Also see: Part Numbers Index Main article for usage, photos, cross-reference Window Regulator for Window Winder/Regulator Handle Door Lock (door latch and door handle) Rear Door Glass
For rear door corner glass, see Rear Door Part Numbers
SEDAN REAR DOOR WINDOW 1 82310-H1000 GLASS-rear door (R.H.) STD 82310-H1100 GLASS-rear door (R.H.) DX,GL,GX 82311-H1000 GLASS-rear door (L.H.) STD 82311-H1100 GLASS-rear door (L.H.) DX,GL,GX 2 82302-H1000 ASS'Y-BOTTOM, channel (R.H.) 82303-H1000 ASS'Y-BOTTOM, channel (L.H.) 3 82316-H1000 RUBBER-glazing (2) 4 82335-H1000 RUBBER-glass run "C" (2) < 82335-H1001 82335-H1001 RUBBER-glass run "C" (2) (from '70-Oct)
VAN REAR DOOR WINDOW 1 82310-H1400 GLASS-rear door (R.H.) VS,VP 82310-H1500 GLASS-rear door (R.H.) V-DX 82311-H1400 GLASS-rear door (L.H.) VS,VP 82311-H1500 GLASS-rear door (L.H.) V-DX 2 82302-H1000 ASS'Y-BOTTOM, channel (R.H.) 82303-H1000 ASS'Y-BOTTOM, channel (L.H.) 3 82316-H1000 RUBBER-glazing (2) 4 82335-H1400 RUBBER-glass run "C" (2) REAR DOOR LOCK & REMOTE CONTROL (4 DOOR SEDAN & VAN) * 82500-H1001 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (R.H.) <> 82500-H1102 82500-H1002 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (R.H.) (from '71-Jan) * 82501-H1001 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (L.H.) < 82501-H1102 82501-H1002 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (L.H.) (from '71-Jan) 5 82502-H1001 ASS'Y-DOOR LOCK, rear (R.H.) <> 82502-H1002 82502-H1002 ASS'Y-DOOR LOCK, rear (R.H.) (from '71-Jan) <> 82502-H3100 82502-H3100 DOOR LOCK ASS'Y, rear (R.H.) (from '72-8) 82503-H1001 ASS'Y-DOOR LOCK, rear (L.H.) <> 82503-H1002 82503-H1002 ASS'Y-DOOR LOCK, rear (L.H.) (from '71-Jan) <> 82503-H3100 82503-H3100 DOOR LOCK ASS'Y, rear (L.H.) (from '72-8) 6 80504-H1001 ASS'Y-REMOTE CONTROL, front door (R.H.) 80505-H1001 ASS'Y-REMOTE CONTROL, front door (L.H.) 7 80508-H1000 SPRING-door lock (R.H.) 80509-H1000 SPRING-door lock (L.H.) fixing door lock 8 08320-61219 SCREW-with lock washer (6) or, fixing door lock 8 08320-61012 SCREW (6) 9 08916-43610 WASHER-tooth lock (6) fixing remote control 10 08310-61226 SCREW-with washer (6) or, fixing remote control 10 08310-61214 SCREW-with washer (6) 11 08915-43610 WASHER-plain (6)
REAR DOOR HANDLE (4 DOOR SEDAN & VAN) 12 82605-H1000 ASS'Y-HANDLE, door outside (R.H.) 82606-H1000 ASS'Y-HANDLE, door outside (L.H.) 13 01221-00023 NUT (4)
REAR DOOR REGULATOR (4 DOOR SEDAN & VAN) 14 80760-H1000 ASS'Y-HANDLE, door window regulator (2) 15 80675-H1000 WASHER-handle, door regulator (2) 16 08330-51220 SCREW (2) 17 82700-H1000 ASS'Y-REGULATOR, rear door window (R.H.) <> 82700-H1001 82700-H1001 ASS'Y-REGULATOR, rear door window (R.H.) 82701-H1000 ASS'Y-REGULATOR, rear door window (L.H.) <> 82700-H1001 82701-H1001 ASS'Y-REGULATOR, rear door window (L.H.) fixing regulator 18 08310-61014 SCREW-with lock washer (6) Or, fixing regulator 18 08310-61012 SCREW (6) 19 08915-13610 WASHER-lock (6)
20 80570-21000 ASS'Y-STRIKER, door lock (R.H.) 80571-21000 ASS'Y-STRIKER, door lock (L.H.) 21 80571-24800 SHIM-striker (2) fixing striker 22 08360-61614 SCREW-with lock washer or, fixing striker 22 08440-61212 SCREW (6) 23 08916-33610 WASHER-tooth lock (6) 24 80510-H1000 ESCUTCHEON-remote control (R.H.) 80511-H1000 ESCUTCHEON-remote control (L.H.) 25 08330-50620 SCREW (fixing escutcheon) (2) 26 80595-21003 KNOB-door lock (2) <> 80595-N1600 80595-N1600 KNOB-door lock (from '71-Apr) (2) 27 80970-21000 GROMMET-knob (2) 28 80515-E0100 BUSH-bell crank (2) fixing bell crank 29 08310-61414 SCREW-with washer (2) 30 08915-53610 WASHER-plain (2) 31 H0510-21001 HOLDER-rod (nylon) (2) 32 80517-H1000 SHIELD-inside handle (2)
