Brake Piping Part Numbers
Revision as of 05:22, 17 June 2012; view current revision
Categories: Brake System | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Brake Piping
1 46223-H1901 ASSY-TUBE BRAKE MASTER CYL. FR(TANDEM)TO OP 2 46223-H1900
1 46223-H3900 ASSY-TUBE,B/MASTER CYL.FR (TANDEM) TO 1071-0473 30 46223-H1901
1 46223-H3901 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 0573- 2 46223-H3900
1 46223-G1300 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 0573- 46223-H3901
1 46223-H1900 ASSY-TUBE BRAKE MASTER CYL FR(TANDEM)TO
2 46224-H3901 ASSY-TUBE,B/MASTER CYL. RR (TANDEM) TO 0573- 2 46224-H3900
2 46224-H1900 ASSY-TUBE BRAKE MASTER CYL RR(TANDEM)TO
2 46224-H1901 ASSY-TUBE BRAKE MASTER CYL. RR(TANDEM)TO OP 1170- 2 46224-H1900
2 46224-H3900 ASSY-TUBE,B/MASTER CYL.RR (TANDEM) TO 1071-0473 30 46224-H1901
3 46100-26100 ASSY-SWITCH BRAKE INDICATOR
3 46100-U5200 ASSY-SWITCH BRAKE INDICATOR 1071-0473 32 46100-26100
4 08360-63514 SCREW-MACHINE WITH WASHER
5 46240-H1900 ASSY-TUBE BRAKE FRONT RH FOR TANDEM B -473 3
5 46240-H1901 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 0573- 2 46240-H1900
5 46240-G1300 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 0573- 2 46240-H1901
6 46242-H1900 ASSY-TUBE BRAKE FRONT LH FOR TANDEM B -473 3
6 46242-H1901 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 0573- 2 46242-H1900
6 46242-G1300 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 0573- 2 46242-H1901
7 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL 0573- 2 46280-H1901
7 46280-H1905 ASSY-TUBE CONNECTOR TO REAR AUTOMATIC
7 46280-H1906 ASSY-TUBE CONNECTOR TO REAR AUTOMATIC 46280-H1905
7 46280-H1901 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL -473 3
7 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL -473 3 46280-H1901
8 46313-18000 CONNECTOR-3WAY REAR
8 02463-13200 CONNECTOR-3WAY REAR 46313-18000
9 08110-82562 BOLT-HEX WITH WASHER M8
10 46290-H5501 ASSY-TUBE REAR BRAKE RH COUPE 0673- 5 46290-H1001
10 46290-H7301 ASSY-TUBE REAR BRAKE RH COUPE 0673- 5 46290-H5501
10 46290-H1000 ASSY-TUBE REAR BRAKE RH SEDAN COUPE -473 3
10 46290-H1001 ASSY-TUBE REAR BRAKE RH SEDAN COUPE 0573- 2 46290-H1000
10 46290-H5001 ASSY-TUBE REAR BRAKE RH SEDAN 0673-0473 35 46290-H1001
10 46290-H7201 ASSY-TUBE REAR BRAKE RH SEDAN 0673-0473 35 46290-H5001
11 46310-H5501 ASSY-TUBE REAR BRAKE LH COUPE 0673- 5 46310-H1001
11 46310-H5001 ASSY-TUBE REAR BRAKE LH SEDAN 0673-0672 25 46290-H1001
11 46310-H1000 ASSY-TUBE REAR BRAKE LH SEDAN COUPE -473 3
11 46310-H1001 ASSY-TUBE REAR BRAKE LH SEDAN COUPE 0573- 2 46310-H1000
12 46201-89918 ASSY-HOSE BRAKE REAR L=330
12 46201-H7200 ASSY-HOSE BRAKE REAR L=330 46201-89918
13 46237-18000 GASKET-BRAKE HOSE TO TUBE
14 46205-61000 PLATE-LOCK BRAKE HOSE
15 46206-18000 SPRING-LOCK BRAKE HOSE
