Also see: * Applied Model Codes Overview * Early Applied Model Codes 001-999 * Applied Model Codes 2 A,B,G,N,R,T,U * Applied Model Codes 3 xxW codes (01W-99W) * Applied Model codes list for A-engined vehicles H,G,M,W - Sunny, Sunny Truck, Cherry/Pulsar, Violet * Nissan Part Number Overview * Nissan hardware part number (N.E.S.) for bolts, nuts, etc.
01A ? B11 03A ? B11.U [USA] 16A ? B11 17A ? B11.DIE 36A ? B11(1983)
07F ? S12.CA20E 18F ? S12.CA18ET 27F ? S12.CA20E (1986) 28F ? S12.CA18ET (1986)
01G ? D21 03G ? D21.Z24.U [FED] 04G ? D21.Z24.V [CAL] 07G ? D21.4WD 11G ? D21.WT 12G ? D21.VG30 55G ? D21 (1992) 83G ? D21 (1993) 86G ? D21 (1993) 92G ? D21 (1991)
16M ? N12 17M ? N12.E15ET 21M ? N10.E15S 23M ? N12.E15S 31M ? N12.E16S.V [CAL] 33M ? N12.E16S.U [FED] 37M ? N12.COUPE
01P ? Z31 02P ? Z31T 19P ? Z31 (1988) 21P ? Z31T (1988)
30P ? Z32 40P ? Z32 (1991) 46P ? Z33 (1992) 48P ? Z33T (1995) 54P ? Z33T (1996)
01W ? 720 02W ? 720 04W ? 720.L20B 06W ? 720.Z22 09W ? 720.SD23 10W ? 720.Z24 11W ? 720.KC 16W ? 720.KC.4WD 21W ? 720.WC 25W ? 720.Z16 26W ? 720.Z18 30W ? 720.Z24 31W ? 720.DIE 41W ? 720.4WD 44W ? 720.L20B C60 ? 160.AD 46W ? 720.Z22 61W ? 720.Z20 89W ? 720.U [FED] 90W ? 720.V [CAL] 19W ? 720.SD25 34W ? 720.SD22 36W ? 720.SD22 54W ? 720 (1983)
CD0 ? Z33 AM6 ? Z33.U
M64 ? N10 M66 ? N10.U [ M67 ? N10.V [CAL]
Sources
Lines marked with ? are inferred from inspection of part numbers (an educated guess).
