Datsun B310 dashboard had round gauges, and later changed for 80s style.
Early Style for all Round Headlight models (1977-1979)
Early: Individual pods for gauges of instrument panel Late: Single large opening for instrument panel
Late Style for Square Headlight models (1980-1982)
full
Early
1977-1979 + all Japan VB310 van (all round headlight models) used a wide driver's "cockpit" that encompassed the radio and center vents.
NOTE: LHD has the two side pods reversed
Right LHD: Clock
Left RHD: Clock
Small Left: single: clock mask
double: Fuel/Temp (Coupe GX)
Large Center Gauges
* Left: Speedometer
* Right: Water/Fuel (sedan)
Blank with idiot lamps
Econometer (coupe A14.GL)
Tachometer (coupe GX)
Small Right:
* Single: Water/Fuel with idiot lights (oil/brake)
* Double: stacked Volt/Amp (coupe GX)
Left Clock (digital)
full
Left Clock (analog)
full
GL
full
GXE
full
SGX
full
See: #Cluster Lid
full
Japan California
Sunny California (wagon)
full
full
full
Van
Australia
USA Coupe
full
full
full
full
full
full
full
USA Sedan
large speedometer flanked by OPTION tachometer
full
full
full
full
To left of speedometer is smaller temp/water gauge
full
Small left side round pod is Clock Blank
full
Tachometer blank with idiot lamps (Oil/Amps)
full
full
full
full
full
Tachometer
Tachometer Yellow Zone * Carburetor 6000-6250 * EGI 6400-6800GX-E
TACHOMETER ASSY 24855-H8700 *K.(DX+GL) -7811 24855-H8701 *K.(DX+GL) 7812- CLEAR LAMP 24855-H9200 (S+K).GX 24855-H9201 (S+K).A14E
Clock
2+4 dash: CENTER STACK CLOCK, sealed shield 2+2 dash: left-side CLUSTER CLOCK, clear shield GX,DX,GL analog SGL, SGX digital
CLOCK K,S.SGX 27380-H9210 DIGITAL QUARTZ LUMINOUS SPORT INST -7804 27380-H9211 DIGITAL QUARTZ LUMINOUS SPORT INST -7805-7909
Late
1980-1982 switched to a smaller driver's "cockpit" that included just the instrument panel -- the radio and center vents were outside of this area. Japan vans stayed with the early style.
H85 single side gauges
Speedometer + Idiot Lamps S,W except SGX
Speedometer + Tachometer Coupe except SGX
H92 double side gauges S,K.SGX
2+2 cluster Wagon/Sedan (except SGX)
Sedan/Wagon
SEDAN/WAGON GAUGES (except SGX) Round or Digital Clock (or 'NISSAN' clock mask) Speedometer Large Fuel/Temperature Idiot Lamp
NO tachometer option
Idiot Lamps (Large Fuel/Temperature) * 'CHG' with BATTERY symbol * OIL symbol
Idiot Lamp (Small pod) two variations * H85 S,W.GL#,DX# BRAKE or * H92 S.GX CHG
2x2 cluster (2 large, 2 small)
Coupe
COUPE GAUGES (except SGX) Round Clock (or 'NISSAN' clock mask) Speedometer Tachometer Small Fuel/Temperature
Idiot Lamp BATTERY (bottom of tachometer)
SGX
SGX/SGX-E GAUGES Digital Quartz Clock Fuel Speedometer (160kph) Tachometer Oil Pressure Water Temperature
Idiot Lamp BATTERY symbol (bottom of tachometer) MASKED: Idiot Lamp Meter strip (bottom of cluster)
SGX-E 6800 RPM tachometer for EGI
Monitor Lamp Strip
Six variations, including two blank strips.
Masks are placed at bottom of cluster (where photo is labeled "Delete Plate")
Inspection Monitor Lamp strip 25040-H8563?
SGX with full Monitor Lamps (all six icons)
68450-H8501 MASK 7910- CT,S.DX,SPT,ES+W.DX, SGX
25040-xxxxx LAMP ASSY [six variations]
H8500 EXH TEMP,BRAKE,FUEL
H8562 FUEL,DOOR
H8761 EXH TEMP,BRAKE,FUEL,DOOR,TAIL,STOP
H9201 EXH TEMP,BRAKE,FUEL,DOOR
H8563 FUEL,DOOR,TAIL,STOP
H8611 CT/DX [blank]
H8761 SGX [blank]
USA BRAKE
Tachometer
All Coupe and Sedan.SGX get a tachometer. There is no room for tachometer on Wagon, Van or regular Sedan dash.
H90 dual idiot lights at bottom H92 single idiot light at bottom
TACHOMETER ASSY 24855-H9020 K-(K.SGX#,K.RSE),W.GX 24855-H9021 K.RSE,S.GXE 24855-H9215 (4S+K).SGX [std redline] 24855-H9216 (4S+K).SGXE [EFI redline]
LENS 68435 25021-H9020 K-SGX# S.(GX#+SGL) OIL,BATTERY 25026-H8503 S,W.GL#,DX. BRAKE 25026-H9215 S.GX CHG
Cluster Lid
Early - individal gauge lenses Late - one big opening for all gauges
H850 DX H851 Late Model H856 GL H86 CITY + DX.WAGON H92 GX H94 Van STD late
CLUSTER LID
68420-H8500 DX BLACK
68420-H8501 DX BROWN
68420-H8510 7910- BLACK
68420-H8511 7910- BROWN
68420-H8560 GL BLACK
68420-H8561 GL BROWN
68420-H8600 CT BLACK W.DX
68420-H8601 CT BROWN W.DX
68420-H9200 GX# BLACK
68420-H9201 GX# BROWN
68420-H9400 BROWN
7812- V.STD
8011- V.A12.STD
8110- V.A12.DXA
68420-H9460 8011- BLACK V.A12.STD,DXA
NOTE: DXA was a trim only available with 2-seat Van (VB312R)
