Body Side Part Numbers
Revision as of 05:35, 7 October 2013; view current revision
Categories: Body | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Body Side
ASSY-CENTER PILLER OUTER
RH 76500-H1009 SEDAN 4 DOOR + WAGON 4 DOOR from January 1972
RH 76500-H1000 SEDAN 4 DOOR + WAGON 4 DOOR
LH 76501-H1009 SEDAN 4 DOOR + WAGON 4 DOOR from January 1972
LH 76501-H1000 SEDAN 4 DOOR + WAGON 4 DOOR
ASSY-CENTER PILLER INNER
RH 76522-H1059 SEDAN 4 DOOR + WAGON 4 DOOR from January 1972
RH 76522-H1050 SEDAN 4 DOOR + WAGON 4 DOOR
LH 76523-H1059 SEDAN 4 DOOR + WAGON 4 DOOR from January 1972
LH 76523-H1050 SEDAN 4 DOOR + WAGON 4 DOOR
Truck
Sedan
1 76200-H1000 ASSY-FRONT PILLAR RH SEDAN 2 DOOR
2 76201-H1000 ASSY-FRONT PILLAR LH SEDAN 2 DOOR
3 76230-H1000 ASSY-WINDSHIELD PILLAR INNERRH SEDAN 2 DOOR
4 76231-H1000 ASSY-WINDSHIELD PILLAR INNERLH SEDAN 2 DOOR
5 64118-H1000 REINF-HOODLEDGE,UPPER,RH SEDAN 2 DOOR 0970-
5 64120-H1000 REINF-HOODLEDGE,UPPER,RH SEDAN 2 DOOR
6 64121-H1000 REINF-HOODLEDGE,UPPER,LH SEDAN 2 DOOR
6 64119-H1000 REINF-HOODLEDGE,UPPER,LH SEDAN 2 DOOR 0970-
7 76240-H1600 ASSY-DASH SIDE RH SEDAN 2 DOOR
7 76240-H1000 ASSY-DASH SIDE RH SEDAN 2 DOOR 0171-
8 76241-H1600 ASSY-DASH SIDE LH SEDAN 2 DOOR
8 76241-H1000 ASSY-DASH SIDE LH SEDAN 2 DOOR 0171-
9 76310-H1200 ASSY-RAIL ROOF SIDE OUTER RH SEDAN 2 DOOR
9 76310-H3600 ASSY-RAIL ROOF SIDE OUTER RH SEDAN 2 DOOR 0172-
10 76311-H1200 ASSY-RAIL ROOF SIDE OUTER LH SEDAN 2 DOOR
10 76311-H3600 ASSY-RAIL ROOF SIDE OUTER LH SEDAN 2 DOOR 0172-
11 76322-H1200 PANEL-RAIL ROOF SIDE INNER RH SEDAN 2 DOOR
12 76323-H1200 PANEL-RAIL ROOF SIDE INNER LH SEDAN 2 DOOR
13 76320-H1201 ASSY-PANEL BODY SIDE INNER RH SEDAN 2 DOOR
13 76320-H1209 ASSY-PANEL BODY SIDE INNER RH SEDAN 2 DOOR 0172-
14 76321-H1201 ASSY-PANEL BODY SIDE INNER LH SEDAN 2 DOOR
14 76321-H1209 ASSY-PANEL BODY SIDE INNER LH SEDAN 2 DOOR 0172-
15 76412-H1201 PANEL-SILL OUTER RH SEDAN 2 DOOR
15 76412-H4501 PANEL-SILL OUTER RH SEDAN 2 DOOR 0171-
16 76413-H1201 PANEL-SILL OUTER LH SEDAN 2 DOOR
16 76413-H4501 PANEL-SILL OUTER LH SEDAN 2 DOOR 0171-
17 76500-H1209 ASSY-CENTER PILLER RH SEDAN 2 DOOR 0172-
17 76500-H1200 ASSY-CENTER PILLAR RH SEDAN 2 DOOR
18 76501-H7000 ASSY-CENTER PILLAR LH SEDAN 2 DOOR 0772-
18 76501-H1200 ASSY-CENTER PILLAR LH SEDAN 2 DOOR
18 76501-H1209 ASSY-CENTER PILLAR LH SEDAN 2 DOOR 0172-
19 76712-H1201 PANEL-REAR WHEEL HOUSE OUTERRH SEDAN 2 DOOR
20 76713-H1201 PANEL-REAR WHEEL HOUSE OUTERLH SEDAN 2 DOOR
21 76722-H1000 PANEL-REAR WHEEL HOUSE INNERRH SEDAN 2 DOOR
21 76720-H1000 PANEL-REAR WHEEL HOUSE INNERRH SEDAN 2 DOOR
22 76723-H1000 PANEL-REAR WHEEL HOUSE INNERLH SEDAN 2 DOOR
22 76721-H1000 PANEL-REAR WHEEL HOUSE INNERLH SEDAN 2 DOOR
23 76730-H1000 ASSY-BRACKET SHOCK ABSORBER MOUNTING RH SEDAN 2 DOOR
24 76731-H1000 ASSY-BRACKET SHOCK ABSORBER MOUNTING LH SEDAN 2 DOOR
25 76742-H1000 PLATE-CLOSING SILL REAR RH SEDAN 2 DOOR
26 76743-H1000 PLATE-CLOSING SILL REAR LH SEDAN 2 DOOR
27 74554-H1000 PANEL-T/F SIDE LOWER RH SEDAN 2 DOOR
28 74555-H1000 PANEL-T/F SIDE LOWER LH SEDAN 2 DOOR
Coupe
1 76200-H1800 ASSY-FRONT PILLAR RH COUPE
2 76201-H1800 ASSY-FRONT PILLAR LH COUPE
3 76230-H1800 ASSY-WINDSHIELD PILLAR INNERRH COUPE
4 76231-H1800 ASSY-WINDSHIELD PILLAR INNERLH COUPE
5 64120-H1000 REINF-HOODLEDGE UPPER RH COUPE
5 64118-H1000 REINF-HOODLEDGE UPPER RH COUPE 0970- 2 64120-H1000
6 64121-H1000 REINF-HOODLEDGE UPPER LH COUPE
6 64119-H1000 REINF-HOODLEDGE UPPER LH COUPE 0970- 2 64121-H1000
7 76240-H1000 ASSY-DASH SIDE,RH COUPE
8 76241-H1000 ASSY-DASH SIDE,LH COUPE
9 76312-H1851 ASSY-PANEL ROOF RAIL SIDE OUT RH COUPE
9 76310-H4050 ASSY-RAIL ROOF SIDE OUTER RH COUPE 0172- 2 76312-H1851
10 76313-H1851 ASSY-PANEL ROOF RAIL SIDE OUT LH COUPE
10 76311-H4050 ASSY-RAIL ROOF SIDE OUTER LH COUPE 0172- 2 76313-H1851
11 76322-H1800 PANEL-RAIL ROOF SIDE INNER RH COUPE
12 76323-H1800 PANEL-RAIL ROOF SIDE INNER LH COUPE
13 76320-H1805 ASSY-PANEL BODY SIDE INNER RH COUPE
13 76320-H1855 ASSY-PANEL BODY SIDE INNER RH COUPE 2 76320-H1805
14 76321-H1805 ASSY-PANEL BODY SIDE INNER LH COUPE
14 76321-H1855 ASSY-PANEL BODY SIDE INNER LH COUPE 0970- 2 76321-H1805
15 76412-H1800 PANEL-SILL OUTER RH COUPE
16 76413-H1800 PANEL-SILL OUTER LH COUPE
17 76500-H1809 ASSY-PILLAR LOCK RH COUPE 0172- 2 76500-H1850
17 76500-H7100 ASSY-PILLAR LOCK RH COUPE 0772- 2 76500-H1809
17 76500-H1850 ASSY-PILLAR LOCK RH COUPE
18 76501-H1850 ASSY-PILLAR LOCK LH COUPE
18 76501-H1809 ASSY-PILLAR LOCK LH COUPE 0172- 2 76501-H1850
18 76501-H7100 ASSY-PILLAR LOCK LH COUPE 0772- 2 76501-H1809
19 76720-H1800 ASSY-WHEEL HOUSE INNER REAR RH COUPE
20 76721-H1800 ASSY-WHEEL HOUSE INNER REAR LH COUPE
21 76742-H1800 PLATE-CLOSING SILL REAR RH COUPE
22 76743-H1800 PLATE-CLOSING SILL REAR LH COUPE
23 78120-H1800 ASSY-DRIP FENDER REAR RH COUPE
24 78121-H1800 ASSY-DRIP FENDER REAR LH COUPE
25 76808-H1800 RUBBLER-FINISH LOCK FILLER (2) COUPE
