Brake Piping Part Numbers
Revision as of 05:20, 23 June 2014; view current revision
Categories: Brake System | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Brake Piping
1971
BRAKE PIPING
1 46223-H1000 ASS'Y-TUBE, brake master cylinder to connector STD,V-Dx
  46223-H1001 ASS'Y-TUBE, brake master cylinder to connector <> 46223-H1000
  46223-H1100 ASS'Y-TUBE, brake master cylinder to connector DX,GL,GX
  46223-H1101 ASS'Y-TUBE, brake master cylinder to connector <> 46223-H1100
  46223-H3200 ASS'Y-TUBE, brake master cylinder to connector (from '71-Sep) DX,GL,GX
2 46234-H1000 CONNECTOR-brake tube (4 way) STD,V-DX
  46234-H1100 CONNECTOR-brake tube (3 way) DX,GL,GX
3   83-60630-14 BOLT
4 46240-H1000 ASS'Y-TUBE, front brake (R.H.)
5 46242-H1001 ASS'Y-TUBE, front brake (L.H.)
6 46202-89913 ASS'Y-HOSE, brake front (l=280) 2
7 46205-61000 PLATE-lock, front hose 4
8 46206-18000 SPRING-lock, front hose 4
9 46245-H1001 ASS'Y-TUBE, wheel cylinder, front (R.H.) (exc. GL,GX)
10 46246-H1001 ASS'Y-TUBE, wheel cylinder, front (L.H.) (exc. GL,GX)
   46245-H1006 ASS'Y-TUBE, wheel cylinder, front disc brake (R.H.) GL,GX
   46246-H1006 ASS'Y-TUBE, wheel cylinder, front disc brake (L.H.) GL,GX
REAR BRAKES
11 46313-18000 CONNECTOR-3 way brake tube
12 46290-H1000 ASS'Y-TUBE, rear brake (R.H.) Sedan
   46290-H1400 ASS'Y-TUBE, rear brake (R.H.) Van, Coupe
13 46310-H1000 ASS'Y-TUBE, rear brake (L.H.) Sedan
   46310-H1400 ASS'Y-TUBE, rear brake (L.H.) Van, Coupe
14 46201-89918 ASS'Y-HOSE, brake rear (l=330)
15 46237-18000 GASKET-brake hose to cylinder
16 46205-61000 PLATE-lock, brake hose
17 40206-18000 SPRING-lock, brake hose
18 46280-H1001 ASS'Y-TUBE, brake master cylinder to rear brake hose STD,V-Dx
   46280-H1101 ASS'Y-TUBE, brake master cylinder to rear brake hose DX <x> 46280-H3200
   46280-H3200 ASS'Y-TUBE, brake master cylinder to rear brake hose DX (from '71-Sep)
   46280-H1105 ASS'Y-TUBE, brake master cylinder to rear brake hose GL,GX <x> 46280-H3210
   46280-H3210 ASS'Y-TUBE, brake master cylinder to rear brake hose GL,GX (from '71-Sep)
19   9-51206   GROMMET-rubber 2
1972
BRAKE PIPING
1 46223-H1001 TUBE-ASS'Y-brake master cylinder to connector (up to '72-7) (Single M/C) STD,V-Dx
  46223-H3200 TUBE-ASS'Y-brake master cylinder to connector (Tandem M/C) DX,GL,GX
  46223-H3201 TUBE-ASS'Y-brake master cylinder to connector (from '72-8) (Tandem M/C) DX,GL,GX > 46223-H3200
2 46234-H1000 CONNECTOR-brake tube (4 way) (up to '72-7) (Single M/C) STD,V-DX
  46234-H1100 CONNECTOR-brake tube (3 way) (Tandem M/C)
3 08360-63014   BOLT
4 46240-H1000 TUBE ASS'Y-front brake (R.H.)
  46240-H1001 TUBE ASS'Y-front brake (R.H.) (from '73-3) > 46240-H1000
5 46242-H1001 TUBE ASS'Y-front brake (L.H.)
  46242-H1002 TUBE ASS'Y-front brake (L.H.) (from '73-3) > 46242-H1001
6 46202-89913 HOSE ASS'Y-brake front (l=280) 2
9 46245-H1001 TUBE ASS'Y-wheel cylinder, front (R.H.) STD,DX <> 46245-H5000
  46245-H5000 TUBE ASS'Y-wheel cylinder, front (R.H.) (from '73-3) STD,DX
10 46246-H1001 TUBE ASS'Y-wheel cylinder, front (L.H.) STD,DX <> 46246-H5000
   46246-H5000 TUBE ASS'Y-wheel cylinder, front (L.H.) (from '73-3) STD,DX
   46245-H1006 TUBE ASS'Y-wheel cylinder, front disc brake (R.H.) GL,GX <> 46245-H5100
   46245-H5100 TUBE ASS'Y-wheel cylinder, front disc brake (R.H.)(from '73-3) GL,GX
12 08110-82562 BOLT
13 46290-H1000 TUBE ASS'Y-rear brake (R.H.) Sedan <> 46290-H5001
   46290-H5001 TUBE ASS'Y-rear brake (R.H.) (from '73-3) Sedan
   46290-H1400 ASS'Y-TUBE, rear brake (R.H.) Van, Coupe < 46290-H1401
   46290-H1401 ASS'Y-TUBE, rear brake (R.H.) Van, Coupe <x> 46290-H5501
   46290-H5501 ASS'Y-TUBE, rear brake (R.H.) (from '73-3) Van, Coupe
14 46310-H1000 TUBE ASS'Y-rear brake (L.H.) Sedan <> 46310-H5001
   46310-H5001 TUBE ASS'Y-rear brake (L.H.) (from '73-3) Sedan
   46310-H1400 ASS'Y-TUBE, rear brake (L.H.) Van, Coupe < 46310-H1401
   46310-H1401 ASS'Y-TUBE, rear brake (L.H.) Van, Coupe <x> 46310-H5501
   46310-H5501 ASS'Y-TUBE, rear brake (L.H.) (from '73-3) Van, Coupe
15 46201-89918 ASS'Y-HOSE, brake rear (l=330)
16 46237-18000 GASKET-brake hose to cylinder <x> 42637-A4600
   46237-A4600 GASKET-brake hose to cylinder (from '73-3)
17 46205-61000 PLATE-lock, brake hose
18 40206-18000 SPRING-lock, brake hose
19 46280-H1001 TUBE ASS'Y-brake master cylinder to rear brake hose (up to '72-7) (Single M/C) STD,V-Dx
   46280-H1001 TUBE ASS'Y-brake master cylinder to rear brake hose (up to '72-8) STD,V-Dx <x> 46280-H1001
   46280-H3200 TUBE ASS'Y-brake master cylinder to rear brake hose DX,GL,GX (exc. Auto,5-speed)
   46280-H3201 TUBE ASS'Y-brake master cylinder to rear brake hose DX,GL,GX (exc. Auto,5-speed) (from 72-8) (Tandem M/C) > 46280-H3200
   46280-H3210 TUBE ASS'Y-brake master cylinder to rear brake hose Automatic
   46280-H3211 TUBE ASS'Y-brake master cylinder to rear brake hose Automatic (from '72-5) > 46280-H3210
   46280-H7201 TUBE ASS'Y-brake master cylinder to rear brake hose 5 speed
   46280-H7201 TUBE ASS'Y-brake master cylinder to rear brake hose 5 speed (from '72-5) > 46280-H7201
1 46223-H1901 ASSY-TUBE BRAKE MASTER CYL. FR(TANDEM)TO OP 2 46223-H1900
1 46223-H3900 ASSY-TUBE,B/MASTER CYL.FR (TANDEM) TO 1071-0473 30 46223-H1901
1 46223-H3901 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 0573- 2 46223-H3900
1 46223-G1300 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 0573- 46223-H3901
1 46223-H1900 ASSY-TUBE BRAKE MASTER CYL FR(TANDEM)TO
2 46224-H3901 ASSY-TUBE,B/MASTER CYL. RR (TANDEM) TO 0573- 2 46224-H3900
2 46224-H1900 ASSY-TUBE BRAKE MASTER CYL RR(TANDEM)TO
2 46224-H1901 ASSY-TUBE BRAKE MASTER CYL. RR(TANDEM)TO OP 1170- 2 46224-H1900
2 46224-H3900 ASSY-TUBE,B/MASTER CYL.RR (TANDEM) TO 1071-0473 30 46224-H1901
3 46100-26100 ASSY-SWITCH BRAKE INDICATOR
3 46100-U5200 ASSY-SWITCH BRAKE INDICATOR 1071-0473 32 46100-26100
4 08360-63514 SCREW-MACHINE WITH WASHER
5 46240-H1900 ASSY-TUBE BRAKE FRONT RH FOR TANDEM B -473 3
5 46240-H1901 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 0573- 2 46240-H1900
5 46240-G1300 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 0573- 2 46240-H1901
6 46242-H1900 ASSY-TUBE BRAKE FRONT LH FOR TANDEM B -473 3
6 46242-H1901 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 0573- 2 46242-H1900
6 46242-G1300 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 0573- 2 46242-H1901
7 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL 0573- 2 46280-H1901
7 46280-H1905 ASSY-TUBE CONNECTOR TO REAR AUTOMATIC
7 46280-H1906 ASSY-TUBE CONNECTOR TO REAR AUTOMATIC 46280-H1905
7 46280-H1901 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL -473 3
7 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL -473 3 46280-H1901
8 46313-18000 CONNECTOR-3WAY REAR
8 02463-13200 CONNECTOR-3WAY REAR 46313-18000
9 08110-82562 BOLT-HEX WITH WASHER M8
10 46290-H5501 ASSY-TUBE REAR BRAKE RH COUPE 0673- 5 46290-H1001
10 46290-H7301 ASSY-TUBE REAR BRAKE RH COUPE 0673- 5 46290-H5501
10 46290-H1000 ASSY-TUBE REAR BRAKE RH SEDAN COUPE -473 3
10 46290-H1001 ASSY-TUBE REAR BRAKE RH SEDAN COUPE 0573- 2 46290-H1000
10 46290-H5001 ASSY-TUBE REAR BRAKE RH SEDAN 0673-0473 35 46290-H1001
10 46290-H7201 ASSY-TUBE REAR BRAKE RH SEDAN 0673-0473 35 46290-H5001
11 46310-H5501 ASSY-TUBE REAR BRAKE LH COUPE 0673- 5 46310-H1001
11 46310-H5001 ASSY-TUBE REAR BRAKE LH SEDAN 0673-0672 25 46290-H1001
11 46310-H1000 ASSY-TUBE REAR BRAKE LH SEDAN COUPE -473 3
11 46310-H1001 ASSY-TUBE REAR BRAKE LH SEDAN COUPE 0573- 2 46310-H1000
12 46201-89918 ASSY-HOSE BRAKE REAR L=330
12 46201-H7200 ASSY-HOSE BRAKE REAR L=330 46201-89918
13 46237-18000 GASKET-BRAKE HOSE TO TUBE
14 46205-61000 PLATE-LOCK BRAKE HOSE
15 46206-18000 SPRING-LOCK BRAKE HOSE
