Radio mounting
Revision as of 22:00, 28 August 2016; view current revision
Categories: Body Electrical System | Options
The radio mounts in the center of the dashboard, and is covered by the Dash Fascia.
[hide]
Stock Location
5023.jpgAlbum 5023
Alternate Mounting Locations
In center Console
834.jpgAlbum 834 4823.jpgAlbum 4823
Receiver in glovebox door
6655.jpgAlbum 6655 12040.jpgAlbum 12040
DIN Chassis
Most modern stereos are DIN-mounted, requiring you to use an alternate mounting location, or cut the metal dash to fit it.
amplifiers, equalizers, CD players, etc
You have to cut out the metal around the radio to fit a modern DIN-chassis receiver.
572.gifAlbum 572
mounted in rear-seat area
2250.jpgAlbum 2250
Glove Box
If you prefer not to cut the sheet metal on the Instrument Panel, you can mount it in the Glove Box:
6655.jpgAlbum 6655 22386.jpgAlbum 22386
Console
Mounted in the console, some modification required:
4823.jpgAlbum 4823
Fitting
Main Forum discussion
DIN-mount radios are the same size as the original, but do not have shafts in the front. Instead they attach at the sides of the radio.
24075.jpgAlbum 24075
First, cut out the facia. Cut out the metal around the radio to fit a modern DIN-chassis receiver:
23172.jpgAlbum 23172
Rectangle cut larger, radio shaft holes now missing
Compare to an uncut dash:
24074.jpgAlbum 24074
Fabricate a DIN adapter bracket (or modify a commercial one).
Create a bezel, by modifying the stock radio delete plamote:
5304.jpgAlbum 5304
Carefully cut the center out of the delete plate:
Fit the bezel to the radio:
Finished product:
