<-- back to H145
B10 Datsun 1000 came with a light alloy version of the H145 differential.
The alloy carrier is weaker (less able to handle the torque) but is lighter, thus keeping unsprung weight down.
B10 4.111 (37:9) sedan & coupe B10 4.375 (35:8) van B20 4.625 (37:8) truck
- All use the same #Gear Carrier
- The bearing cap fit over studs and are secured with nuts, compared to the B110 cast iron H145 which uses bolts
- Instead of the inexpensive crush sleeve that the cast iron H145 uses, the alloy unit uses reusable shims for side bearing preload
'37 X 9' stamping indicates 4.111 gear ratio (37/9), as used by B10 sedan and Coupe
Carrier Assembly
The Carrier Assembly, also called the diff center or 3rd-member 'pumpkin', comprises the #Gear Carrier with differential gear case and gearset installed.
Gear Carrier
B10 Datsun 1000 H145 alloy carrier 38310-18000 COMP.-CARRIER, gear ALL fixing differential bearing cap (4 used) * 38315-18000 STUD * 38317-18000 WASHER * 38318-18000 NUT
The gasket face is 86mm Outside Diameter
See also: Differential Part Numbers
38300-18000 ASS'Y-CARRIER, with gear (37 T : 9 T) Sedan & Coupe 38300-18100 ASS'Y-CARRIER, with gear (35 T , 8 T) Van < 38300-H0700 38300-H0700 ASS'Y-CARRIER, with geer (35 T : & T) Van 38300-15400 ASS'Y-CARRIER, with gear (37 T : 8 T) Truck < 38300-G0500 38300-G0500 ASS'Y-CARRIER, with gear (37 T : 8 T) Truck 1 38310-18000 COMP.- CARRIER, gear 4 fixing differential bearing cap 2 38315-18000 STUD 4 3 38317-18000 WASHER 4 4 30318-18000 NUT 4 5 38100-18000 SET-GEAR. hypoid with pinion (37 T : 9 T) Sedan & Coupe 38100-18100 SET-GEAR, hypoid with pinion (35 T : 8 T) Van 38100-H0700 SET-GEAR, hypoid with pinion (35 T : 8 T) Van 38100-15400 SET-GEAR, hypoid with pinion (37 T : 8 T) Truck 38100-G0400 SET-GEAR, hypoid with pinion (37 T : 8 T) Truck (from '69-Nov.) <x> 38100-15400 6 38102-18000 BOLT-drive gear 8 38102-18100 BOLT-drive gear 8 <> 38102-18000 7 38103-18000 STRAP-lock bolt 8 38103-18001 STRAP-lock bolt 4 <> 38103-18000 38103-18100 STRAP-lock bolt 4 <> 38103-18001 8 38421-18001 CASE-differential gear 9 38423-10000 GEAR-side, differential bevel 2 10 as required 38424-18000 WASHER-thrust, side gear 38424-18001 WASHER-thrust, side gear 38424-18002 WASHER-thrust, side gear 11 38425-18000 MATE-pinion, differential bevel 2 12 33426-18000 WASHER-thrust, pinion mate 2 13 38427-18000 SHAFT-pinion mate 14 38428-18000 PIN-lock, pinion shaft 15 38440-14361 ASS'Y-BEARING, differential side 2 16 as required 38453-18000 SHIM-adjusting, drive gear (0.05 T) 38454-18000 SHIM-adjusting, drive gear (0.075 T) 38455-18000 SHIM-adjusting, drive gear (0.125 T) 38456-18000 SHIM-adjusting, drive gear (0.25 T) 38457-18000 SHIM-odjusting, drive gear (0.5 T) 17 38120-18000 ASS'Y-BEARING, drive pinion, rear 18 38140-18000 ASS'Y-BEARING, drive pinion, front 19 as required 38125-18000 WASHER-adjusting, drive pinion bearing 38126-18000 WASHER-adjusting, drive pinion bearing 38127-18000 WASHER-adjusting, drive pinion bearing 38128-18000 WASHER-adjusting, drive pinion bearing 38129-18000 WASHER-adjusting, drive pinion bearing 38130-18000 WASHER-adjusting, drive pinion bearing 38131-18000 WASHER-adjusting, drive pinion bearing 38132-18000 WASHER-adjusting, drive pinion bearing 38133-18000 WASHER-adjusting, drive pinion bearing 38134-18000 WASHER-adjusting, drive pinion bearing 38135-18000 WASHER-adjusting, drive pinion bearing 38136-18000 WASHER-adjusting, drive pinion bearing 38137-18000 WASHER-adjusting, drive pinion bearing 38138-18000 WASHER-adjusting, drive pinion bearing 38139-18000 WASHER-adjusting, drive pinion bearing 20 as required 38165-18000 SPACER-drive pinion bearing 38166-18000 SPACER-drive pinion bearing 38167-18000 SPACER-drive pinion bearing 21 38153-18000 SHIM-adjusting, drive pinion (0.05 T) 38134-18000 SHIM-adjusting, drive pinion (0.075 T) 38155-18000 SHIM-adjusting, drive pinion (0.125 T) 38156-18000 SHIM-adjusting, drive pinion (0.25 T) 38157-18000 SHIM-adjusting, drive pinion (0.5 T) 38189-18000 SEAL-oil, drive pinion 22 38189-18000 SEAL-oil, drive pinion 23 38210-18000 ASS'Y-FLANGE, companion & dust shield 38210-18001 ASS'Y-FLANGE, companion & dust shield <> 38210-18000 24 38215-01300 WASHER-plain 25 38216-18000 NUT-drive pinion 26 38320-18000 GASKET-gear carrier 38320-18010 GASKET-gear carrier <> 38320-18000
