Synchronizers let you shift gears using the clutch.
Synchro is two cones pressed together until the two shafts run the same speed:
Each gear has a syncho face (external cone) machined with it
The hub is spring loaded so when you move the shifter partway, it presses the baulk ring (internal cone part) against the gear.
When they have slow down to the same speed, the shifter will move all the way in. It happens very quickly, unless the synchros are worn and not working well.
Synchro is basically:
Coupling with hub Baulk rings and gear faces
Coupling with hub. Left: assembled. Right: not assembled
Each synchro set services two gears (arrows). Center arrow points to the Coupling Sleeve
The Coupling Sleeve is what the shifter moves.
The hub is keyed to the mainshaft, so the sleeve rotates constantly in the Shift ForK while the car is moving.
The spring lets the hub move side-to-side inside the Coupling Sleeve, but not move too far. On this one there is a total of about 1/4" (5mm) total movement possible.
56-Series Transmission
FS5C56A 5-speed has very different synchros from other A-series transmissions. It has "C" type synchros (the "C" in FS5C56A) which are very different
4-speed: W56 'W' Warner (Borg Warner) baulk-ring type syncromesh 5-speed: C56 'C' Type Porsche split-ring synchromesh
See Transmission Gear Part Numbers
4-speed F4W56L, F4W56A 32604-H9000 RING-BAULK (4) > 32604-H1000 <> 32604-H1010 32609-18000 INSERT-SHIFTING (6) 32603-18000 SPRING-SYNCHRONIZER (4) 32601-18000 HUB-SYNCHRONIZER (2) 32606-18000 SLEEVE-COUPLING (2)
5-SPEED FS5C56A 32601-H7200 HUB-SYNCHRONIZER (2) 32606-H7200 SLEEVE-coupling (2) 32611-H7200 RING-synchro 32612-H7200 BLOCK-thrust 32613-H7200 BLOCK-anchor 32614-H7200 BAND-brake 22 (2) 32616-H7200 CIRCLIP
Also see 56-Series_Transmission_Parts#Synchros.
32603-18000 SPRING-SYNCHRONIZER * B11/B12/B13/B14 4-speed, 5-speed, E16, SR20DE, GA16DE * B110/B210 4-speed * B210/B310 4-speed, 5-speed * N10/N12/N13 F4, F5 * T11
60-Series Transmission
32604-H9000 RING-BAULK * F4W56A 4-speed light duty (4) * F4W60L 4-speed heavy duty (4) * FS5W60L 5-speed early (5) 32604-H9700 RING-BAULK * FS5W60A 5-speed late (5)
FS5W60L 5-Speed (1979 B310) 32606-18000 SLEEVE-COUPLING 4th-5th, 2nd-3rd NOTE: 1st gear coupling sleeve is built into Reverse Gear 32604-H9000 RING-BAULK 5 32258-H9001 HUB-SYNCHRONIZER 1ST & REVERSE $133.92 USD 32602-32200 SPRING-SYNCHRONIZER 1ST 3 32608-H9000 INSERT-SHIFTING 3 32234-H9000 RETAINER-SHIFTING INSERT 32601-H9001 HUB-SYNCHRONIZER 2ND & 3RD 32603-18000 SPRING-SYNCHRONIZER 2 32609-18000 INSERT-SHIFTING 3 32601-H9000 HUB-SYNCHRONIZER 4TH & 5TH 32603-18000 SPRING-SYNCHRONIZER 2 32609-18000 INSERT-SHIFTING 3
FS5W60A 5-Speed (1980- B310) 32606-18000 SLEEVE-COUPLING 3 32604-H9700 RING-BAULK 5 32601-H7300 HUB-SYNCRO,1ST & 2ND 32609-H9700 INSERT-SHIFTING 3 32603-18000 SPRING-SYNCRO 2 32601-H7301 HUB-SYNCRO,3RD & 4TH 32609-M0102 INSERT-SHIFTING -0780 3 32609-H9700 INSERT-SHIFTING 0880- <0> 32609-M0102 3 32603-18000 SPRING-SYNCRO 2 32601-H9000 HUB-SYNCRO 5TH & REVERSE 32609-H9700 INSERT-SHIFTING 3 32603-18000 SPRING-SYNCRO 2
32602-32200 SPRING-SYNCHRONIZER * B310 1979 5-speed * 71B 5-speed, 4-speed
32609-M0102 INSERT-SHIFTING * B310 1980 5-speed * N10 1979-1981 F4, F5
