Painting
Revision as of 00:14, 30 October 2021; view current revision
Categories: Body | Paint
See also: Colors
Prices
[written in 2013]
A standard acrylic enamel non-metallic paint job (door closed) starts at $450 in USA to paint the entire car.
A typical budget paint job is more like $1500 USD which includes small amounts of minor bodywork.
A 'show car' metallic paint job starts at $5000 USD. But if you want to win the car show, $15,000 is not out of line.
Double these prices for Australia.
Paint Types
The original 1200 paint was "amino alkyd enamel" (a type of synthetic enamel), which is tough, durable and sprays on shiny. It's a good choice. Enamel won't dull if waxed. All new cars have used enamel since the 1960s. The older type is acrylic lacquer and requires initial buffing and is not as durable as enamel, but can be layered and buffed for a superior shine.
Alkyd Enamel dries shiny, needs no buffing, but takes a little longer to dry than 2-pak Enamel. And is inexpensive. A lot of old guys recommend acrylic lacquer for its superior deep shine, but that needs buffing and rubbing.
  • Single package coatings (1-pak) are less expensive and provide good results, but take longer to dry.
  • Two package coatings (2-pak) seal/harden/gloss the paint and dry quickly. Classic two package epoxies or polyurethanes fall into this category.
Newer cars use a base coat and clear-coat. The results can be better (or worse) than single-coat Acrylic Enamel.
1K: (single-pack) a coating that does not require a hardener, catalyst or activator. A "single-component" paints. Not the same as a "single stage" paint.
2K: (two-pack) an epoxy type coating that needs to be mixed with a hardener, catalyst or activator. A "two-component" paint, include Two Pack Acrylic Enamel, and urethane paints. 2K paint requires a full respirator to shoot, although a mask is always recommended.
CLEAR COAT
  • Single-Stage: a coating that does not require a clear top coat. A single-stage coating may or may not require a catalyst, hardener or activator.
  • Two-Stage: a coating system that requires both base and clear coats. This is more commonly referred to as "basecoat/clearcoat" or "BC/CC". The coats of base and clear may or may not require a catalyst, hardener or activator.
  • A clear top coat even when not required may be added for enhanced durability or depth.
  • Easy to paint: Regular is easier than Metallic
  • Easy to maintain: Do not use lacquer paint. Use either Acrylic Enamel (as per original Datsun paint) -- or -- the newer 2-part expoxy paints with a clearcoat finish.
  • Safer to paint: Acrylic Enamel won't kill you, as can spraying epoxy paint without a full-mask.
How To Paint
Retal052 shows how it is done.
15746.jpgAlbum 15746 15747.jpgAlbum 15747 15748.jpgAlbum 15748 15749.jpgAlbum 15749 15750.jpgAlbum 15750 15751.jpgAlbum 15751 15752.jpgAlbum 15752 15753.jpgAlbum 15753 15754.jpgAlbum 15754 15755.jpgAlbum 15755 15756.jpgAlbum 15756 15757.jpgAlbum 15757 15758.jpgAlbum 15758 15759.jpgAlbum 15759 15760.jpgAlbum 15760 15761.jpgAlbum 15761 15762.jpgAlbum 15762 15763.jpgAlbum 15763 15764.jpgAlbum 15764 15765.jpgAlbum 15765 15766.jpgAlbum 15766 15767.jpgAlbum 15767 15768.jpgAlbum 15768 15769.jpgAlbum 15769 15770.jpgAlbum 15770 15771.jpgAlbum 15771 15772.jpgAlbum 15772 15773.jpgAlbum 15773 15774.jpgAlbum 15774 15775.jpgAlbum 15775 15776.jpgAlbum 15776
