Also see:
Part Numbers Index Main articles for usage, photos, cross-reference Rear Body panels & rear 1/4 panel (quarter panel) Parcel Shelf Fuel Door
Contents[hide] |
Truck
76116 FENDER-REAR END,RH 76310-G1050 PANEL ASS'Y-body side outer rear end (R.H.)
76116G HOOK-REAR GATE,RH 90510-G1000 -8910 90510-G1900 8910-
76117 FENDER-REAR END,LH 76311-G1050 PANEL ASS'Y-body side outer rear end (L.H.)
76117G HOOK-REAR GATE,LH 90511-G1000 -8910 90511-G1900 8910-
76392G HOOK-ROPE 93332-G1000 -7803 SB 8, LB 10 93332-G1062 7804-8104 1SB 8, LB 10 <2,0> 93332-G1900 93332-G1900 8105- 5
76779 PATCH-REAR FENDER,RH 76330-G1062 SB 8110- 76330-G1462 LB 8110-
76780 PATCH-REAR FENDER,LH 76331-G1062 SB 8110- 76331-G1462 LB 8110-
78110 FENDER-REAR,RH 76306-G1050 PANEL ASS'Y-body side outer rear with gas filler lid (R.H.) S [early] 76304-G1025 PANEL ASS'Y-body side outer (R.H.) S [early] 76304-G1024 SB 76304-G1426 LB -7803 >< 76304-G1425 76304-G1425 LB 7804-
78111 FENDER-REAR,LH 76307-G1050 PANEL ASS'Y-body side outer rear (L.H.) S [early] 76305-G1025 PANEL ASS'Y-body side outer (L.H.) S [early] 76305-G1024 SB 76305-G1426 LB -7803 >< 76305-G1425 76305-G1425 LB 7804-
78120 BASE-FILLER LID 78135-G1001 8910-
78810 LID-GAS FILLER 78130-G1001 08915-43510 WASHER 08360-51014 SCREW
78810F BUMPER-LID 77760-89902 2
79100M PANEL ASSY-BACK 79100-G1000 -7803 <4,0> 79100-G1060 79100-G1060 7804-
79100N PANEL-BACK,LOWER 79106-G1401 -7803 <> 79106-G1660 79106-G1660 7804-8105 <9,0> 79106-G1902 79106-G1902 8106-8111 SB <4,0> 79106-G1904 79106-G1903 8106-8111 LB <4,0> 79106-G1905 79106-G1904 8112- SB 79106-G1905 8112- LB
79120 PANEL-REAR LOWER [beaver panel] 79110-G1001
Early Fuel Door Detail
01 78130-G1000 COVER ASS'Y-gas filler 02 77760-89902 BUMPER-rubber, gas filler 2 07 76960-H1001 LOCK ASS'Y-gas filler 08 78962-18200 CLIP-seating cylinder lock 09 08310-51014 SCREW-with lock washer 2 <> 08360-51014 10 08915-43510 WASHER-plain 2
Sedan
1 78100-H1900 ASSY-FENDER REAR RH SEDAN 2 78101-H1900 ASSY-FENDER REAR LH SEDAN 3 78120-H1000 ASSY-DRIP REAR FENDER RH SEDAN 4 78121-H1000 ASSY-DRIP REAR FENDER LH SEDAN 5 76612-H1250 ASSY-AIR BOX REAR PILLER RH SEDAN 2 DOOR 6 76613-H1250 ASSY-AIR BOX REAR PILLER LH SEDAN 2 DOOR 7 78135-H1000 ASSY-COVER GAS FILLER SEDAN 8 79100-H1901 ASSY-PANEL REAR SEDAN 8 79100-H7000 ASSY-PANEL REAR SEDAN 0772- 9 79121-H1001 REINF-REAR PANEL SEDAN 10 79111-H1000 PANEL-REAR WAIST SEDAN 11 79420-H1000 ASSY-PANEL PARCEL SHELF SEDAN 12 79430-H1001 ASSY-SUPPORT REAR SEAT BACK RH SEDAN 13 79431-H1001 ASSY-SUPPORT SEAT BACK LH SEDAN 14 79434-H1000 BRACE-REAR SEAT BACK (2) SEDAN 15 78130-H1000 ASSY-GAS FILLER LID SEDAN 16 77760-89902 BUMPER-RUBBER GAS FILLER LID SEDAN 17 79910-H7000 ASSY-PARCEL SHELF SEDAN 0772- 17 79910-H1001 ASSY-PARCEL SHELF SEDAN 18 76906-G0511 CLIP-PARCEL SHELF 1 (10) SEDAN 18 01553-00051 CLIP-PARCEL SHELF 1 (10) SEDAN 19 79911-H1000 COVER-PARCEL SHELF SEDAN 20 79912-H1000 PLUG-PARCEL SHELF SEDAN
Coupe
1 78110-H1955 ASSY-FENDER REAR RH COUPE 2 78110-H1905 1 78110-H1956 ASSY-FENDER REAR RH COUPE 0172- 2 78110-H1955 1 78110-H1905 ASSY-FENDER REAR RH COUPE 2 78111-H1955 ASSY-FENDER REAR LH COUPE 2 78111-H1905 2 78111-H1956 ASSY-FENDER REAR LH COUPE 0171- 2 78111-H1955 2 78111-H1905 ASSY-FENDER REAR LH COUPE 3 78120-H1800 ASSY-DRIP FENDER REAR RH COUPE 4 78121-H1800 ASSY-DRIP FENDER REAR LH COUPE 5 78135-H1800 ASSY-COVER GAS FILLER COUPE 6 76500-H7100 ASSY-PILLAR LOCK RH WITH PATCH COUPE 2 76500-H1809 6 76500-H1850 ASSY-PILLAR LOCK RH WITH PATCH COUPE 6 76500-H1809 ASSY-PILLER LOCK RH WITH PATCH COUPE 2 76500-H1850 7 76501-H7100 ASSY-PILLAR LOCK LH WITH PATCH COUPE 2 76501-H1809 7 76501-H1850 ASSY-PILLAR LOCK LH WITH PATCH COUPE 7 76501-H1809 ASSY-PILLAR LOCK LH WITH PATCH COUPE 2 76501-H1850 8 78124-H1800 PANEL-AIR DUCT SIDE RH COUPE 9 78125-H1800 PANEL-AIR DUCT SIDE LH COUPE 10 79100-H1905 ASSY-PANEL REAR COUPE 11 79120-H1800 ASSY-REINF REAR PANEL COUPE 12 96224-H1800 BRACKET-REAR LICENCE PLATE COUPE 13 79312-H1800 PANEL-REAR WAIST OUTER COUPE 14 79314-H1800 PANEL-REAR WAIST INNER COUPE 15 78130-H1800 ASSY-LID GAS FILLER (2) COUPE 16 77760-89902 BUMPER-RUBBER GAS FILLER LID (2) COUPE 17 08310-51012 SCREW-MACHINE M5 FIX LID (2) COUPE 18 78843-H2225 SET-GRILLE AIR OUTLET UPPER (2) COUPE 19 78844-H2225 SET-GRILLE AIR OUTLET LOWER (2) COUPE 20 08961-44810 PUSH (4) COUPE 21 08915-43410 WASHER-PLAIN (8) COUPE 22 08915-13410 WASHER-SPRING (8) COUPE 23 08911-10410 NUT-HEX (8) COUPE 24 74993-73000 PLUG-REAR FENDER (2) COUPE
