The front window is a known as a windshield or windscreen.
- Sedan/Truck/Van windshields differ from Coupe windshield
- Sedan & Van are the same by part number (per Nissan catalog)
- Coupe differs from all others (20.5 inches ~52.1 cm top to bottom)
- Truck reportedly same as sedan (53cm top to bottom)
Trix fitted a B140 windscreen to his 1200 coupe, he used filler to make up the gaps:
Jeff fitted [coupe?] glass to his ute after sanding the corners down:
And spacing the glass to fill the gap
Removal and Installation
SEDAN
- 72613-H1902, 72613-H1901 GLASS-WINDSHIELD PL (clear) T=6.6 2-dr SEDAN USA
- 72613-H1903, 72613-H1900 GLASS-WINDSHIELD PLT (tinted) T=6.6 OP 2-dr SEDAN USA
- 72613-H1003 GLASS-windshield from '70 Aug S-Std JDM replaces 72613-H1002
- 72613-H1103 GLASS-windshield from '70 Aug S-DX, S-GL, 4GX JDM replaces 72613-H1102
- 76210-H1001 WEATHERSTRIP-windshield from '70 Aug Sedan, Van replaces 76210-H1000
COUPE
- 72613-H1910,72613-H1913 GLASS-WINDSHIELD (tinted) T=6.6 Coupe USA
- 72613-H1802 GLASS-windshield Coupe from '70 Aug JDM replaces 72613-H1801
- 76210-H1801 WEATHERSTRIP-windshield from '70 Aug Coupe replaces 76210-H1800
TRUCK
- 72613-H1002 GLASS-windshield, front ALL (exc. B-T,GB-T) -7509
- 72613-H1102 GLASS-windshield, front B-T,GB-T -7509
- 72613-H1102 GLASS-WINDSHIELD all 7510-8611
- 72613-G1900 GLASS-WINDSHIELD all 8611-
- 72610-G1000 WEATHERSTRIP-WINDSHIELD all
VAN
- 72613-H1003 GLASS-windshield, front from '70 Aug V-Std replaces 72613-H1002 VS, VP
- 72613-H1103 GLASS-windshield, front from '70 Aug V-Dx, V-P replaces 72613-H1102
- 76210-H1001 WEATHERSTRIP-windshield Sedan, Van
2-dr Sedan & Pickup
- 80238-H1001 BRACKET-PIVOT TOP LOW $10.50 USD
- 80234-H1000 WASHER-BRACKET PIVOT $5.83 USD
- 80284-H1000 WASHER-RUBBER A $0.62 USD
- 80285-H1000 WASHER-RUBBER B $0.62 USD
- 08330-41020 SCREW-MACHINE M4 $0.80 USD
- 80292-73000 RIVET-SPECIAL [CLIP-TUBULAR] NLA
Rubber Seals
See Also: Rubber#Suppliers
- 72610-H1001,72610-H1000 WEATHERSTRIP-WINDSHIELD 2-dr SEDAN $95.37 USD
- 72610-H1800,72610-H1801 WEATHERSTRIP-WINDSHIELD Coupe $107 USD
Coupe Windshield Weatherstrip
Moulding Trim Sedan & Van
S-DX, S-GL, 4-GX, Van-Dx
Early style: single upper piece
- 72810-H1100 SET-MOULDING, windshield
- 72812-H1100 MOULDING-windshield, upper
- 72814-H1100 MOULDING-windshield, side (R.H.)
- 72815-H1100 MOULDING-windshield, side (L.H.)
- 72813-H1100 MOULDING-windshield, lower
From '70 June: tree-piece upper
The SET replaces the earlier SET, but not vice-versa
- 72810-H1101 SET-MOULDING, windshield S-DX, S-GL, 4-GX, V-DX, V-P
- 72811-H1101 MOULDING-windshield, upper (R.H.)
- 72812-H1101 MOULDING-windshield, upper (L.H.)
- 72814-13600 CLIP-moulding
- 72814-H1101 MOULDING-windshield, side (R.H.)
- 72815-H1101 MOULDING-windshield, side (L.H.)
Moulding Trim Coupe
- 72810-H1800 SET-MOULDING, windshield
- 72812-H1800 MOULDING-windshield, upper
- 72814-H1800 MOULDING-windshield, side (R.H.)
- 72815-H1800 MOULDING-windshield, side (L.H.)
- 72813-H1800 MOULDING-windshield, lower
- 72810-H1801 SET-MOULDING, windshield S-DX, S-GL, 4-GX
- 72811-H1801 MOULDING-windshield, upper (R.H.)
- 72812-H1801 MOULDING-windshield, upper (L.H.)
- 72814-H1801 MOULDING-windshield, side (R.H.)
- 72815-H1801 MOULDING-windshield, side (L.H.)
Moulding Trim Truck
74-up Truck uses 8-piece molding set. Has L-shaped pieces in the corners.
- 72810-G1000 MOULDING SET-WINDSHIELD 7510- ALL
- 72810-G1000 MOULDING SET-windshield-7509 DX
- 72812-G1000 MOULDING-windshield, upper
- 72813-G1000 MOULDING-windshield, lower
- 72814-G1000 MOULDING-windshield, side (R.H.)
- 72815-G1000 MOULDING-windshield, side (L.H.)
- 72816-G1000 CORNER-windshield, upper (R.H.)
- 72817-G1000 CORNER-windshield, upper (L.H.)
- 72818-G1000 CORNER-windshield, lower (R.H.)
- 72819-G1000 CORNER-windshield, lower (L.H.)
