Bulbs
Revision as of 02:11, 7 May 2015; view current revision
Also see Lighting System
1. Exterior single element, one bottom contact
Rear T/S (turn signal)
* 23 watt (North America) Sylvania 1156 Wagner 1156
* 21 watt (other countries)
2. Exterior dual element, two bottom contacts
Front park & T/S, Rear Tail & Stop
* 23/8 watt (North America) Sylvania 1157 Wagner 1157
* 12/5 watt (other countries)
3. 10-AMP FUSE
(2 needed) 08941-11000 for Fuse Box
4. 15-AMP FUSE
(4 needed) 08941-11500 for Fuse Box
5. Seat Belt Lamp
USA 1972-1973 Seat belt light (on top of dash) Toshiba 12V 10W Type SV8.5 31mm long
* 26945-H4600 (not sure if this lamp only, or whole unit)
 Sylvania DE3175
 Wagner 12100
6. Dome Lamp
10 watt (room lamp) 26736-89902
* Type SV7, ~29 mm long (pictured) seems to fit best, but are usually 3w or 5w
* Some parts stores specify the larger unit (see above Wagner 12100, Sylvania DE3175) which is readily available
7. Instrument Panel Lamp
Twist-lock holder (7 used in round dash).
26260-89900 Wedge Socket (7 total for round gauge) $3.28 USD each
* W2.1x9.5d base (aka W2, miniature wedge, or T5 base)
T10 bulbs come in different wattage and socket bases, the 1200 ones use a W2.1x9.5d base, known in USA as "Miniature Wedge".
USA 26261-89902 1.7 watt bulb (ROUND GAUGE)
JPN B110
* 26261-89900 BULB-12V, 1.5W SQUARE METER 7
* 26261-89902 BULB-12V, 1.7W ROUND METER 7
JPN B120
* 26261-89900 7510-7803 12V-3.4W 商B113 8
* 26261-89902 7804- 12V-2.7W 商B113 6
* 26711-89900 7804- 12V-1.7W 商B113 2
* 26711-89902 8910- 12V-2.7W 商B113 6
* 26711-89900 8910- 12V-1.7W 商B113 2
* 3.4 watt (Square Gauge) Type 158 14V
NOTE: Type 159 is identical looking, but only 1.0 watt 6.3V
8. Exterior Lamp
Side-marker lamp
* 8 watt (North America, non-flashing)
  Wagner 97
  Sylvania 97 (9.32 watt  nominal)
* 6 watt (flashing, non-North America)
License lamp Sylvania 1895 Wagner 1895 (3.78 watt)
* 10 watt (Sedan, except North America)
* 7.5 watt Coupe, Van 26715-89901 Ichikho
* 7.5 watt Sedan USA
 Bailey B29.012.625 (7.5w) or [Toshiba A12V8W 6 7]
Reverse light - 10 watt
9. Instrument Panel Turn Signal
Indicators (2 needed)
* (not shown) 26260-H1800 SOCKET-WITH LEAD WIRE
* 26711-89900 1.7 watt (ROUND GAUGE) 3.4 watt (Square Gauge)
Sylvania 1445 $2.49 Wagner 1445
Lamp Specifications
Head Lamp
26705-04101 Sealed beam unit (Koito)
or
26705-08700 Sealed beam unit (Koito)
Front Combination Lamp - Early
26717-89920 BULB (12V-23/7W)
26261-89900 BULB (12V-3W)
Front Combination Lamp - Late
26717-89900 BULB (12V-23) [P21W]
26261-89920 BULB (12V-8/3.4W) [P21/5W???]
* or 26261-89925 BULB (12V-8/3.4W) 7804-
North America
  Spec. SAE No. Nissan^
Headlight unit 12V-50/40W 6012 26705-04201
Direction and Parking 12V-23/8W 1034/[*1157] 26717-89920
Side marker 12V-8W 67 26715-89902
License plate 12V-7.5W 89 26715-89901
Rear combo. Light
Taillight
Stop (brake)
Turn signal
Back-up light
12V-23/8W
12V-23/8W
12V-23W
12V-23W
1034
1034
1073/[**1156]
1073
26717-89920
26717-89900
Meter illumination 12V-1.7W (round gauge) 161 26711-89900
Wiper Knob illumination (1973) 12V-3.4W 158  ?
Heater control ill. (1973) 12V-3.4W 57  ?
Ignition warning 12V-1.7W 161 26711-89900
Turn Signal indicator 12V-1.7W 161 26261-89902
Headlight beam ind. 12V-1.7W 161 26711-89900
Oil press. warning 12V-1.7W 161 26711-89900
Brake warning 12V-1.7W 161 26711-89900
Room light 12V-10W n/a 26736-89902
^from USA catalog, all are ICHIKO brand
* 1157 can replace 1034 but uses more current
** 1156 can replace type 1073
USA 1972 Owners manual (see page 36 for bulb specifications):
Portugal
Opticas 12V-50/40W
12V-21/5W Luz de mudança de direcção o de presença
12V-6W Luzes laterais de mudança de direcção
12V-7.5W Luz da chapa de matricula
Conjunto de luzes traseiras
 12V-5W luz de presença
 12V-21W luz de stop (travões)
 12V-21W luz de mudança de direcção
 12V-21W luz de marcha atrás
12V-3W Luz de iluminacão do painel de instrumentos
12V-3W Luz avisadora da ignicão
12V-3W Luz indicadora dos máximos
12V-3W Luz avisadora da pressao do óleo
12V-10W Luz interior
12V-3W Luz de iluminação do relogió
