The front wheel hub contains the Wheel Bearings. The brake rotor (or brake drum) is bolted to the hub.
drum hub vs. disk hub
The brake rotor bolts to the back of the hub
full
hub slips onto spindle
late Disc Brake Hub from 1989 October (not early B122)
Specs
The hub slips over the spindle, thus the bearing sizes matter
B110 Wheel bearings D1 inner 25mm bearing journal diameter (0.9840") D2 outer 15mm bearing journal diameter (0.5906")
B110 Drum Hub EXTERNAL measurements * 135 mm diameter (disc hub is more than 140mm) * 47 mm height * about 82 mm overall length![]()
Comparo
Bearing Seal
See Wheel Bearings
Grease Caps
Replace the caps if grease is leaking out:
Buy at Bprojects
Larger size dust cover 43mm 40234-18000 CAP-HUB FRONT WHEEL * B10 * B110 * early B120 to 7510 * early B210 to 7510
Smaller caps 40 mm 40234-28500 CAP-HUB FRONT WHEEL * B310 (both hub types) * Late B210 from 7510 (both hub types) * Late B120 from 7510
A10 Hub
A10 Stanza uses same hub as 710.
1.25" inner bearing journal diameter 0.75" outer bearing journal diameter
DRUM - ASSY-HUB ROAD WHEEL FRONT * B110: 40202-18051 DRUM BRAKE * B210: 40202-18000 DRUM 1974-1975 * B210: 40202-H7405 DRUM 1976-1978 Japan * B210: 40202-H7425 DRUM 7510- Van Japan * B210: 40202-H7425 DRUM 1976-1978 Japan
DISC - ASSY-HUB ROAD WHEEL FRONT * B110: 40202-H1005 DISC BRAKE * B210: 40202-H1005 DISC 1974-1975 GX * B210: 40202-22000 DISC -0775 USA * PB210: 40202-22050 DISC 1974-1975 * PB210: 40202-A0155 DISC 7510- * B210: 40202-A0155 DISC 0875- USA * B210: 40202-A0155 DISC 1976-1978 L16 Japan * B310: 40202-H7405 DISC, small rotor (Canada A12A) * B310: 40202-W5050 DISC, large rotor (A14/A15, A12A USA)
