Rear Door Fitting Part Numbers
Revision as of 02:34, 4 September 2017; view current revision
Categories: Body | Catalog
<-- back to Part Numbers Index
Also see: Main articles for usage, photos, cross-reference
Window Regulator for Window Winder/Regulator Handle
Door Lock (door latch and door handle)
Rear Door Glass
For rear door corner glass, see Rear Door Part Numbers
SEDAN REAR DOOR WINDOW
1 82310-H1000 GLASS-rear door (R.H.) STD
  82310-H1100 GLASS-rear door (R.H.) DX,GL,GX
  82311-H1000 GLASS-rear door (L.H.) STD
  82311-H1100 GLASS-rear door (L.H.) DX,GL,GX
2 82302-H1000 ASS'Y-BOTTOM, channel (R.H.)
  82303-H1000 ASS'Y-BOTTOM, channel (L.H.)
3 82316-H1000 RUBBER-glazing (2)
4 82335-H1000 RUBBER-glass run "C" (2) < 82335-H1001
  82335-H1001 RUBBER-glass run "C" (2) (from '70-Oct)
VAN REAR DOOR WINDOW
1 82310-H1400 GLASS-rear door (R.H.) VS,VP
  82310-H1500 GLASS-rear door (R.H.) V-DX
  82311-H1400 GLASS-rear door (L.H.) VS,VP
  82311-H1500 GLASS-rear door (L.H.) V-DX
4 82335-H1400 RUBBER-glass run "C" (2)
REAR DOOR LOCK & REMOTE CONTROL (4 DOOR SEDAN & VAN)
* 82500-H1001 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (R.H.) <> 82500-H1102
  82500-H1002 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (R.H.) (from '71-Jan)
* 82501-H1001 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (L.H.) < 82501-H1102
  82501-H1002 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (L.H.) (from '71-Jan)
 5 82502-H1001 ASS'Y-DOOR LOCK, rear (R.H.) <> 82502-H1002
   82502-H1002 ASS'Y-DOOR LOCK, rear (R.H.) (from '71-Jan) <> 82502-H3100
   82502-H3100 DOOR LOCK ASS'Y, rear (R.H.) (from '72-8)
   82503-H1001 ASS'Y-DOOR LOCK, rear (L.H.) <> 82503-H1002
   82503-H1002 ASS'Y-DOOR LOCK, rear (L.H.) (from '71-Jan) <> 82503-H3100
   82503-H3100 DOOR LOCK ASS'Y, rear (L.H.) (from '72-8)
 6 80504-H1001 ASS'Y-REMOTE CONTROL, front door (R.H.)
   80505-H1001 ASS'Y-REMOTE CONTROL, front door (L.H.)
 7 80508-H1000 SPRING-door lock (R.H.)
   80509-H1000 SPRING-door lock (L.H.)
     fixing door lock
 8   08320-61219 SCREW-with lock washer (6)
     or, fixing door lock
 8   08320-61012 SCREW (6)
 9   08916-43610 WASHER-tooth lock (6)
     fixing remote control
10   08310-61226 SCREW-with washer (6)
     or, fixing remote control
10   08310-61214 SCREW-with washer (6)
11   08915-43610 WASHER-plain (6)
REAR DOOR HANDLE (4 DOOR SEDAN & VAN)
12 82605-H1000 ASS'Y-HANDLE, door outside (R.H.)
   82606-H1000 ASS'Y-HANDLE, door outside (L.H.)
13   01221-00023 NUT (4)
REAR DOOR REGULATOR (4 DOOR SEDAN & VAN)
14 80760-H1000 ASS'Y-HANDLE, door window regulator (2)
15 80675-H1000 WASHER-handle, door regulator (2)
16   08330-51220 SCREW (2)
17 82700-H1000 ASS'Y-REGULATOR, rear door window (R.H.) <> 82700-H1001
   82700-H1001 ASS'Y-REGULATOR, rear door window (R.H.)
   82701-H1000 ASS'Y-REGULATOR, rear door window (L.H.) <> 82700-H1001
   82701-H1001 ASS'Y-REGULATOR, rear door window (L.H.)
     fixing regulator
18   08310-61014 SCREW-with lock washer (6)
     Or, fixing regulator
18   08310-61012 SCREW (6)
19   08915-13610 WASHER-lock (6)
20 80570-21000 ASS'Y-STRIKER, door lock (R.H.)
   80571-21000 ASS'Y-STRIKER, door lock (L.H.)
21 80571-24800 SHIM-striker (2)
     fixing striker
22   08360-61614 SCREW-with lock washer
     or, fixing striker
22   08440-61212 SCREW (6)
23   08916-33610 WASHER-tooth lock (6)
24 80510-H1000 ESCUTCHEON-remote control (R.H.)
   80511-H1000 ESCUTCHEON-remote control (L.H.)
25   08330-50620 SCREW (fixing escutcheon) (2)
26 80595-21003 KNOB-door lock (2) <> 80595-N1600
   80595-N1600 KNOB-door lock (from '71-Apr) (2)
27 80970-21000 GROMMET-knob (2)
28 80515-E0100 BUSH-bell crank (2)
     fixing bell crank
29   08310-61414 SCREW-with washer (2)
30   08915-53610 WASHER-plain (2)
31 H0510-21001 HOLDER-rod (nylon) (2)
32 80517-H1000 SHIELD-inside handle (2)
