<-- back to 56-Series Transmission Parts
See also: Shifter
STRIKING ROD fits into extension housing
Gearshift lever fits into GUIDE
| Contents |
Striking Rod
GUIDE with plug. After inserting the ROD, put the plug in
17 32892-H7200 PLUG-checking ball 3 18 32896-H7200 LEVER-striking 19 32917-H7200 PIN-lock 20 08915-13610 WASHER-lock 21 08915-53610 WASHER-plain 22 08911-20610 NUT-hex 23 32850-H7200 GUIDE ASS'Y-striking rod 24 * 32845-24900 PIN-ret, striking rod 2 25 32857-14600 CAP-ring O 26 32858-14600 RING O, striking rod 30 00933-32800 PLUG-expansion
Shift Return Spring & Plunger
PLUNGER and RETURN SPRING fits into the extension housing
31 32851-24900 PLUNGER-return spring 32 32852-24901 SPRING-return 33 32856-24901 SPRING-reverse check 34 32853-E9300 PLUG-return
Shift Rails
Shift Lever
Shift Arm Bracket
STRIKING LEVER has two pins & two nuts:
1. Fastens BRACKET to STRIKING LEVER
2. Fastens STRIKING LEVER to striking rod
