The W-series is a 4-speed or 5-speed manual transmission built by Aisin. It is a super strong transmission which will just fit in the Datsun 1200 transmission tunnel.
Toyota W transmissionᵂ by Aisin. About 90 pounds. W can handle 300-350 ft-Lb torque. If your engine makes more torque, use the larger heavier Toyota R transmissionᵂ. The R154 can handle 450-550 ft-Lb torque.
- W50 5-speed Steel Case (all others are alloy)
- Steel case and alloy case gearboxes do not interchange
- W55, W56, W57, W58, W59 all interchange bellhousings
- All have the same output splines in common with the T50 Automatic gearbox
W55 5-speed 0.850 overdrive, 3.566 1st W56 truck extra-low 1st gear 3.954 1st W57 5-speed 0.861 overdrive, 3.285 1st W58 5-speed 0.783 overdrive, 3.285 1st W59 truck extra-low 1st gear 3.954 1st
W50 1973-1981 Celica, Carina, Corona, Supra, Hilux
W55 1981-1995 2002-2005 USA Lexus IS300
W56 1983-1986 Supra Japan 1986 Crown 1986 Cressida 1982-1985 Celica with 21R engine
W58 (same as W57 except for 5th gear ratio) 1982-1998 non-turbo Supra, Celica, Cressida, Soarer 1982-1985 Celica USA 1992-1997 Lexus SC300 1982-1992 Lotus Excel
W58 came in North America Celica 1982-1985 -- all with 22R engine
Coupe | Liftback
ratios W58 W57 1st 3.285 2nd 1.894 3rd 1.275 4th 1.000 5th 0.783 0.0861 REV 3.768
Alloy Case W55-W59
Swap Notes
3Rotor and Cameron_Datto have fitted W gearboxes to Datsun 1200.
To adapt to the Nissan A Engine use one of the following methods:
- Cut & Shut
- Adapter Plate
- A-series bellhousing (custom order from Dellow)
3Rotor: remove the cross-member mounting pods in the tunnel, open up the shifter hole a bit to the back (no other tunnel mods needed). Cameron had do to "some heating & beating" in the tunnel topic
- Find/fabricate a 180mm clutch plate to fit the splines of the W
- Newer Ws must swap the electronic speed sensor for a cable drive
Wogboy: The clutch is original datto 1200. I used the datsun clutch fork and cut the opposite side of the bellhousing on the t50. Then is used the toyota thrust race, ground down the datto clutch fork to clear , then welded a couple of allen keys(strong steel) to reinforce the clutch fork. The result was the sweetest clutch action I have ever felt.
Hydraulic clutch cylinder fitted
tail-shaft needs lengthening and the right yoke for this box
Tunnel mod: Remove tunnel bosses and use Wide gearbox crossmember
More Pics: 3rotor Gearbox transplant
Cut-n-Shut
racinaround cut the front 3" off a FWD SR transmission, then welded it to the Supra gearbox. This is handy because Nissan doesn't make RWD 5-speeds that fit the FWD SR engine.
Steel Case W50
W50 is the steel-case version of the W gearbox. It does not interchange with the W55-W50 alloy case models.
W50 Adapter Kit
Reportedly, Dellow offers a kit to bolt up a W50 to a Datsun A-series engine.
W50 Adapter Plate
The W50 Toyota 5-speed can be fitted to a Datsun A-series engine. Use an A-series automatic transmission bellhousing with an adapter plate to fit the W50 gearbox. The W50 is a non-alloy gearbox, and the thickness of the adapter plate would be different for any alloy W gearbox.
Bare adaptor plate to suit an A series auto bell housing and a W50 steel case Celica 5 speed
Adaptor plate bolted to Celica box, clutch fork pivot fitted.
Datsun 56A 4-speed verses a Celica W50 steel case 5-speed fitted with an A series auto bell housing and adaptor plate.
Above: A series 56A 4-speed
Below: W50 Celica 5-speed below. Modified Datsun clutch fork fitted to Celica thrust bearing. Slot cut through the side of an A series auto bell housing . Clutch fork retaining spring and clutch cable mount still to be made.
The input spline lines up exactly
The spigot fits into the back of the A-series crankshaft as per standard but a machined spigot bearing needs to be made to suit the Celica input shaft.
mods need to be made to the clutch fork , thrust baring carrier
A new cross member needs to be made , the tunnel needs a bit of a massage
the speedo cable matches up to the Celica box with no mods.
A clutch needs to be sorted out , a new spiggot baring needs to be made and a new tailshaft is needed.
funkeyman photos
Clutch
Some Ws use the same spline/diameter input shaft as the Datsun A. So the Datsun clutch disc fits
Other Ws use a larger 1-1/8 shaft with 18-splines. For this you may be able to re-drill the A-series flywheel to take one of the smaller clutches.
Exedy/Daikin KTY18 * Shaft diameter 1" * Input splines 21 * Diameter 210 to 213 mm * Celica 1994-1997 * Corolla 1993-1997
