The room lamp, also known a dome light.
Car
These parts are the same for both B110 and B210.
510 Lamp
510 lamp is a different style and bolts into B210, so may fit B110.
26410-23100 ASSY-LAMP ROOM -0968 EXC CAN <x> 26410-23101 * 1968 CANADA used dual rectangular side lamps 26410-A0800 ASSY-LAMP ROOM 0968-
Pickup
26410-04100 LAMP ASS'Y-room -7803 IKI 26410-G1000 LAMP ASSY-ROOM -7803 IMASEN 26410-04400 LAMP ASSY-ROOM 7803- IKI
Two wires: * Red: bulb 12V * Black: earth/ground
B10
B10 sedan and VB10 wagon uses the same lap as 1200 ute. IKI brand (市川, Ichikawa).
26410-04100 ASS'Y-LAMP, room STD IKI 26410-04400 ASS'Y-LAMP, room DELUXE IKI
521 Lamp
Datsun 521 pickup (USA) uses the same Room Lamp as a 1200 Pickup. IKI brand.
26400-04100 ASS'Y-LAMP, room 26410-04400 ASS'Y-LAMP, room * 26411-04100 LENS * 26715-89900 BULB (12V 6W) * 5-10813-1 SCREW-machine (2)
The room lamp has one side of the lamp (RL wire) always hot from the L wire of the fuse box. The switch has three positions:
- Off
- Auto (center)
- On
In the auto position, the light is grounded by the Door Switch (BR wire in a-pillar). Usually only the driver's side door has a switch. In the ON position, it is grounded through the ground wire in the headliner.
