Main : Mechanical : Engine oil filter alternative
[<   Previous  2634  2635  2636  2637  2638  2639  2640  Next   >]
oil filter alternativePopular
Submitterang94541More Photos from ang94541   Last Update2004/6/22 8:10    Tell a friendTell a friend
Hits4625  Comments2    0.00 (0 votes)0.00 (0 votes)
Here are a couple of oil filter alternatives. If it saves one person from opening all the boxes at at the autoparts store then I guess it's worth it.
These fit the 3/4"-16 thread of the stock oil pump. Same thread as most Ford/Chryslers.  I had to grind a little off of the engine block (a12) to get the extra width to fit. You could probably do it with a big file. The 977a will hang about even with the bottom of the oil pan.
Posted: 2006/7/9 1:46  Updated: 2006/7/9 1:46
 Re: oil filter alternative
Yes, the standard Ford V8 filter is less expensive yet larger:
F1
PH1
etc
You only need to grind off about 6mm, using a rotary "cast iron" bit makes it live cutting butter.
For standard filter numbers, see:
club wiki - Oil Filters [edited link]
oil filter number
LittleFireyOne
Posted: 2007/2/21 12:35  Updated: 2007/2/21 12:35
Browsing through these pics I find it amusing. At work (Ford) we have enough A series oil filters to keep my car going for about 500 years, then we have the Ford ones so that should add a few thousand years to it lol
