Synchros
4-speed and 5-speed synchronizers are very different. 4-speed uses synchro baulk rings. 5-speed has baulk nubs on the hub itself.
4-SPEED EARLY
- 32601-18000 HUB-SYNCHRONIZER 1 4 SPEED $78 USD
- 32604-H1000 BAULK RING
- 32606-18000 SLEEVE-COUPLING $52 USD
4-SPEED LATE
- 32601-H7301 HUB-SYNCHRONIZER, 1ST & 2ND, 3RD & 4TH $83 USD
- same as 60-series transmission 4-speed & 5-speed (1st & 2nd only)
- 32604-H9000 BAULK RING $44 USD
- also replaces ealier 32604-H1000
Coupling with hub. Left: assembled. Right: not assembled
5-SPEED 32601-H7200 HUB-SYNCHRONIZER, 2nd & 3rd, 4th & 5th 5-speed 32606-H7200 SLEEVE-coupling
Case
The case is the front part of the transmission (the "bell housing"). The case for 4-speed and 5-speed looks the same, but has different part numbers. Note that different years and different markets added changes to the case.
RHD (JDM Catalog)
- 32100-18000 CASE-transmission 4-speed B10
- bell-crank clutch linkage
- 32100-H1000 CASE-transmission 4-speed B110 (56L)
- 32100-H7230 CASE-transmission 5-speed B110 GX-5
- 32100-G1030 CASE COMP.-transmission B120 (56A)
- 32100-H5035 CASE-transmission 4-speed B210 1975
- 32100-H5030 CASE-transmission 4-speed B210 (from 7503)
- 32100-H7421 CASE-transmission 4-speed B210, B310 1976-
- 32100-G1123 CASE-transmission 4-speed B120 SB 7510-
- 32100-G1124 CASE-transmission 4-speed B120 LB 7510-
LHD (USA catalog)
- 32100-H1600 CASE-transmission 4-speed B110 LHD to 0970
- 32100-H1630 CASE-transmission 4-speed B110 LHD from 1070-
- 32101-H3900 CASE-transmission 4-speed B110 LHD from 0671-
- 32101-H3930 CASE-transmission 4-speed B110 LHD from 0172-
- 32100-H6200, 32100-H6201 CASE-transmission 4-speed B210 LHD to 0874 (A13 engine)
- 32100-H6127 CASE-transmission 4-speed B210 LHD USA
- 32100-H8511, 32100-H8529 CASE-transmission 4-speed B210 LHD CANADA
- Has an electrical switch in case (reverse)
Extension
variations:
- double-mount with top switch drilled & tapped (8910-)
- double-mount w/o top switch (? B310?)
- 56L with bushing & small oil seal (B110 early)
- 56L with large oil seal (B110 late)
- 56A with internal w/o oil dam (early B120???)
- 56A with internal oil dam
F4W56
- 32010-H1652 ASSY-TRANSMISSION(F4W56)
- 32010-H3551 ASSY-TRANSMISSION (F4W56) 0972-
- replaces 32010-H1652
- 32010-H3950 ASSY-TRANSMISSION(F4W56E) 0671-
- 32010-H3951 ASSY-TRANSMISSION (F4W56L) 0172-
- 32010-H3953 ASSY-TRANSMISSION (F4W56L) 0972-0373
- replaces 32010-H3951
- 32010-H3963 ASSY-TRANSMISSION (F4W56A) 0473-
- replaces 32010-H3953
- SKF Seal 99098 SKF Part # 99098
Reverse Lamp Switch
Counter Gear
Cluster Gear
- 32210-24900 GEAR-COUNTER 29T,25T,19T,13T B10, -0373 B110 (F4W56L)
- 32210-G1100 GEAR-COUNTER 29T,25T,19T,13T B120 ALL, CAR 0473-0874 (F4W56A)
- USA B110, starting April 1973
- Used through 1982 (listed for A12-powered B210 & B310)
Counter Gear Bearings
http://www.rockauto.com/catalog/x,carcode,1208483,parttype,8688
56L Front Countershaft Bearing
- Timkin 305AG (F4W56L)
- also fits Center F4W71B, Rear R4W71A
- National 305 (Aichi F4W56L) $24.89
- Ball Bearing
- Outer Race Radius=0.0402"
- Bore=0.9843"
- Outer Diameter=2.4409"
- Width=0.6693"
- Inner Race Radius=0.0402"
56A Front Countershaft Bearing
- Nissan 32219-H7300
- Timkin 304WB (F4W56A)
- also fits F4W71B front, F4W71A front
- Cone Bearing
- Bore=0.787"
- Outer Diameter=2.047"
- Width=0.591"
Rear Countershaft Bearing
- 32223-24900 BEARING-ball counter
- Timking 303SS (F4W56L)
- National/BCA 303SS (Aichi F4W56L)
- Ball Bearing
- Bore=0.6693"
- Outer Diameter=1.8504"
- Width=0.5512"
- Timkin 205BB (F4W56A) $13.00
- Ball Bearing
- Width: 0.5906"
- Bore=0.9843"
- Outer Diameter=2.0472"
Input Shaft Bearing
http://www.rockauto.com/catalog/x,carcode,1208483,parttype,8708
Main Drive Gear Ball Bearing (input shaft)
- 32203-18000 BEARING-ball, main drive gear
- superceded by 32203-E9800 $25.45 USD
Main Shaft Bearing
56L Main Shaft Ball Bearing
- 32273-24900 BEARING-main shaft
- SKF 6305J
- Timkin 305L Front; F4W56L $27.79
- National 305L Aichi F4W56L
- Ball Bearing
- Bore=0.9843"
- Width=0.6693"
56A Main Shaft Ball Bearing
- 32273-G1000 BEARING-ball, main shaft
- Timkin 306L Front; F4W56A, Front; R4W71A
- Ball Bearing
- Bore=1.1811"
- Outer Diameter=2.8346"
- Width=0.748"
Input Shaft Seal
- http://www.rockauto.com/catalog/x,carcode,1208483,parttype,10065
- Timkin 222540 F4W56L, F4W56A $2.84
- National 710316 F4W56L
- Oil Seal: Nitrile
- Shaft Size=0.984"
- Housing Bore=1.575"
- Outer Diameter=1.583"
- Width=0.315"
- Timkin 710417 F4W63, F4W63A, F4W63L
- Timkin 1981 R4W71A
- Timkin KWK99098 Kwik Sleeve repair F4W56L, F4W56A
- National/BCA 99098 Redi-Sleeve $27.79
- .982" x .986" x .313"
Main Shaft
- SKF 6305J Main Shaft Bearing $24.79
Output Shaft
Bearing
- TIMKEN 306L F4W63, F4W63A, F4W63L, F4W71B, R4W71A $27.79
- TIMKEN 305L F4W56A, F4W56L, F4W60, F4W60L, F4WF60, F4WF60L
- National/BCA 305L Aichi F4W56L $36.79
- http://www.rockauto.com/catalog/x,carcode,1208483,parttype,8728
Seal
- TIMKEN 3771 F4W63, F4W63A, F4W63L, F4W71B, R4W71A $4.04
- TIMKEN 2016 F4W56A, F4W56L, F4W60, F4W60L, F4WF60, F4WF60L $11.04
- NATIONAL 2016 Aichi F4W56L $15.87
- Oil Seal: Nitrile
- Shaft Size=1.181"
- Housing Bore=1.772"
- Outer Diameter=1.78"
- Width=0.591"
F5C56
Counter Gear
- 32213-H7200 GEAR-counter B110
- 32213-H7201 GEAR-counter B210
- 32210-H7200 GEAR-1st counter
Nissan Competition
- 32010-H7251 TRANSMISSION ASSY B110 GX-5
- 32010-H7251P TRANSMISSION ASSY Nissan Competition OPT 1
- 32010-H7220N TRANSMISSION ASSY Nissan Competition OPT 2
- 32010-H5250 TRANSMISSION ASSY B210 GFK
- 32010-H5250 TRANSMISSION ASSY B210 GFK from 73-10
- 32010-H5251 TRANSMISSION ASSY B210 GFK ratiol tire
- 32010-H5253 TRANSMISSION ASSY B210 GFK from 73-10 ratiol tire
Uncategorized Nissan Parts List
B110 Gearset, 4-speed
- B110 4spd 32280-G1100 ASSY-GEAR REVERSE IDLER 17T 1 4 SPEED 0473-
- B110 4spd 32283-G1100 BUSH-GEAR REVERSE IDLER 1 4 SPEED 0473-
- B110 4spd 32281-G1100 SHAFT-REVERSE IDLER 1 4 SPEED 0473-
- B110 4spd 32285-18000 RING-SNAP REVERSE IDLER 1 4 SPEED 0473-
- B110 4spd 32210-G1100 GEAR-COUNTER 29T,25T,19T,13T 1 4 SPEED 0473-
- B110 4spd 32223-24900 BEARING-BALL COUNTER SHAFT 1 4 SPEED 0473-
- B110 4spd 32220-G1100 GEAR-REVERSE COUNTER 13T 1 4 SPEED 0473-
- B110 4spd 00922-11700 RING-SNAP 1 4 SPEED 0473-
- B110 4spd 32219-G1000 BEARING-NEEDLE COUNTER SHAFT 1 4 SPEED 0473-
- B110 4spd 32224-H7201 WASHER-THRUST COUNTER BEARING T=2. 0 4 SPEED 0673- 2
- B110 4spd 32224-H7205 WASHER-THRUST COUNTER BEARING T=2. 0 4 SPEED 0673- 2
- B110 4spd 32224-G1005 WASHER-THRUST COUNTER BEARING T=2. 0 4 SPEED 0473-0573 3
- B110 4spd 32224-H7204 WASHER-THRUST COUNTER BEARING T=2 0 4 SPEED 0673- 2
- B110 4spd 32224-G1004 WASHER-THRUST COUNTER BEARING T=2 0 4 SPEED 0473-0573 3
- B110 4spd 32224-H7203 WASHER-THRUST COUNTER BEARING T=2. 0 4 SPEED 0673- 2
- B110 4spd 32224-G1003 WASHER-THRUST COUNTER BEARING T=2. 0 4 SPEED 0473-0573 3
- B110 4spd 32224-G1002 WASHER-THRUST COUNTER BEARING T=2. 0 4 SPEED 0473-0573 3
- B110 4spd 32224-G1001 WASHER-THRUST COUNTER BEARING T=2. 0 4 SPEED 0473-0573 3
- B110 4spd 32224-H7200 WASHER-THRUST COUNTER BEARING T=2. 0 4 SPEED 0673- 2
- B110 4spd 32224-G1000 WASHER-THRUST COUNTER BEARING T=2. 0 4 SPEED 0473-0573 3
- B110 4spd 32224-H7202 WASHER-THRUST COUNTER BEARING T=2. 0 4 SPEED 0673- 2
- B110 4spd 32200-G1000 ASSY-GEAR MAIN DRIVE 19T,30T 1 4 SPEED -
- B110 4spd 32203-18000 BEARING-BALL MAIN SHAFT 1 4 SPEED 0473-
- B110 4spd 32205-18000 WASHER-THRUST MAIN DRIVE GEAR 1 4 SPEED 0473-
- B110 4spd 32204-18000 RING-SNAP MAIN DRIVE GEAR 1 4 SPEED 0473-
- B110 4spd 32241-G1101 SHAFT-MAIN 1 4 SPEED 0473-
- B110 4spd 32246-G1000 WASHER-THRUST MAIN SHAFT 1 4 SPEED 0473-
- B110 4spd 32253-18000 BUSH-MAIN SHAFT REVERSE GEAR 1 4 SPEED 0473-
- B110 4spd 32264-18000 BEARING-NEEDLE MAIN SHAFT 1 4 SPEED 0473-
- B110 4spd 32230-G1100 ASSY-GEAR 1ST SPEED 1 4 SPEED 0473-
- B110 4spd 32604-H1000 RING-BAULK 2 4 SPEED 0473-
- B110 4spd 32604-H1010 RING-BAULK 2 4 SPEED 0473-0573 32
- B110 4spd 32609-18000 INSERT-SHIFTING 3 4 SPEED 0473-
- B110 4spd 32603-18000 SPRING-SYNCHRONIZER 2 4 SPEED 0473-
- B110 4spd 32601-18000 HUB-SYNCHRONIZER 1 4 SPEED 0473-
- B110 4spd 32606-18000 SLEEVE-COUPLING 1 4 SPEED 0473-
- B110 4spd 32264-24900 BEARING-NEEDLE MAIN SHAFT 2 4 SPEED 0473-
- B110 4spd 32250-G1100 ASSY-GEAR 2ND SPEED 1 4 SPEED -
- B110 4spd 32260-G1100 ASSY-GEAR 3RD SPEED 1 4 SPEED 0473-
- B110 4spd 32604-H1010 RING-BAULK 2 4 SPEED 0673- 2
- B110 4spd 32603-18000 SPRING-SYNCHRONIZER 2 4 SPEED -
- B110 4spd 32601-18000 HUB-SYNCHRONIZER 1 4 SPEED -
- B110 4spd 32606-18000 SLEEVE-COUPLING 1 4 SPEED -
- B110 4spd 32265-18000 WASHER-THRUST SYNCHRONIZER HUB 1 4 SPEED 0473-
- B110 4spd 32265-H7200 WASHER-THRUST SYNCHRONIZER HUB 1 4 SPEED 0473- 2
- B110 4spd 32720-14600 BALL-STEEL 1 4 SPEED 0473-
- B110 4spd 32272-18000 BEARING-PILOT MAIN SHAFT 1 4 SPEED 0473-
- B110 4spd 32273-G1000 BEARING-BALL MAIN SHAFT 1 4 SPEED 0473-
- B110 4spd 32205-18000 WASHER-MAIN BEARING 1 4 SPEED 0473-
- B110 4spd 32204-18000 RING-SNAP MAIN SHAFT 1 4 SPEED 0473-
- B110 4spd 32245-G1100 GEAR-REVERSE MAIN SHAFT 1 4 SPEED 0473-
