GL and GX trim Datsun 1200s used illuminated electrical switch knobs. In 1973 all USA 1200s adopted the illuminated knobs. B210 also used this as standard fitment in Japan and USA.
A variable knob was turned to progressively dim the lamps.
H70 Type: Green knobs with words and illumination.
* Wipe Wash knob * Heater Control knob * Cigar Lighter knob * Auto-trans shift indicator lamp
From 1976 * Clock lamp * Radio lamp
Control Switch
A resistor rheostat was used through 1976. This produced significant heat.
This switch went in-between the lamps and Earth/Ground (B wire).
For 1977 a new active semiconductor rheostat was introduced, which required a 12V IGN feed, but is otherwise wired the same.
Resistor Rheostat B: Earth/Ground (notched side of connector) RL: to lamps![]()
Semiconductor Rheostat - Illumination Control B: Earth/Ground GW: to lamps & Lighting Switch from Fuse Box (RG) GY: to lamps![]()
Pin-Out
Australia
Australia 1200s use a two-position bright/dim switch built into the Lighting Switch. It is not a rheostat (variable). The knob is twisted (rotated) to use either bright or dim position.
See Wiring Diagrams
