You can add rear disc brakes to H145 with a Australia-built R31 Skyline/Pintara setup. It will also fit H150. Fits over 13" steel wheels.
Click each photo to read the comments and find more detail.
Use a brake proportioning valve to set the balance. These are large rear brakes.
Modified caliper bracket to fit H145
Holes re-drilled for H145 housing pattern
Fitted the calipers facing forward as you can then run the cables back and loop around and utilise the existing hand brake bracket and cabling on the diff.
