L, Z, KA and SR all use the same crossmember mount points. You can use the stock B110 L-series crossmember or an A-series crossmember modified.
Or, use the unmodified A-series crossmember with custom engine-side brackets.
Stock
Factory crossmember from L14-powered B110:
- 54401-H2500 MEMBER ASS'Y-cross, front suspension
- 54401-H2501 MEMBER ASS'Y-cross, front suspension (from '71-7)
- 81-34028-1 BOLT (4)
- 89-12340-1 NUT (4)
- 54408-21000 WASHER-plain
- 54408-U0100 WASHER-plain (from '71-7)
- 54407-21000 WASHER-plain
- 11220-A3500 INSULATOR-engine mounting (2)
- 11230-A3500 BRACKET ASS'Y-engine mounting front (R.H.)
- 11233-A3500 BRACKET ASS'Y-engine mounting front (L.H.)
- Uses Datsun 510 Transverse Links
- 54529-A0800 LINK ASS'Y-transverse, front suspension (R.H.)
- 54529-U0102 LINK ASS'Y-transverse, front suspension (R.H.)
- 54530-A0800 LINK ASS'Y-transverse, front suspension (L.H.)
- 54530-U0102 LINK ASS'Y-transverse, front suspension (L.H.)
Custom Crossmember
You can modify the 1200 crossmember: Have the mounts trimmed to an angle simular to that of a 200B, then cut the 200B mounts in 1/2 to finish the job and locate the motor lower and improve the mounting angles. A 910 Bluebird L20B sump fits almost perfect, reshape it with a hammer a little just so it will clear the 1200 crossmember, maybe 1/2cm.
If using other sumps, you may need to do the following:
- Remove notch from Datsun 1200 xmember
- Reshape sump to clear the drag link
NOTE: These do not fit a 1200:
- Stanza/510 A10 crossmember
- 120Y B210 crossmember
- 510 crossmember
Motor Mount Isolators
The engine mount Brackets and rubber Isolators you use depends on which crossmember you use.
Stock PB110 or 510 type
- 11220-A3500 INSULATOR-engine mounting (2) $34 USD
- 11230-A3500 BRACKET ASS'Y-engine mounting front (R.H.) $48 USD
- 11233-A3500 BRACKET ASS'Y-engine mounting front (L.H.) $48 USD
$14 at RockAuto.com http://www.rockauto.com/catalog/x,carcode,1209989,parttype,5552
510 specs (L13 uses a softer LH mount than L16):
- 11220-21004 INSULATOR LH L13
- 11220-22000 INSULATOR LH L13, RH ALL
- 11220-A3500 INSULATOR ENGINE MTG FRONT (2)
- supercedes 11220-22000
A10 (1978-1981 510) uses double-stud type: $14 at RockAuto.com
620 with L-series engine:
- 11220-B7900 INSULATOR-ENGINE MOUNTING FRONT (2) 1073-0874
- supercedes 11220-B2000 -0973
- 11220-B8000 INSULATOR-ENGINE MOUNTING FRONT RH 0974-
- 11221-B8000 INSULATOR-ENGINE MOUNTING FRONT LH 0974-
620 1973-1974 triple stud type, $5 at RockAuto http://www.rockauto.com/catalog/x,carcode,1210105,parttype,5552
620 1975-1978 single-stud type $3 to $14 at RockAuto.com http://www.rockauto.com/catalog/x,carcode,1210127,parttype,5552
These look the same as 510 isolators, but are likely a harder rubber.
