The front wheel hub contains the Wheel bearings. The brake rotor bolts to the hub on disc brake models.
drum hub vs. disk hub - The drum hub is shorter, so that after the drum is placed over it, the track exactly matches the disc version.
The brake rotor bolts to the back of the hub (see Replacing Rotors)
full
hub slips onto spindle (which is on the bottom of the strut)
late Disc Brake Hub from 1989 October (not early B122)
Specs
The hub slips over the spindle, thus the bearing sizes must match
B110 Wheel bearings D1 spindle inner 25 mm bearing journal diameter (0.9840") D2 spindle outer 15 mm bearing journal diameter (0.5906") 1200 1976-up D1 spindle inner 27 mm bearing journal diameter (1.0625") D2 spindle outer 17.5mm bearing journal diameter (0.6875") B110 hub D1 hub inner 52 mm bore diameter (2.0470") D2 hub outer 42 mm bore diameter (1.6535") 1200 from 1976 D1 hub inner 50.3mm bore diameter (1.980") D2 hub outer 39.9mm bore diameter (1.570")
B110 Drum Hub EXTERNAL measurements * 135 mm diameter (disc hub is more than 140mm) * 47 mm height (disc hub is ~52 mm) * about 82 mm overall length
The drum hub is shorter, so that when the drum is placed over it the track exactly matches the disc version.
Spindle Comparo
Bearing Seal
See Wheel Bearings
Grease Caps
Replace the caps if grease is leaking out:
Buy at Bprojects
Larger size dust cover 43mm 40234-18000 CAP-HUB FRONT WHEEL * B10 * B110 * early B120 to 7510 * early B210 to 7510
Smaller caps 40 mm 40234-28500 CAP-HUB FRONT WHEEL * B310 (both hub types) * Late B210 from 7510 (both hub types) * Late B120 from 7510
180 Hubs
* Large Bearings * for small spindle
Nissan 40202-18000 hub fits: * Datsun B10 (1000) * Datsun B110 drum brake strut * Datsun 1200 truck to 7510 * Datsun 120Y drum brake strut to 7510
These use the large bearngs, and fit on the small spindles (early 1200 drum struts or disc struts). They have less track than the disc hubs.
H10 Hubs
Nissan 40202-H1005 hub fits: * Datsun B110 disc brake strut * Datsun 120Y disc brake strut to 7510
Will bolt to the early drum brake spindles & struts, but will increase track ~10 mm.
A08 Hubs
510 style bearings are 210 (outer) and A08 (inner). They are smaller O.D. than B110 bearings, but fit on larger spindles.
27mm inner bearing journal diameter 0.6875" outer bearing journal diameter
Hubs using A08 bearings include:
B120 1976- 40202-H7425 Drum Brake 40202-H7427 Disc Brake 8910-
B210 1976- Japan 40202-H7405 Disc Brake 40202-H7425 Drum Brake Japan 710 early 1973-1975 (-7602) 40202-22050 [disc] HUB ASSY-front wheel GL,SSS 40202-21050 [drum] HUB ASSY-front wheel STD,DX
Japan A10 Disc: S,K,HB (except STD), Van.GL B310 Disc: A14 & A15 40202-W5050 [disc] front HUB small bearings (210 & A08 bearings)
A01 Hubs
A01 are extra-large wheel bearings.
1.25" inner bearing journal diameter 0.75" outer bearing journal diameter See A0100 Wheel Bearings
95 mm Rotor bolt circle 70 mm height
40202-A0125 <> 40202-A0155 <> 40202-A0127 HITACHI buy at Bprojects PB210 7510- G HB210 USA 7508- S10/S110 7510-8308 GC10/GC110 6808-7510
USA 710 all (1974-1976) DISC BRAKES JAPAN GB211 (1976-1977) DISC BRAKES
Japan 710 late 1976-1977 (7509-7704) 40202-A0155 [disc] HUB ASSY-ROAD WHEEL FRONT 40202-N7150 [drum] HUB Van, LPG (taxi), Sedan.STD
Japan 810 40202-A0155 all disc brake models 40202-N7150 [drum] LPG + Van.DX
Japan A10 Drum: Sedan.STD, Van.STD, Van.DX 40202-N1750 [drum] front HUB large bearings (A01 bearings)
DRUM - ASSY-HUB ROAD WHEEL FRONT * B110: 40202-18051 DRUM BRAKE * B210: 40202-18000 DRUM 1974-1975 * B210: 40202-H7405 DRUM 1976-1978 Japan * B210: 40202-H7425 DRUM 7510- Van Japan * B210: 40202-H7425 DRUM 1976-1978 Japan
DISC - ASSY-HUB ROAD WHEEL FRONT * B110: 40202-H1005 DISC BRAKE * B210: 40202-H1005 DISC 1974-1975 GX * B210: 40202-22000 DISC -0775 USA * PB210: 40202-22050 DISC 1974-1975 * PB210: 40202-A0155 DISC 7510- * B210: 40202-A0155 DISC 0875- USA * B210: 40202-A0155 DISC 1976-1978 L16 Japan * B310: 40202-H7405 DISC, small rotor (Canada A12A) * B310: 40202-W5050 DISC, large rotor (A14/A15, A12A USA)
