« 1 ... 24 25 26 (27) 28 29 30 ... 54 »
Re: Leveys 2dr sedan v1.2
From Perth WA AUS
Hehe!
Posted on: 2010/8/22 11:30
Datsun 1200 2Dr sedan.
From mandurah
hhmm nigel how much will it cost me for you to make a heap of flares ,say 2 or 3 sets all around the car ??? pm me if your keen !
Posted on: 2010/8/22 14:51
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
This is my first update for a while I've been very busy at work.
The car is running fine now just needs to get back on the dyno to be tuned properly, fitted a 60 series dogleg 5spd (a few mods needed for that) and also rebuilt my airbox for better clearance to the strut tower and modded it for colder air intake.
Oh and working on a R31 disc brake setup.
Couple of pics:
jpg  Dogleg box fitted.JPG (121.85 KB)
9665_4cf0c96919da4.jpg 980X735 px
jpg  Dogleg box mount.JPG (105.79 KB)
9665_4cf0c97c3f088.jpg 980X735 px
jpg  Dogleg box mount rear.JPG (117.50 KB)
9665_4cf0c98b46e65.jpg 980X735 px
jpg  Cold airbox.JPG (125.24 KB)
9665_4cf0ca242237e.jpg 980X735 px
jpg  Rear dicss.JPG (109.00 KB)
9665_4cf0ca67db5f0.jpg 980X735 px
Posted on: 2010/11/27 9:09
good stuff, but why not ship them over here to melbourne where someone can use them?
Posted on: 2010/11/27 10:09
From Perth WA AUS
Who would that be?
Theres a brake setup on Gumtree for about $90.
Posted on: 2010/11/27 10:47
From Sydney
If you plan to run your calipers rear facing (as mocked up in the pic) you will run in to dramas when you try to set up your hand brake mechanism. ( you'll have to "re invent the wheel" to get the cables to the hand brake lever and you have the added delima of getting the cable around the muffler).
I fitted mine forward facing as you can then run the cables back and loop around and utilise the existing hand brake bracket and cabling on the diff.
I'll take some pic's of mine in the next couple of days so you can see what I mean.
Posted on: 2010/11/27 10:59
From Perth WA AUS
Thanks mattblack I'd appreciate that, any tips etc are allways welcome :)
Posted on: 2010/11/27 12:17
From Townsville, Qld
Ah poo, that mean I'll probly have to change my setup.
Posted on: 2010/11/27 14:21
From Perth WA AUS
I need to get a handbrake cable setup so I can check it out first.
Otherwise rotate the mounting bracket 180 degrees like this:
EDIT: Oh and swap sides with the calipers (not shown in the photo!)
jpg  Rear disc forward caliper.JPG (113.25 KB)
9665_4cf1f6a57c85e.jpg 980X735 px
Posted on: 2010/11/28 0:18
Edited by levey on 2010/11/28 6:29:00
Edited by levey on 2010/11/28 7:47:03
From Sydney
here you go
jpg  IMG_3326.JPG (59.60 KB)
10076_4cf2acdd6c123.jpg 800X533 px
jpg  IMG_3327.JPG (54.79 KB)
10076_4cf2acec2d865.jpg 800X533 px
jpg  IMG_3328.JPG (72.56 KB)
10076_4cf2acfc5bda1.jpg 800X533 px
jpg  IMG_3330.JPG (71.61 KB)
10076_4cf2ad1229ff3.jpg 800X533 px
Posted on: 2010/11/28 19:27
