Datsun 1200 takes a traditional spin-on oil filter with 76-82 mm diameter and threads of 3/4-16 (fine thread).
Pretty much any A-series filter fits. Or any with the same threads and diameter. Few are too long for the 1200.
Nissan 15208-H8920 Oil Filter 130mm length $7.08 * formerly: 15208-H1010 115 height $8.27 USD 0272-7910 ** formerly: 15208-13211/15208-13212 145 length
15208-55Y00 Oil Filter $7.08 USD formerly: * 15208-H8911 FILTER ASSY-OIL 7911-8502 * 15208-H8903 FILTER ASSY-OIL 8502-
Specifications: Threads: 3/4-16-UNF-2B Outside Diameter: 80 Seal diameter: 70mm (original spec) or 63mm (revised spec)
Australia/New Zealand: Ryco Z145A (102mm tall) Ryco Z37 (143mm tall)
http://www.rockauto.com ELEMENT-oil filter, cartridge PRO-TEC 150 $2.43 BECK/ARNLEY 0418723 $4.41 BOSCH 72133 $4.41 WIX 51361 $4.67 ACDELCO PF34 $4.88 FRAM PH3639 $6.00
Tokio FL-208(Y) 1300, 1500 C-201 FRAM ExtraGuard PH3639 Purolator #L30042 Deutsch #D601 Purolator PER42 (DATSUN,TOYOTA) Purolator L30042 Pennzoil PZ8 Champion PH2822,2825 AC PF1026 (?)
Newer A-series filter PN 15208-H8920 (Length: 130) Tokio FL-208 C-208 CKO-1218 SP-842 FC 208 15208H8923 T-3135
NISSAN 15208-55Y00 Fits these USA models: * B14U 1998- GA16DE * B14X 1995- GA16DE * D21 1986-1992 VG30, Z24, VG30E * D21U 1995- KA24Em VG30 * S13 1991- KA24E * S14 1994- KA24DE * U13U 1993- KA24DE * V40 1992-1997 VG30E * WD21 1987-1989 Z24I, VG30E * B12 1989- GA16I * B13 1991- GA16DE * J3- 1992- VG30E * M11 1991- KA24E * Z31 1991- VG30, VG30T
Ford F1 Filter
TIP: Use a Ford oil filter #F-1 on your 1200. You only need to use a rotary grinder to grind 1/4 inch off the engine boss. The rotary bit cuts cast iron like butter. Then it fits.
- bigger capacity
- In the US, it is less expensive than the small "import" filter
Other A-series
NISSAN SUNNY,CHERRY (Length: 100) FL-207 15208-H8916 15208-H8911 15208-H8994 SP-929 15208-H8917 15208-H8912 15208-H8905 15208-H8904 15208-H8903 15208-H1011 15208-H1010 Purolator L24457 Pennzoil PZ27 Champion PH2827,2903 NISSAN,SUBARU AC Delco PF8903 Wix 51361 Champ PH2827 Fram ExtraGuard PH3682 Fram ToughGuard TG3682 Fram DoubleGuard DG3682 Fram X2 XG3682 Fram PH3682 Fits: * Kubota 66021-36060/66021-36061 * Komatsu 15208-01B02 * Komatsu 15208-H8911 * Komatsu 15208-H8920 * Komatsu 37Z-02-OF201/37Z-02-OF201L * Nissan 15208-55Y00 * Nissan 15208-60U01/15208-60U02 * Nissan 15208-H8901/15208-H8903 * Nissan 15208-H8911/15208-H8916/15208-H8917 * Nissan 15208-H8994 * Subaru 15208-AA000/15208-AA001 * Subaru SOA5165100 * Volkswagen Fastback 1966-1973 * Volkswagen Squareback 1966-1973 * Volkswagen Karmann Ghia 1955-1974 * Volkswagen Thing 1973-1974
B210, B310, F10 Fram ExtraGuard PH46 Purolator L10168 (Audi 5000 Turbo) AC DuraGuard PF34: PF34 #6437982 AC PF34 fits: * 74-82 DATSUN F10,210,B210,310 * 78-80 FORD FIESTA L4-1.6L * 71-73 PINTO L4-1.6L * 72-75 CHEV LUV TRUCK * 83-90 MERCEDES-BENZ 4 CYL * 70-79 SUBARU * 86-90 TOYOTA VAN 2.2L, 69-80 W/KC, RC ENGINES * 81-84 STARLET * 84-85 TERCEL L4-2.0L
