MAIN DRIVE 19T,30T 4 SPEED
12 32203-18000 BEARING-BALL MAIN SHAFT 4 SPEED 0473-
13 32205-18000 WASHER-THRUST MAIN DRIVE GEAR 4 SPEED 0473-
14 32204-18000 RING-SNAP MAIN DRIVE GEAR 4 SPEED 0473-
15 32241-G1101 SHAFT-MAIN 4 SPEED 0473-
16 32246-G1000 WASHER-THRUST MAIN SHAFT 4 SPEED 0473-
17 32253-18000 BUSH-MAIN SHAFT REVERSE GEAR 4 SPEED 0473-
18 32264-18000 BEARING-NEEDLE MAIN SHAFT 4 SPEED 0473-
19 32230-G1100 ASSY-GEAR 1ST SPEED 4 SPEED 0473-
20 32604-H1000 RING-BAULK (2) 4 SPEED 0473-
20 32604-H1010 RING-BAULK (2) 4 SPEED 0473-0573 32 32604-H1000
21 32609-18000 INSERT-SHIFTING (3) 4 SPEED 0473-
22 32603-18000 SPRING-SYNCHRONIZER (2) 4 SPEED 0473-
23 32601-18000 HUB-SYNCHRONIZER 4 SPEED 0473-
24 32606-18000 SLEEVE-COUPLING 4 SPEED 0473-
25 32264-24900 BEARING-NEEDLE MAIN SHAFT (2) 4 SPEED 0473-
26 32250-G1100 ASSY-GEAR 2ND SPEED 4 SPEED
27 32260-G1100 ASSY-GEAR 3RD SPEED 4 SPEED 0473-
28 32604-H1000 RING-BAULK (2) 4 SPEED 0473-
28 32604-H1010 RING-BAULK (2) 4 SPEED 0673- 2 32604-H1000
29 32609-18000 INSERT-SHIFTING (3) 4 SPEED 0473-
30 32603-18000 SPRING-SYNCHRONIZER (2) 4 SPEED
31 32601-18000 HUB-SYNCHRONIZER 4 SPEED
32 32606-18000 SLEEVE-COUPLING 4 SPEED
33 32265-18000 WASHER-THRUST SYNCHRONIZER HUB 4 SPEED 0473-
33 32265-H7200 WASHER-THRUST SYNCHRONIZER HUB 4 SPEED 0473- 2 32265-18000
34 32720-14600 BALL-STEEL 4 SPEED 0473-
35 32272-18000 BEARING-PILOT MAIN SHAFT 4 SPEED 0473-
36 32273-G1000 BEARING-BALL MAIN SHAFT 4 SPEED 0473-
37 32205-18000 WASHER-MAIN BEARING 4 SPEED 0473-
38 32204-18000 RING-SNAP MAIN SHAFT 4 SPEED 0473-
39 32245-G1100 GEAR-REVERSE MAIN SHAFT 4 SPEED 0473-
