Pertronix Electronic Ignition
Revision as of 21:07, 13 December 2012; view current revision
Category: Engine Electrical System
The Pertronix Electronic Ignition Retrofit Kit model 1741 fits a stock Datsun 1200 distributor. Moderate cost. It is is points replacment unit, but not a high-energy system.
  • Easy 2-wire hookup, replace points & condensor
  • RPM range: 0 - 15000 RPM (with high performance coil)
  • Sold both in USA and Australia
  • Fits in stock distributor
Retail prices
  • $112.52 USD
  • About $63-78 USD online
  • About 65 + s/h on eBAy
  • Also sold in Australia
StreetSideAuto.com
More information:
Alternatives
Since Pertronix is a low-energy unit (points replacement), you may wish to consider a high-energy system. See Electronic Ignition.
In USA, a complete high-energy system can be had for less money. See B310 Electronic Distributor Swap.
In Japan, the system of choice is the Sunny Truck Electronic Distributor.
Reviews
DimeQuarterly
  • Red wire: 12V +
  • Black wire: Coil -
Distributor Timing
If you removed the distributor to install the Pertronix kit, see How to Install a Distributor on A-series Engine: Installing Distributor
Finally, when you are ready to start the engine you will want to immediate check the timing. See Ignition Timing for the procedure.
