Main : Misc : Tech Section F5C56 5-speed gearset
[<   Previous  126  127  128  129  130  131  132  Next   >]
F5C56 5-speed gearsetPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2015/10/13 3:48    Tell a friendTell a friend
Hits3188  Comments2    0.00 (0 votes)0.00 (0 votes)
This 5-speed has:
* no overdrive
* 4th is regular meshed gears
* 5th is direct drive
* "Nn" is the input gear pair
.. n: main drive gear
.. N: counter driven gear
Dodgeman
Posted: 2008/12/15 0:45  Updated: 2008/12/15 0:45
 Re: F5C56 5-speed gearset
Fifth gear is direct drive. First gear is in the extention housing with reverse.
Input shaft [17] is coupled direct to the main shaft [57] via the locking collar & synchro hub [58 & 59] when 5th is selected.
The gears numbered [5] on the input shaft, & [5] on the cluster are the constant mesh, or primary drive. This simply provides drive to the cluster.
All of the intermediate forward gears are constantly in mesh & are coupled to the mainshaft when required via the synchro hubs & collars.
