<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference A12GX Carburetor Part Numbers
1971
CARBURETOR (TWIN)
16010-H2330 ASS'Y-CARBURETOR, twin, front GX 16010-H2332 ASS'Y-CARBURETOR, twin, front (from '70-Jul.) GX < 16010-H2332 16010-H2331 ASS'Y-CARBURETOR, twin, rear GX 16010-H2333 ASS'Y-CARBURETOR, twin, rear (from '70-Jul.) GX < 16010-H2331 1 16122-H2310 ASS'Y-SHAFT, throttle GX 2 16324-H2310 ASS'Y-FILTER, piston GX 3 16144-H2310 ASS'Y-NUT, idle adjusting GX 4 16355-H2310 ASS'Y-NOZZLE GX 5 16127-H2310 ASS'Y-PLATE, throttle adjusting, front GX 5 16127-H2311 ASS'Y-PLATE, throttle adjusting, rear GX 6 16277-H2310 ASS'Y-LEVER, first idle, front GX 6 16277-H2312 ASS'Y-LEVER, first idle, front (from '70-Jul) GX < 16277-H2310 6 16277-H2311 ASS'Y-LEVER, first idle, rear GX 6 16277-H2313 ASS'Y-LEVER, first idle, rear (from '70-Jul) GX < 16277-H2311 8 16083-58000 SLEEVE 2 GX 9 16214-25610 NUT (8ø) 2 GX 9-1 16116-H2310 SLEEVE (from '71-May) 2 GX 10 16190-10401 SPRING-starter, return (B) GX 16190-73410 SPRING-starter, return (A) GX 11 16147-14611 PLATE-cam (B) GX 16147-73411 PLATE-cam (A) GX 12 16116-14610 SLEEVE (B) 2 GX 13 16157-14610 SPRING-connecting (B) GX 16157-73410 SPRING-connecting (A) GX 16238-H2310 ASS'Y-LEVER, choke, front GX 14 16238-H2311 ASS'Y-LEVER, choke, rear GX 16147-H2310 PLATE-connecting, front GX 15 16147-H2311 PLATE-connecting, rear GX 16227-H2310 ADAPTER-front GX 16 16227-H2311 ADAPTER-rear GX 17 16233-E3210 BOLT (8ø) 2 GX 18 16356-25610 PIPE-rubber, fuel 2 GX 19 16358-E4310 CLIP-fuel pipe 4 GX 20 16061-10400 FLOAT 2 GX 21 16101-H1000 ASS'Y-VALVE, needle 2 GX 22 16062-10400 LEVER-float 2 GX 23 16066-25610 SHAFT-float 2 GX 24 16331-10400 SCREW-nipple set 2 GX 25 16098-25710 FILTER 2 GX 26 16554-H2310 JET-needle 2 GX 27 16031-10560 PLUG-drain 2 GX 16031-A8710 PLUG-drain 2 GX 2 16031-10560 16418-H2310 CLAMP-choke, front GX 28 16419-H2310 CLAMP-choke, rear GX 29 16346-10615 SPRING-suction 2 GX 30 16341-25610 ASS'Y-NUT, oil cap 2 GX 31 16194-H2310 SPRING-throttle 2 GX
16455-H2310 SET-GASKET GX A 16335-14610 PACKING (10ø) 4 GX B GASKET-float chamber 2 GX C WASHER (8ø) 2 GX D PACKING (18ø) 2 GX E WASHER (10ø) 2 GX
16475-H2310 SET-SCREW & WASHER "B" GX F PACKING (12.5ø) 2 GX G WASHER (7ø) 4 GX H WASHER (5ø) 2 GX WASHER (4ø) 2 GX I PING-cotter (1ø) 2 GX J WASHER-thrust 2 GX K BOLT (5ø) 2 GX BOLT (5ø) 2 GX L WASHER-clock (7ø) 2 GX M SET-screw, needle jet 2 GX
16465-H2310 SET-SCREW & LOCK WASHER "A" GX N SCREW (5ø X 16) 16 GX O SCREW (5ø X 12) 2 GX SCREW (4ø X 10) 2 GX SCREW (4ø X 8) 4 GX P WASHER-lock (8ø) 4 GX Q WASHER-lock (5ø) 18 GX R WASHER-lock (4ø) 2 GX
