Front door hinges are all the same: Sedan/Coupe/Ute/Wagon.
[edit]
Upper hinge: sheet metal Lower hinge: cast metal
FRONT DOOR Upper & Lower hinge differs * Upper Left & Right hinge differ * Lower is same on both sides * 2-dr, 4-dr, truck/van/sedan/coupe all the same
[edit]
See also: Front Door Part Numbers
See also: Rear Door Part Numbers
[edit]
Hinge Replacement
The hinges bolt to the cowl dash side panel, and the bolts are accessed from inside the passenger cabin. The bolts for the lower hinge can be accessed by removing the kick panel plug.
[edit]
Hinge Repair
Door dropping down on its hinges?
NAPA Door Hinge Pin & Bushing Kit Balkamp 6755157 Pin Length: 2.85" Pin Diameter: .313" Bushing I.D.: 0.315" Bushing O.D.: 0.397"![]()
Motormite/Door Hinge Parts 38397
Tip: You will need to cut the pin to length
If you need the bushings, and the pin is still OK:
H0400-73002 BUSH-DOOR HINGE UPPER $2.53 USD H0400-73002 BUSH-DOOR HINGE REAR DOOR UPPER & LOWER H0402-H1001 BUSH-DOOR HINGE LOWER $1.29 USD
Also see: Datsun Door hinge repair from NWDE
ドア ヒンジ
