B110 2-door sedan has large popout side windows, B110 while 2-dr coupe has smaller popout glass. 2-dr Van has a rectangular popout.
Also see Glass#Door_Glass
Van rear side window is fixed, while 2-dr Van middle side window is popout-type.
4-door 2-door van
All popout-type windows use the same inside handle, but it bolts to the glass in different way on the Coupe.
Sedan & Van use seperate hinges bolted to the glass, while coupe has hinges welded to the glass frame.
Also see Rear Window Part Numbers
Coupe
Sedan
4-door
Sedan has fixed "quarter windows" in the rear doors.
See main article: Doors#Door_Glass
2-door
* Tinted * Non-tinted * Laminated or non-laminated
76822-H1301 GLASS-SIDE WINDOW RH TINTED & TEMPERD T=
Rubber
B110 has a window seal (weatherstrip) that's glued to the outside of the frame, and an inside cover (welt) for the frame.
76802-H1202 WEATHERSTRIP-SIDE WINDOW RH 76803-H1202 WEATHERSTRIP-SIDE WINDOW LH 76922-H1200 WELT-SIDE WINDOW BLACK #698 (2) COUPE, SEDAN 2-DOOR
generic aftermarket Welt can be used:
B310 weatherstrip fits with some trimming:
B310 83830-H8600 WEATHERSTRIP-SIDE WINDOW RH (BLACK 002G0 $84.53 USD B310 83831-H8600 WEATHERSTRIP-SIDE WINDOW LH (BLACK 002G0 $84.53 USD
B310 uses a one-piece seal. B310 weatherstripping can be used for B110 2-dr sedan rear side window weatherstripping. It's almost perfect, but about 1 inch too short for the B110. Surprisingly, the B110 glass is actually larger! Just trim a bit of it off when fitting to the B110.
Hinges
Hinges - big washer goes under the hinge
76832-H1201 HINGE-SIDE WINDOW (4) SEDAN 2 DOOR![]()
76828-H1200 COVER-SIDE WINDOW HINGE
B310 Hinges are identical except for additional tab for hinge cover
Grommet (Finish Nut) Comparo. B310 units do not interchange
B310 grommets can be used if B110 rubber washers are employed
Do B210 hinge covers fit?![]()
Latches
76870-H1200 ASSY-HANDLE SIDE WINDOW LH COUPE,SEDAN 2-DR![]()
76872-18000 PIN-HANDLE SIDE WINDOW
B310 Handle comparo (does not interchange):![]()
B210 latches are same Right/Left. Do they fit B110?
76860-H5300 HANDLE ASS'Y-side window COUPE, VAN-2DR, SEDAN-2DR
Van
2-door Van
Datsun 1200 2-dr wagon has popout side glass in the spot where the rear passenger doors are on the 4-dr van.
Same handle as the others
Same hinges and grommets as Sedan
2-door wagon also has a fixed rear side window. A bar runs across the inside to guard it. It is identical to the 4-door except for the weatherstripping and Guard Bar.
4-door Van
Wagon has fixed "quarter windows" in the rear doors.
Wagon also has a fixed rear side window. A bar runs across the inside to guard it.
620 Pickup
Datsun U620 ute uses same Hinges as B110 Van/Sedan
76832-H1201 HINGE-SIDE WINDOW 76828-H1200 COVER-SIDE WINDOW HINGE 76846-H1201 WASHER [window glass]
