Engine Gasket Kit Part Numbers
Revision as of 23:56, 2 November 2012; view current revision
Categories: Engine Mechanical | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Engine Gasket Kit
Truck
11011K GASKET KIT-ENGINE REPAIR
 10101-H1025 GASKET KIT-engine
 10101-H1026 GASKET KIT-engine (from '72-6) > 10101-H1025
 10101-H1027 GASKET KIT-engine (from '73-6) <> 10101-H1025
 10101-H3928 7510-7907 <2,0> 10101-M9025
 10101-M9025 7908-8503
 10101-G1925 8504-8910
 10101-G6126 8910-
11042K
 11042-G6126 GASKET KIT-VALVE REGRIND 8910-
1974 catalog
11044-H1000  GASKET-cylinder head
11044-H1001  GASKET-cylinder head (from '72-6) <x> 11044-H1000
11045-H1000  RING "O" (from '72-6)
11062-18000  WASHER-joint, water outlet
11130-18002  SEAL-oil, oil pan, front
11131-18002  SEAL-oil, oil pan, rear
11132-18001  GASKET-oil pan (R.H.)
11133-18001  GASKET-oil pan (L.H.)
12279-H1000  SEAL-oil, crank shaft, rear
13510-H1000  SEAL-oil, crank shaft, front
13044-18001  GASKET-cover, timing chain
13219-H1000  SHROUD-valve inner (from '73-5) 8
13207-18000  SEAL-oil, valve (up to '72-5) 8
13270-18001  PACKING-rocker cover
14035-18000  GASKET-manifold, cylinder block
15053-18000  GASKET-oil strainer
17099-21002  PACKING-fuel pump 2
21014-18000  GASKET-water pump
15066-18000  GASKET-oil pump
22180-71200  O RING-distributor support (from '73-5)
10101-H3927 KIT-GASKET ENGINE A12 0673- 2 10101-H3926
10101-H3926 KIT-GASKET ENGINE A12 0672- 2 10101-H3925
10101-H3925 KIT-GASKET ENGINE A12 0671- 0 10101-H1025
10101-H1025 KIT-GASKET ENGINE A12 2 10101-18027
10101-18027 KIT-GASKET ENGINE A12
11042-H3927 KIT-GASKET VALVE REGRINED A12 0673- 2 11042-H3926
11042-H3926 KIT-GASKET VALVE REGRINED A12 0672- 2 11042-H3925
11042-H3925 KIT-GASKET VALVE REGRINED A12 0671- 0 11042-H1025
11042-H1025 KIT-GASKET VALVE REGRINED A12 2 11042-18026
11042-18026 KIT-GASKET VALVE REGRINED A12
