The Rear Engine Crossmember is more commonly called the gearbox crossmember. This transmission crossmember hold the rear engine mount (transmission mount). The B210 and B310 crossmembers are wider than the B110 crossmember.
Manual Transmission
B110
- 11322-H1002 MEMBER-engine mounting, rear 3-speed, 4-speed
- 11322-H7200 MEMBER-engine mounting, rear 5-speed
- superceded by 11322-H7201 from 7210
- 11322-H5000 MEMBER-engine mounting, rear 3-speed, 4-speed (56-series)
- 11322-H7400 MEMBER-engine mounting, rear from 7510 Van (also replaces 11322-H5000)
- 11322-H7500 MEMBER-engine mounting, rear A14 B210 60-series 4-speed
- 11322-H5700 MEMBER-engine mounting, rear A12 5-speed F5C56
- 11341-H7500 MEMBER-engine mounting, rear A14 B210 5-speed 63-series
Automatic Transmission
- 11322-H1020 MEMBER-engine mounting, rear Automatic B110
- 11322-H5200 MEMBER-engine mounting, rear Automatic early B210
- 11340-H7500 MEMBER-engine mounting, rear Automatic late B210
Gearbox Rubber Mount
There are different types of rear engine mounts (transmission mounts).
- The 56-Series Transmission type of mount bolts to the crossmember from the sides of the mount, just like these stock 1200 mounts:
- PN 11321-H1000 INSULATOR ASS'Y-engine mounting, rear manual trans: B110, B210, B310 56-series transmission
- This type, used with 60-Series Transmission, bolts from the bottom:
- PN 11321-H7500 INSULATOR ASS'Y-engine mounting, rear manual trans: A14 B210 4-speed
- PN 11323-H7400 INSULATOR ASS'Y-engine mounting, rear manual trans: late A12 B210 Sedan, Coupe
- PN 11323-H7510 INSULATOR ASS'Y-engine mounting, rear manual trans: A14 B210 5-speed
- PN 11321-H1020 INSULATOR ASS'Y-engine mounting, rear auto trans B110
- PN 11321-H2521 INSULATOR ASS'Y-engine mounting, rear auto trans early B210
- PN 11321-H7321 INSULATOR ASS'Y-engine mounting, rear auto trans late B210
