The Datsun 1200 cylinder head gasket fit A12 and A10 engines. Aftermarket gaskets vary in material and size of cooling holes. Aftermarket gaskets may come with oversized bore holes.
Also See: * Changing Head Gasket * Tune-upNissan recommends re-torquing the head gasket bolts ever twenty-four months (every two years):
Revised gasket uses an O-ring seal
11044-18004 GASKET-CYLINDER HEAD A12 superceeded![]()
11044-H1000 GASKET-CYLINDER HEAD A12 B110 11044-H1000 GASKET-cylinder head A12 B210 to '75-4 11044-H1025 B110 (from '72-5) * 11045-H1000 RING "O" (from '72-5) 11044-H1025 B210 from '75-5 11044-H1026 11044-H1027 11044-H3900 GASKET-CYLINDER HEAD A12 USA 0671-
fits: A10 PULSAR 1000 BN10 988cc 1978-ON A10 SUNNY 1000 B10,B20 1000 1966-1970 A12 SUNNY 1200 B110,B210,C20 1171cc 1970-73.3 A12 SUNNY 1200 B210 1973.4-75 A10 CHERRY 1000 E10, F10 988 1970.10-73.9 A12 CHERRY 1200 PE10, F10 1171cc 1972-78
11044-H2300 A12GX, A12T 11044-H2301 [thinner?] A12GX, A12T 11044-H2325 A12GX from '72-6 * 11045-H2300 RING "O" (from '72-6)![]()
Head Set
Nissan 11044-H3926 KIT-GASKET,CYLINDER HEAD 11042-H3927 KIT-GASKET,CYLINDER HEAD
aftermarket Victor HS3602 FEL-Pro HS21181PT ROL HS32060
Head Set gasket kit includes all you need to change the head:
* Cylinder head gasket * Valve stem seals * Rocker cover gasket * Gasket-manifold to cylinder head
it may include the following:
* thermostat gasket * intake-to-exhaust manifold gasket (heat riser gasket) * oil cap packing (gasket) * fuel pump gaskets
Nissan Competition
Nismo head gaskets for Nissan A series motor A12,A13,A14,A15 Engine
11044-M0822 t=0.8 79.0 mm bore diameter 11044-M0823 t=0.6 80.0 mm bore![]()
シリンダーヘッドガスケット
既に生産廃止
