<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Body Side
Contents[hide] |
[edit]
4 DOOR SEDAN ASSY-CENTER PILLER OUTER RH 76500-H1009 SEDAN 4 DOOR + WAGON 4 DOOR from January 1972 RH 76500-H1000 SEDAN 4 DOOR + WAGON 4 DOOR LH 76501-H1009 SEDAN 4 DOOR + WAGON 4 DOOR from January 1972 LH 76501-H1000 SEDAN 4 DOOR + WAGON 4 DOOR
ASSY-CENTER PILLER INNER RH 76522-H1059 SEDAN 4 DOOR + WAGON 4 DOOR from January 1972 RH 76522-H1050 SEDAN 4 DOOR + WAGON 4 DOOR LH 76523-H1059 SEDAN 4 DOOR + WAGON 4 DOOR from January 1972 LH 76523-H1050 SEDAN 4 DOOR + WAGON 4 DOOR
76412-H1201 PANEL-SILL OUTER RH SEDAN 2 DOOR 76412-H4501 PANEL-SILL OUTER RH SEDAN 2 DOOR 0171-
4 DOOR SEDAN 68 76412-H1001 PANEL-sill, outer (R.H.) 4 door 69 76413-H1001 PANEL-sill, outer (L.H.) 4 door 45 74320-H1000 ASS'Y-FLOOR SIDE (R.H.) sedan 46 74321-H1000 ASS'Y-FLOOR SIDE (L.H.) sedan
2 DOOR SEDAN 91 76320-H1201 ASS'Y-PANEL, body side inner (R.H.) 2 door 92 76321-H1201 ASS'Y-PANEL, body side inner (L.H.) 2 door 93 76412-H1201 PANEL-body sill, outer (R.H.) 2 door 94 76413-H1201 PANEL-body sill, outer (L.H.) 2 door
[edit]
Truck
[edit]
[edit]
Sedan
1 76200-H1000 ASSY-FRONT PILLAR RH SEDAN 2 DOOR 2 76201-H1000 ASSY-FRONT PILLAR LH SEDAN 2 DOOR 3 76230-H1000 ASSY-WINDSHIELD PILLAR INNERRH SEDAN 2 DOOR 4 76231-H1000 ASSY-WINDSHIELD PILLAR INNERLH SEDAN 2 DOOR 5 64118-H1000 REINF-HOODLEDGE,UPPER,RH SEDAN 2 DOOR 0970- 5 64120-H1000 REINF-HOODLEDGE,UPPER,RH SEDAN 2 DOOR 6 64121-H1000 REINF-HOODLEDGE,UPPER,LH SEDAN 2 DOOR 6 64119-H1000 REINF-HOODLEDGE,UPPER,LH SEDAN 2 DOOR 0970- 7 76240-H1600 ASSY-DASH SIDE RH SEDAN 2 DOOR 7 76240-H1000 ASSY-DASH SIDE RH SEDAN 2 DOOR 0171- 8 76241-H1600 ASSY-DASH SIDE LH SEDAN 2 DOOR 8 76241-H1000 ASSY-DASH SIDE LH SEDAN 2 DOOR 0171- 9 76310-H1200 ASSY-RAIL ROOF SIDE OUTER RH SEDAN 2 DOOR 9 76310-H3600 ASSY-RAIL ROOF SIDE OUTER RH SEDAN 2 DOOR 0172- 10 76311-H1200 ASSY-RAIL ROOF SIDE OUTER LH SEDAN 2 DOOR 10 76311-H3600 ASSY-RAIL ROOF SIDE OUTER LH SEDAN 2 DOOR 0172- 11 76322-H1200 PANEL-RAIL ROOF SIDE INNER RH SEDAN 2 DOOR 12 76323-H1200 PANEL-RAIL ROOF SIDE INNER LH SEDAN 2 DOOR 13 76320-H1201 ASSY-PANEL BODY SIDE INNER RH SEDAN 2 DOOR 13 76320-H1209 ASSY-PANEL BODY SIDE INNER RH SEDAN 2 DOOR 0172- 14 76321-H1201 ASSY-PANEL BODY SIDE INNER LH SEDAN 2 DOOR 14 76321-H1209 ASSY-PANEL BODY SIDE INNER LH SEDAN 2 DOOR 0172- 15 76412-H1201 PANEL-SILL OUTER RH SEDAN 2 DOOR 15 76412-H4501 PANEL-SILL OUTER RH SEDAN 2 DOOR 0171- 16 76413-H1201 PANEL-SILL OUTER LH SEDAN 2 DOOR 16 76413-H4501 PANEL-SILL OUTER LH SEDAN 2 DOOR 0171- 17 76500-H1209 ASSY-CENTER PILLER RH SEDAN 2 DOOR 0172- 17 76500-H1200 ASSY-CENTER PILLAR RH SEDAN 2 DOOR 18 76501-H7000 ASSY-CENTER PILLAR LH SEDAN 2 DOOR 0772- 18 76501-H1200 ASSY-CENTER PILLAR LH SEDAN 2 DOOR 18 76501-H1209 ASSY-CENTER PILLAR LH SEDAN 2 DOOR 0172- 19 76712-H1201 PANEL-REAR WHEEL HOUSE OUTERRH SEDAN 2 DOOR 20 76713-H1201 PANEL-REAR WHEEL HOUSE OUTERLH SEDAN 2 DOOR 21 76722-H1000 PANEL-REAR WHEEL HOUSE INNERRH SEDAN 2 DOOR 21 76720-H1000 PANEL-REAR WHEEL HOUSE INNERRH SEDAN 2 DOOR 22 76723-H1000 PANEL-REAR WHEEL HOUSE INNERLH SEDAN 2 DOOR 22 76721-H1000 PANEL-REAR WHEEL HOUSE INNERLH SEDAN 2 DOOR 23 76730-H1000 ASSY-BRACKET SHOCK ABSORBER MOUNTING RH SEDAN 2 DOOR 24 76731-H1000 ASSY-BRACKET SHOCK ABSORBER MOUNTING LH SEDAN 2 DOOR 25 76742-H1000 PLATE-CLOSING SILL REAR RH SEDAN 2 DOOR 26 76743-H1000 PLATE-CLOSING SILL REAR LH SEDAN 2 DOOR 27 74554-H1000 PANEL-T/F SIDE LOWER RH SEDAN 2 DOOR 28 74555-H1000 PANEL-T/F SIDE LOWER LH SEDAN 2 DOOR
[edit]
Coupe
1 76200-H1800 ASSY-FRONT PILLAR RH COUPE 2 76201-H1800 ASSY-FRONT PILLAR LH COUPE 3 76230-H1800 ASSY-WINDSHIELD PILLAR INNERRH COUPE 4 76231-H1800 ASSY-WINDSHIELD PILLAR INNERLH COUPE 5 64120-H1000 REINF-HOODLEDGE UPPER RH COUPE 5 64118-H1000 REINF-HOODLEDGE UPPER RH COUPE 0970- 2 64120-H1000 6 64121-H1000 REINF-HOODLEDGE UPPER LH COUPE 6 64119-H1000 REINF-HOODLEDGE UPPER LH COUPE 0970- 2 64121-H1000 7 76240-H1000 ASSY-DASH SIDE,RH COUPE 8 76241-H1000 ASSY-DASH SIDE,LH COUPE 9 76312-H1851 ASSY-PANEL ROOF RAIL SIDE OUT RH COUPE 9 76310-H4050 ASSY-RAIL ROOF SIDE OUTER RH COUPE 0172- 2 76312-H1851 10 76313-H1851 ASSY-PANEL ROOF RAIL SIDE OUT LH COUPE 10 76311-H4050 ASSY-RAIL ROOF SIDE OUTER LH COUPE 0172- 2 76313-H1851 11 76322-H1800 PANEL-RAIL ROOF SIDE INNER RH COUPE 12 76323-H1800 PANEL-RAIL ROOF SIDE INNER LH COUPE 13 76320-H1805 ASSY-PANEL BODY SIDE INNER RH COUPE 13 76320-H1855 ASSY-PANEL BODY SIDE INNER RH COUPE 2 76320-H1805 14 76321-H1805 ASSY-PANEL BODY SIDE INNER LH COUPE 14 76321-H1855 ASSY-PANEL BODY SIDE INNER LH COUPE 0970- 2 76321-H1805 15 76412-H1800 PANEL-SILL OUTER RH COUPE 16 76413-H1800 PANEL-SILL OUTER LH COUPE 17 76500-H1809 ASSY-PILLAR LOCK RH COUPE 0172- 2 76500-H1850 17 76500-H7100 ASSY-PILLAR LOCK RH COUPE 0772- 2 76500-H1809 17 76500-H1850 ASSY-PILLAR LOCK RH COUPE 18 76501-H1850 ASSY-PILLAR LOCK LH COUPE 18 76501-H1809 ASSY-PILLAR LOCK LH COUPE 0172- 2 76501-H1850 18 76501-H7100 ASSY-PILLAR LOCK LH COUPE 0772- 2 76501-H1809 19 76720-H1800 ASSY-WHEEL HOUSE INNER REAR RH COUPE 20 76721-H1800 ASSY-WHEEL HOUSE INNER REAR LH COUPE 21 76742-H1800 PLATE-CLOSING SILL REAR RH COUPE 22 76743-H1800 PLATE-CLOSING SILL REAR LH COUPE 23 78120-H1800 ASSY-DRIP FENDER REAR RH COUPE 24 78121-H1800 ASSY-DRIP FENDER REAR LH COUPE 25 76808-H1800 RUBBLER-FINISH LOCK FILLER (2) COUPE
