Also see:
Part Numbers Index Main article for usage, photos, cross-reference Automatic Transmission
1 31411-X0100 SHAFT-INPUT 3N71B 2 31440-X0100 ASSY-CARRIER,REAR PLANET 3N71B 3 31436-X0100 RACE-BEARING,NEEDLE THRUST 3N71B 4 31435-X0100 BEARING-NEEDLE THRUST (5070) 3N71B 5 31477-X0100 RING-SNAP (116B) 3N71B 6 31460-X0100 ASSY-GEAR,SUN 3N71B 7 31465-X0100 SHELL-CONNECTING 3N71B 8 31466-X0100 RACE-BEARING,CONNECTING SHELL 3N71B 9 31467-X0100 RING-SNAP (47S) (2) 3N71B 10 31420-X0100 ASSY-CARRIER,FRONT PLANET 3N71B 11 31428-X0100 BEARING-NEEDLE THRUST (3047) 3N71B 12 31436-X0100 RACE-BEARING,PLANET CARRIER 3N71B 13 31431-X0100 GEAR-INTERNAL 3N71B 14 31553-X0100 HUB-REAR CLUTCH 3N71B 15 31433-X0100 RING-SNAP (99B) 3N71B 16 31435-X0100 BEARING-NEEDLE THRUST (5070) 3N71B 17 31438-X0100 BEARING-NEEDLE THRUST (3553) 3N71B 18 31431-X0100 GEAR-INTERNAL 3N71B 19 31452-X0100 FLANGE-INTERNAL DRIVE 3N71B 20 31433-X0100 RING-SNAP (99B) 3N71B 21 31428-X0100 BEARING-NEEDLE THRUST (3047) 3N71B 22 31435-X0100 BEARING-NEEDLE THRUST (5070) 3N71B 23 00922-12800 RING-SNAP (28) 3N71B 24 31471-X0100 DRUM-CONNECTING 3N71B 25 31475-X0100 RACE-OUTER,ONE WAY CLUTCH 3N71B 26 31476-X0100 RING-SNAP (92B) 3N71B 27 31473-X0100 ASSY-CLUTCH,ONE WAY 3N71B 28 31479-X0100 RING-SNAP (71B) (2) 3N71B 29 31376-X0100 RING-SNAP (134) 3N71B 30 31667-X0104 PLATE-RETAINING, T=16.6 3N71B 30 31667-X0105 PLATE-RETAINING, T=16.8 3N71B 30 31667-X0103 PLATE-RETAINING, T=16.4 3N71B 30 31667-X0102 PLATE-RETAINING, T=16.2 3N71B 30 31667-X0101 PLATE-RETAINING, T=16.0 3N71B 30 31667-X0100 PLATE-RETAINING, T=15.8 3N71B 31 31662-X0100 ASSY-PLATE,ORIVE (130) (3) 3N71B 32 31666-X0100 PLATE-DRIVEN (130) 3N71B 33 31668-X0100 PLATE-DISHED (130) 3N71B 34 31652-X0101 RING-SNAP (56S) 3N71B 35 31651-X0100 SPRING-PISTON RETURN 3N71B 35 31651-X0101 SPRING-PISTON RETURN 3N71B 2 31651-X0100 36 31648-X0100 RING-THRUST SPRING 3N71B 37 31647-X0100 SEAL-O RING (56D) 3N71B 38 31646-X0100 SEAL-LATHE CUT RING (132D) 3N71B 39 31645-X0100 PISTON-LOW & REVERSE BRAKE 3N71B 40 31438-X0100 BEARING-NEEDLE THRUST (3553) 3N71B 41 31489-X0100 RACE-BEARING,DISTRIBUTOR 3N71B 42 31480-X0100 ASSY-SHAFT,OUTPUT 3N71B 43 31486-X0100 ASSY-DISTRIBUTOR,OIL 3N71B 44 31487-X0100 RING-SEAL (62) (3) 3N71B 45 31860-X0410 ASSY-GOVERNOR 3N71B 46 31862-X0100 VALVE-PRIMARY GOVERNOR 3N71B 47 31863-X0100 SPRING-PRIMARY GOVERNOR 3N71B 48 31872-X0410 VALVE-SECONDARY GOVERNOR (35) 3N71B 49 31873-X0100 SPRING-SECONDARY GOVERNOR 3N71B 50 31864-X0100 PLATE-RETAINER (3) 3N71B 51 08160-61610 BOLT (4) 3N71B
