Ignition Coil
Revision as of 20:34, 23 July 2015; view current revision
Category: Engine Electrical System
Original specification: Hanshin H5-15-2 or Hitachi C6R-601
Ballast Resistor: Hanshin RC-15 or Hitachi 5560R-1510
1: Coil Ballast Resistor
2: Ignition Coil
3: Horn Relay
The location is the same for RHD and LHD 1200s.
Specification
  • Primary (12V) Resistance @ 20C/68F temperature: 1.17 to 1.43 ohms
Secondary (high voltage) Resistance @ 20C/68F temperature: 11,200 to 16,800 ohms
External Resistor (Ballast Resistor) @ 20C/68F temperature: 1.3 to 1.7 ohms
  • beck-arnley part number 178-8000
OEM by Hanshin
22433-14806 COIL-ignition (Hitachi C6R-601)
22433-14816 COIL-ignition (Hanshin H5-15-2)
22433-14606 COIL-ignition (Hitachi) GX (op. non-GX)
 22460-14606 RESISTER
22433-14616 COIL-ignition (Hanshin) GX (op. non-GX)
 22460-14616 RESISTER
22462-U3110 COIL-IGNITION Hanshin
22462-H3140 COIL-IGNITION Mitsubishi
For late 1200 with electronic igntion, see EI Coil
22462-52A60 COIL-IGNITION Mitsubishi 8910-
See
Aftermarket
OEM Replacement
ECHLIN IC17
BECK/ARNLEY 1788025, includes external resistor
AIRTEX/WELLS 5C1057
* Primary 200 Scale 1.2 - 1.9
* Secondary 200 Scale 7.0k - 13.0k
STANDARD MOTOR PRODUCTS SMP UF2
SMP UF2 Replaces:
* Nissan
  22433-14606/22433-14615/22433-14616
  22433-A5400/22433-A5410
  22433-AA170
  22433-U3310
ALFA ROMEO GTV-6 (83-81)
AUDI 100 SERIES (74-70)
AUDI 4000 (80)
AUDI FOX (79-73)
AUDI SUPER 90 (72-70)
AUSTIN AMERICA (72-68)
AUSTIN MARINA (75-73)
BENTLEY MULSANNE (81)
BMW 2500 (71-68)
BMW 2800 (71-68)
BMW 3.0CS (74-72)
BMW 3.0CSI (74-72)
BMW 3.0S (74-72)
BMW 320I (79-77)
BMW 530I (78-75)
BMW 630CSI (78-77)
FIAT 124 (77-68)
FIAT 128 (79-75)
FIAT 131 (78-75)
FIAT 850 (73-70)
FIAT STRADA (82-79)
FIAT X-1/9 (83-75)
FORD FESTIVA (89)
ISUZU PICKUP (87-86)
JAGUAR VANDEN PLAS (87-82)
JAGUAR XJ12 (79-73)
JAGUAR XJ6 (89-75)
JAGUAR XJS (81-76)
JAGUAR XKE (74-71)
LAND ROVER RANGE ROVER (91-87)
MAZDA 618 (72)
MAZDA 808 (77-72)
MAZDA B1600 (76-72)
MAZDA B1800 (78-77)
MAZDA COSMO (78-76)
MAZDA GLC (79-77)
MAZDA ROTARY PICKUP (77-74)
MAZDA RX-2 (74-71)
MAZDA RX-3 (77-72)
MAZDA RX-4 (78-74)
MAZDA RX-7 (79)
MERCEDES-BENZ 220 (65-60)
MERCEDES-BENZ 220S (65-60)
MERCEDES-BENZ 220SE (65-60)
MERCEDES-BENZ 230 (69-66)
MERCEDES-BENZ 230SL (65-63)
MERCEDES-BENZ 250 (70-68)
MERCEDES-BENZ 250S (67-66)
MERCEDES-BENZ 300 (61)
MERCEDES-BENZ 300D (62)
MERCEDES-BENZ 300SE (66-61)
MERCEDES-BENZ 300SEL (65-63)
MERCEDES-BENZ 300SL (63-61)
MERCEDES-BENZ 600 (71-66)
MG MGB (81-75)
MG MIDGET (79-75)
NISSAN 1200 (73-72)
NISSAN 240Z (73-70)
NISSAN 410 (65-63)
NISSAN 411 (67-64)
NISSAN 510 (73-69)
NISSAN 520 PICKUP (68-65)
NISSAN 521 PICKUP (72-69)
NISSAN 620 PICKUP (73-72)
OPEL 1900 (75-71)
OPEL DELUXE (71)
OPEL KADETT (72-64)
OPEL MANTA (75-71)
OPEL OPEL (73-69)
OPEL RALLYE (70-69)
PORSCHE 911 (67-65)
RENAULT R17 (74-72)
ROLLS ROYCE CORNICHE (76-75)
ROLLS ROYCE SILVER SHADOW (76-75)
ROVER 2000 (71)
ROVER 3500 (80)
ROVER 3500S (71-70)
SAAB 95 (68-66)
SAAB 96 (68-65)
SAAB 96 GT (65)
SAAB 99 (74-70)
SAAB MONTE CARLO (67-66)
SUBARU DELUXE (73)
SUBARU DL (79-77)
SUBARU FE (79)
SUBARU GF (79-77)
SUBARU GL (79)
TOYOTA COROLLA (73-71)
TRIUMPH SPITFIRE (80-75)
TRIUMPH TR6 (76-73)
TRIUMPH TR7 (82-80)
VAUXHALL VICTOR (63-59)
VOLKSWAGEN BEETLE (79-67)
VOLKSWAGEN DASHER (80-74)
VOLKSWAGEN FASTBACK (73-71)
VOLKSWAGEN JETTA (80)
VOLKSWAGEN KARMANN GHIA (67)
VOLKSWAGEN RABBIT (80-75)
VOLKSWAGEN RABBIT PICKUP (80)
VOLKSWAGEN SCIROCCO (79-75)
VOLKSWAGEN SQUAREBACK (73-71)
VOLKSWAGEN SUPER BEETLE (80-71)
VOLVO 164 (74-70)
VOLVO 262 (78-76)
VOLVO 264 (81-76)
VOLVO 265 (78-76)
VOLVO 760 (86-83)
VOLVO DL (84)
VOLVO GLE (84)
Bosch
Bosch OEM replacment coil
There are several common coils in the Australian Bosch GT coil range.
  • GT40: an oil filled conventional type coil, 3 ohm
  • GT40R: same as GT40, but 1.5 ohm for use with a ballast resistor
  • GT40T: a 'transformer' style coil potted in epoxy, 3 ohm
  • GT40RT: same style as GT40T, but 1.5 ohm
GT40R or GT40RT can be used as a direct replacement for the stock 1200 coil, but is less powerful than the stocker 1.3 ohm coil.
Bosch Blue
The Bosch black coil uses varnish & tar in its construction, the blue coil uses Formavar (a high temp varnish) and polypropylene. In theory, the blue coil should hold up better at higher temperatures but users report that both coils do about the same.
GT40R
Primary Resistance: 1.2 ohms
Secondary Resistance: 8-10 Kohms
GT40RT
Primary Resistance: 1.5 ohms
Secondary Resistance: 8.6 Kohms
Bosch EI
Bosch HEC715 is used with electronic ignition.
Primary Resistance: 0.41 ohms
Secondary Resistance: 7.8 Kohms
