Clutch Diagnoses
Revision as of 02:24, 15 July 2018; view current revision
Category: Clutch
Noise when pedal pressed
Noise when pedal released
  • Worn Gearbox Bearing [Input Shaft Bearing]
Clutch Won't Release Fully
Difficult to shift gears due to failure to fully release
  • improper adjustment of linkage
  • incorrect length of Release Bearing sleeve fitted
Grabby clutch
  • Drum shoe brakes too tight, or contaminated with oil or grease. Inspect drum brakes
  • Oil or grease on clutch face
  • Disc rivets loose
  • Poorly lubricated clutch disc splines
  • warped pressure plate
  • Misaligned clutch. Make sure there is no junk between gearbox
  • worn clutch cable (common with RHD clutches)
  • Worn lining. Replace disc
Clutch Slips
  • improper adjustment of linkage (no free play)
  • worn disc[[Category:Diagnoses and Corrections}}
