B310 Bumpers
Revision as of 21:40, 9 January 2025; view current revision
Category: Datsun B310
Large park-bench bumpers were optional on Australia and Japan-market B310s. As usual, North America required the large bumpers while other countries got a choice, including still-boxy but lighter bumpers and simple full-chrome versions.
One-piece VS three-piece Bumpers
One-piece bumper bar is fashioned of a single piece of steel. It may or may not have rubber covers over the ends
174_5b5a871b20802.jpgPost 489047
Three piece bumper consists a larger channel-shaped steel piece, and REQUIRED rubber end-covers. The channel piece is straight with no curved end -- only the rubber curves aroud the side of the car
The JDM/AUS three-piece bumper is a shock-aborsber design which appears to be lifted from the 1975 USA B210 5-mph bumper design (resistant to body damage in low-speed collision).
One-piece bumper: steel stamping, chrome plated
One-piece all-chrome bumper with bolted-on rubber end caps
Front
Worldwide B310 have lights in the front bumper. North American bumpers have no lights.
1-piece bumpers
* All Sedan, Coupe (except OPTION)
* All Van (VB310)
* Not used for North America
3-piece bumpers
* All Wagon (WB310)
* OPTION Sedan, Coupe Round-eye late 7812-
* OPTION Sedan, Coupe Square-eye
* All North America
Round-eye 1978-1979
Square-eye 1980-1982
 Van (VB310) all round-eye
 early Sedan, Coupe: round-eye  7711-7909
 late  Sedan, Coupe: square-eye 7910-
 Wagon (WB310) round-eye or square-eye came only with 3-piece bumper
One-piece Bumpers
Early bumpers are one-piece, and continued to be used even after other styles were introduced. In Japan, they were used on all B310 except Wagon (WB310). One-piece bumpers were available with or without rubber end-caps and rubber strips.
Plain VS Luxe
Plain | or with fancy rubber junk bolted on
174_5b59b7ccc6067.pngPost click for topic 174_5b59b7dee2012.pngPost 489043
STAY BOLT [STAY-TO-CHASSIS] 2 x M10
62250-H9100 round headlight
62250-H9105 square headlight
* look similar, perhaps spacing differs?
STAY FRONT RH
For H8500 plain bumper (mounting close to body)
  62210-H8500 round headlight cars
  62210-H8505 square headlight cars
For H8560 luxe bumper (mounting out from body)
  62210-H8900 round headlight cars
  62210-H8905 square headlight cars
62022-H8500 Plain Bumper
All metal 62022-H8500 all-chrome with no rubber end-caps, in Japan was fitted to VB310 and lower trims of Sedan and Coupe.
174_5b5a871b20802.jpgPost 489047 174_5b5a877165d7f.jpgPost 489047
174_5b5a872d46c25.jpgPost 489047 174_5b5a8744bbc48.jpgPost 489047 174_5b5a87578bb91.jpgPost 489047
Front combination lamps fit into the front bumper
174_5b5a8762a62ef.jpgPost 489047 174_5b5a877d94ea1.jpgPost 489047
62022-H8500 - all years JDM Van (squareback)
saniwo2000-img600x450-13157201226mj0g32137.jpg 19791.jpgAlbum 19791
62022-H8500 - Sedan Round Eye + Square Eye (CT, City DX, DX only)
0500576A30160128W00132.jpg n63206471banbanbo2000-img600x450-1220170642xzbwaz49859.jpg f74268333akasrl311-img600x450-12275318311fn2pz12529.jpg maina6000-img600x450-12826213852agli336766.jpg m73111669sakuranbon_bon-img600x450-1263129635luis9b54101.jpg
62022-H8500 Coupe DX (round eye), Coupe ES (square eye), Coupe Sport (1980)
ysmat2008-img600x450-1291176224rbvtb639211.jpg k108869318marutyosyouten-img600x450-123536438497ke9027207.jpg m51627383hirakka-img600x450-1198906969dsc02067.jpg 7136.jpgAlbum 7136f66158356daddys_s-img600x450-12206729801a0eul74717.jpg
Australia VB310 with H85 bumper
9936.jpgAlbum 9936
62022-H8900 Luxe Round Eye
One-piece GL have angle-cut rubber ends
14588.jpgAlbum 14588
Round Eye One-piece with rubber-covered ends (GL,GX Coupe & Sedan)
g64564908chk38750-img600x450-1219999197j55bof73736.jpg k41994716youichi11221104-img600x450-1180671823dscn0486.jpg
g60467996kimi_z-img450x600-1208093678b310cat11.jpg g65872303kimi_z-img450x600-1208094744b310cat31.jpg k116127160zepcore-img450x600-1254468535jfnysi75934.jpg k116127160zepcore-img600x450-1254468536przuxb75934.jpg sunny_new140-A.jpg sunny_new140-B.jpg
62022-H8560 Luxe Square Eye
From 1979 OCT has added a rubber strip along bumper front top edge
b84632467hakosuka_r-img600x450-1198315215dscf0005.jpg f69854632goos5555-img600x450-1229835883ffex4v13282.jpg
Note: the orange coupe has the Strip removed, but the holes are visible
Overriders
Rubber bumper overriders (not used in Japan)
12735.jpgAlbum 12735 16084.jpgAlbum 16084
Misc
Custom: Silver painted metal bumper (old-style STD look). B310 didn't use painted bumpers like B110 standard, but it makes for an interesting appearance.
Custom: Big-bumper model retrofitted with small bumpers. Note the large openings behind the bumpers.
minorimn-img600x400-1277726772u58yqr76588.jpg r51797668ts_sunny310-img600x338-1234083902fhmc1457225.jpg
Stays
62671 STAY FRONT RH
  62210-H9311 W -7909
  62210-H9315 W 7910-
  62210-H8500 V, K.DX, S.DX+CT+CITYDX
  62210-H8505 K.ES+SPR, S.DX+CT
  62210-H8900 (S+K)GL+GX# -7909
  62210-H8905 K.GS+GX+RSE,S.GL#+GX 7910-
62671A BOLT [STAY STUD BRACKET]
  62250-H9100 (K+S)-7909, V
  62250-H9105 (K+2)7910-
08911-14037 STAY NUT
62650A BUMPER-TO-STAY CARRIAGE BOLT
  01135-00061 W, (S+K).(A14+A15)# 6
  62663-27700 2 OR 4
08911-10637 NUT
62673A BUMPER-TO-END-BRACKET CHROME BOLT
08911-10637 NUT
early cars with rear bumper below plate. Brackets.
10602.jpgAlbum 10602
H89
62210-H8900 BUMPER STAY RH
62212-H8900 BUMPER STAY LH
Deluxe Sedan/VB310 stays
28595.jpgAlbum 28595 28596.jpgAlbum 28596 28597.jpgAlbum 28597
Modified with second set of holes to mount closer to the body and about 5mm lower (tilts down slightly)
28609.jpgAlbum 28609 28610.jpgAlbum 28610 28611.jpgAlbum 28611 28612.jpgAlbum 28612
Three-piece Bumpers
A three-piece bumper has a channel-section center bar and each end is bolted to it. Thus, three pieces.
Regular type mounted with stays
* Wagon (WB310 sport wagon/"Sunny California")
* NOT AVAILABLE Van (VB310 regular wagon)
type mounted with shock absorbers
* OPTION JDM Wagon, A14/A15 Sedan, A14/A15 Coupe
* STANDARD EQUIPMENT for all North America B310
  including A12A cars
3-piece bumpers are much heaver, with a complex cross-section.
3-piece pointed end | 1-piece diagonal-cut end
62022-H8905 Round Eye
Round Eye (late) 62022-H8905. W/O rubber strip along top edge.
7901-7909 (JDM WB310)
Australia
#North America - H91 bumper w/o lights and w/overriders
62022-H9936 Square Eye
Square Eye 62022-H9936. Has rubber strip along top edge of front surface.
7910- (square headlight models)
e86542521carogon_6666-img600x450-122612155585jhie21743.jpg m49651272blacknight820002000-img600x450-1204209632dsc07198.jpg m67956792zepcore-img600x450-1261108093gpprrf38677.jpg
Malaysia
8708.jpgAlbum 8708
#North America - H99 bumper w/o lights
Blackout
EUROPE, CARRIBEAN: Rubber covered bumpers -- 1-piece Luxe bumpers.
23893.jpgAlbum 23893 17929.jpgAlbum 17929 17960.jpgAlbum 17960 m67956792zepcore-img600x450-1261108093ktfl0b38677.jpg
North America
Canada & USA B310 have no lights in bumper (they are in the grille instead). North America was also *only* using the #Three-piece Bumpers for all B310.
1979 (round headlamp) has rubber overriders
1980-1982 (square headlamp) has rubber strip
BUMPER-FRONT CENTER
 -1179 62022-H9100
       62050-H9100 OVER RIDER ASSY-BUMPER
 1279- 62022-H9900/62022-H9930
       62060-H9900 RUBBER STRIP ASSY-FRONT
BUMPER SIDE ASSY-FRONT
 62032-H9100 RH, 62033-H9100 LH
1979-1980.5 (round headlamp)
4714.jpgAlbum 4714 6354.jpgAlbum 6354 8854.jpgAlbum 8854 21586.jpgAlbum 21586 devilscrown666-img600x450-1307435890i8zdmi72986.jpg devilscrown666-img600x450-13074358907rikwd72986.jpg
1980.5-1982 has rubber strip instead of protruding overriders
210-grill.jpg 3101.jpgAlbum 3101 13366.jpgAlbum 13366 e65951964power_planning-img575x479-1171511455310em003.jpg B3101980Datsun210510810WagonsAd.jpg 174_5d5068eed7540.jpgPost 492200 174_5d81e23430e79.jpgPost 492632
Customized with 1979 bumper on later B310
14364.jpgAlbum 14364
Parts
Side (end finishers)
Large Bumper
* 62032-H9100 RH
* 62033-H9100 LH
Small Bumper (GL bumper finishers)
* #62032-H8900 RH
62032-H8900 Luxe Finisher
62032-H8900 RH GL bumper finisher
28598.jpgAlbum 28598 28599.jpgAlbum 28599 28600.jpgAlbum 28600 28601.jpgAlbum 28601
62033-H8900 Luxe Finisher
62033-H8900 LH GL bumper finisher
28602.jpgAlbum 28602 28603.jpgAlbum 28603 28604.jpgAlbum 28604 28605.jpgAlbum 28605 28606.jpgAlbum 28606 28607.jpgAlbum 28607 28608.jpgAlbum 28608
B310 フロントバンパー エンドフィニッシャー 左
Rear
Small and Large
Fiberglass
